KitchenAid KCMS145J Microwave Oven Logo
Posted on Dec 01, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Microwave partially heats
I have a Kitchenaid KCMS185JSS microwave since 2002.
A couple of weeks ago it wouldn't heat anything. I found that the door and frame had shorted in two small spots, apparently due to conductive food spots.
I cleaned these and covered the spots with appliance paint.
It worked fine until this weekend. Now it only seems to heat water but nothing else.
Is it time for replacement or repair?
Thank you.
  • William Miller
    William Miller May 11, 2010
    Sounds like you took care of the arcing at the door and frame just fine.
    Now you have a separate issue of poor heating.
    Assuming your inside light, stirrer, and turntable are working, you may have a failing relay on the control board or a failing magnetron.
    First I would suggest removing the stirrer cover in the ceiling of the oven and running the oven for a a minute or so while watching to see if it turns steadily.
    If not, it may be binding or the motor may be bad.
    Please replace the cover when you are done testing.
    Next, the
    following test will provide a suitably accurate measurement of the
    output power of any microwave oven. Variations or errors in performing
    this test will produce uncertain results. If the line voltage (from the
    electrical outlet) is low, the magnetron output will be correspondingly
    low.
    Equipment needed:
    - Microwave safe container with 1000 mL (1 Liter) gradation.
    - Fahrenheit or centigrade thermometer
    Procedure:
    Pour
    exactly 1000 mL (1 Liter) of cool tap water into the container. Using
    the thermometer, stir the water, then measure and record the
    temperature. For accurate results the water should be about 60 degrees
    F (20 degrees C).
    Place the container on the center of the
    oven cooking shelf (do not leave the thermometer in the container and
    remove any metal racks), and heat the water (at full power) for 63
    seconds. Use the second hand of a watch, not the oven timer.
    After
    the heating time is completed, immediately remove the container, stir
    the water, re-measure and record the temperature of the heated water.
    Subtract the starting water temperature (step 2) from the ending water temperature (step 3) to obtain the temperature rise.
    To
    determine the output power in watts, multiply the total temperature
    rise by a factor of 38.75 if you're using a Fahrenheit thermometer or
    by 70 if you're using a centigrade thermometer.
    Let us know how it goes, then we can offer further guidance depending on thew results.
William Miller
Level 3:
  • KitchenAid Master 9,179 Answers
  • Posted on Dec 05, 2008
William Miller
KitchenAid Master
Level 3:
Answers
9179
Questions
Helped
4481212
Points
21747
Assuming your power line voltage is right, bearing the whole thread in mind, I'm sure you have a bad magnetron.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you follow the safety & disassembly info, this is not a difficult job for a do-it-yourselfer.
Denny Adams
Level 2:
  • Expert 125 Answers
  • Posted on Dec 02, 2008
Denny Adams
Expert
Level 2:
Answers
125
Questions
Helped
52487
Points
212
Its time repair will cost more than a new one
My kitchenaid microwave KCMS185JSS-4 is running fine but does not heat the food. Is it worth trying to get fixed?
To fix this issue you really need to hire a professional for safety purposes. You are looking around $500 + or - $50 for this repair.
I have a KitchenAid microwave model # KCMS185JSS. Everything works except it stopped heating up anything. Is there a separate fuse for the microwave heating? Where is it? can I fix this myself?
Sounds like the microwave's magnet tron (join two words together this page will not allow the correct word) the has gone down. They only last a short time depending on use. Not a great job to do on your own (if you do not know what you are doing) the part cost about 35pounds so most cheap microwaves are not worth repairing, if it is an expensive one it may be worth paying for the repair.
Intermittent heating
From the description you have a bad latch switch on the door caused by build up of food particles or ware.
Microwave not working (generating heat)
Please check the door switch for proper operation.
Was heating something when it made a zinging noise and now thothing is working no lights or power
My same microwave did this about a week ago... repair people said the part that surrounds a fuse had burned through. 350 to fix it, I am considering just getting a new one since I have now found that mine has had a replacement part fix done after a recall on this microwave. If you have not read the recall info you can find it easily by doing a search for Kitchenaid Microwave recall. There will be a small green square sticker by the serial number if yours had had the recall repair done already. Mine had but I still have had this recent problem even after the recall repair.
4helpful
Kitchenaid KCMS185JSS-3 microwave - no power
Well your gonna have to take it down a take apart the microwave more than likely. Probably have a shorted HV diode,magnetron, shorted winding in HV transformer.burnt or frayed HV wire insulation
2helpful
My KCMS185JSS-5 microwave has no heat. It seems to be running, the light and turn table all work, but it won't heat water.
hi..Your micro hood is "shot".so it is not working properly.
The food may not be heating,but the electrical and the walls
of the unit might heat.This may cause sparking and melting
of the interior of the unit.
check it out..
thank u..
kindly rate my response..
KitchenAid KCMS185JSS1 Door Removal
On most new MW ovens, the door will lift off the hinges once the top grille is removed. There are two screws on the top that hold the grille in place.
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
