I have a digital HD package from my cable company and have one HD box I rent and another I just bought from a friend that was originally set up with Comcast, which is a different cable company than I'm with. It is the same Motorola HD box that I have on my TV that was set up by the cable company. A friend who works for the cable company told me I could try doing a 3 finger salute to reset the box, because I wasn't getting any channels through the box I bought from a friend. I have everything set up correctly in terms of wiring. So I did the 3 finger salute and now the front of the Motorola box is reading "FR HUnt" and "E603, E607" I'm not sure what its doing, but my friend who works for the cable company said it is downloading software to reset itself. Does this sound accurate, how long should I expect this to take, is there a constant signal that is sent out by cable companies to reset a box?? Thanks for any help.
    Problem Solver:
  • 11 Answers
Each DVR or box that allows you to access anything other than broadcast analog signals (channels 1 thru 100) has to be registered with your cable company. The box has an internal device number similar to the MAC address a wireless PC card might use to connect to a WiFi network. If that number is not registered as a box allowed to be on your account, then it will do nothing at all other than display those numbers you refer to. This is done to prevent you from buying a cable box from somewhere else, instead of renting the one from the cable company. The cable company looses that "rental" money if they allow this. You may be able to contact your cable company to see if they can add that box, and will ask you for numbers on the bottom or back of the box. You may also be required to pay an additional HD charge to have a 2nd HD box in your home, even if you own the box.
The bottom line is to contact the cable company, let them know what you have, and ask what is possible.
Posted on Dec 01, 2008
I don't now how i recive tv chanels in hd
Your source has to be in HD like a local broadcast TV station currently broadcasting in HD which you get with a VHF/UHF antenna connected to the HDTV. Most primetime TV shows are in HD so using the antenna on the HDTV is all you need. Press MENU on your TV remote and make sure you have ANTENNA set instead of cable to get local TV stations.
You also could use your local cable TV provider. You would need digital cable service and a HD cable box with HDMI or component video cable hookup to the HDTV. HD channels are typically above 100. Call your cable TV provider for more details.
Read your user manual for the LG TV. Ask for help from family, friends, neighbors, local electronics shops.
Mar 13, 2011 | LG 32LG30 32 in. LCD HDTV
I bought a 42inch snayo hdtv and i cant get it to recieve any hd cahnnels and was wondering why.
You need an HD Cable box from either your Satellite provider or the cable company, and you must subscribe to the HD package. The HD package is usually in a different channel range than your SD channels.
Mar 02, 2011 | Sanyo DP42849 42 in. HDTV
Cant get a signal do i need a box i do have cable
Normally the TV will work with over the air signals, but depending on how far you are from the station it does poorly as the new frequencies are higher in the band width and do not travel through the aur as well as the old signals. For that reason you have picture degredation and drop outs. If you have cable, then you need a set top box from your cable carrier. Those boxes cost about 5-6 bucks to rent each month. They take the signal from the cable and put it out on channel 3 or 4 (your choice on the STB) and you can use the cable companies remote to change channels depending on what package you bought.
Jan 06, 2011 | Televison & Video
Not getting HD from the set. I have an HD cable box. I bought an HDMI adapter, but still no HD.
The cable box output needs to be set to HD, 1080I, 720P, 1080P. If you call the cable company they should be able to set the box up to ouput a higher resolution. A way to check your hd would be to play a blu ray disk through a ps3 if you have friends with one or have one yourself. If it plays hd just fine you know for sure it's the cable box.
May 07, 2010 | Sony KP-57WS500 57" Rear Projection...
I have a RCA HDTV model# R52WH74. The cable company said all I needed was a digital box from them and a connector cable which I have. However the connector cable that fits into the digital box does not...
The cable company is always encouraging customers to rent cable boxes. It is hard to tell if a HDTV has a Quadrature Amplitude Modulation feature unless you ask at the time of purchase. Now the only thing to find out is to have it scan. Your TV has 2 RF inputs. You can choose one to hook up directly from cable source. Make sure to set up the right one for the input that you connect then let it scan. You will see something like channel 7, channel 7.1.... After that you have to make notes of what number is for which channel since it doesn't list out as what you have with a cable box. That is the inconvenience to watch without a cable box, but if you know what channel already then you can go straight to it without searching from remote.
I find out that cable box renting is a rip off. Another option is buy a new TiVo HD 20GB is selling now for 249.99 at Best to replace cable box legally and have all features just like cable box plus many more. However you have to pay TIVO service in order to record program. It still about the cost, but at least you know there is an option. Hope this can help.
Dec 29, 2009 | Televison & Video
If i buy a full hd tv,instead of hd ready,can i view HD PROGAMS from outdoor arial without anymore setup. thank you A R SHEARING.
You do not want to buy HD ready (ready means it will accept HD sources), Ful HD TV will have ATSC digital tuner for off the air signal, you will want it to have QAM tuner also so if you decide to get cable, you can get unencryped HD programs without using the cable box (that is what I am using with my Entended BASIC Comcast cable without using/renting their box, Comcast gives three free boxes, then you have to rent the rest if you have more than 3 TVs at about $7 a month).
Nov 19, 2009 | Televison & Video
Cable companies are slowly but surely reducing the channels you can get without a digital box, which they will supply. You will need to cantact them and rent a HD cable box or converter from them that will work with your displays built-in tuner. However, if your display is HD compatible, then I would just asked your cable company for and non-DVR HD cabe box and connect it to your display with component cables....
May 30, 2009 | Toshiba 61A61 61" Rear Projection...
How do I set up model 50v500 hitachi tv to receive hd
You have to have an hd cable box it is different from your run of the mill digital cable box. Most people rent them from their cable provider. This will enable you to get HD channels through them
Apr 01, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
FLM3232 will not receive channels directly from Comcast Cable
Use the TV/Cable rf jack and auto program the TV.
Mar 16, 2009 | Polaroid FLM-3232 Television
HD reception
To have HD on cable, you will need an HD cable box with the HD service activated by the cable company. Some cable carriers will provide some basic HD services included in the base cost with the box.
From the HD cable box to the TV, you will need an HDMI cable between the cable box and the TV set. This is an HDTV interconnect wire. You will have to refer to the instructions on the cable box and on the TV to get everything going properly.
Jerry G.
Apr 28, 2008 | Sanyo DP26746 26 in. LCD Television
Televison & Video Logo
224 people viewed this question
Top Televison & Video Experts
