Question about Philips DCP855/37 Portable DVD Player
DVD Does not play SDHC Cards
Hello everyone,
I have a Philips DCO855/37 which does not recognize an 8 gb SDHC card. I wanted to know if this is a problem with only my card. Does this at all work with SDHC cards, Did it work for anyone?
Also the screen flickers sometimes when i adjust the screen panel. Is this a common behaviour for this Player.
Thanks,
KP
SOURCE: WHITE SCREEN
Our Philips PET702/37 Portable DVD player has white screen, when i press the screen appears the image. please help me. thanks
Posted on Aug 28, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: password on my dvd player
The default password is 136 900
You may have to enter it twice
Once you have entered the default and changed the password, you can then go in and turn the password off:
The same password is used for both
Parental Control and Disc Lock. Enter
your six-digit password when prompted
on the screen. The default password is
136900.
1 In ‘PREFERENCE PAGE’, press 3 4 to
highlight {PASSWORD}, then press 2 to
select {CHANGE}.
2 Press OK and the menu appears.
Old Password
New Password
Confirm PWD
OK
3 Use the numeric keypad (0-9) to enter
your old six-digit password.
➜When doing this for the first time, key
in ‘136900’.
➜If you forget your old six-digit
password, key in ‘136900’.
4 Enter the new six-digit password.
5 Enter the new six-digit password a second
time to confirm.
➜The new six-digit password will now
take effect.
6 Press OK to confirm.
-Tha Mp3 Doctor
Posted on Feb 25, 2009
  • 35 Answers
SOURCE: Want to unlock Philips DVD player (DVP320)
Did you follow these instructions exactly? If you pressed 9990, as you mentioned, it will not work. You need to press 99990. Do you see region "0" on the display?
start the player without any DVD in it.
open the lid.
while the lid is open press 9,9,9,9,0
you should see region 0 displayed.
close the lid.
Your DVD player is now region free.
note:
replace 0 with 1 to 6 at to set the wanted region number if needed.
Posted on Mar 05, 2009
SOURCE: Philips Portable DVD Player PET 730/98 Unlock Code Needed!
Philips PET730/05
Using remote control
Setup
Down arrow
Down arrow
Right arrow
212225 (you won't see anything!)
Left arrow
Down arrow
should now show region code box
Enter 0
Setup to save
Posted on Apr 09, 2009
SOURCE: does not play divx/mpeg4 files on dvd disk!!
The player plays strictly DIVX files, but not variants like XVID (which today is more common since divx became not free).
Divx is actually the same than XVID. After spending days converting my files from xvid to divx, realized that changing only the FOURCC code of the files works.
Look for a program named videoinspector. It allows to edit the fourcc for a video file. for all xvid and variants change the fourcc of the files to DIVX. The change takes a second instead hours of conversion, and movies in xvid that used not to play on this device, now will be played without problems.
Posted on Jun 19, 2009
Hello I currently have a 2 GB memory card in my canon SD 1000, camera i want to upgrade to 4GB memory card, what is the best brand or type? Will 4GB SDHC memory card work with my canon camera? ...
The Canon SD1000 will work with SDHC cards, up to 32GB in size. Stick with any of the major brands and you won't have problems.
The HP 7350 will NOT work with SDHC cards, limited to SD cards 2GB and smaller.
Mar 26, 2011 | HP PhotoSmart 7350 InkJet Printer
8 Gb SD card not recognized by Minolta DiMage Z6 digital camera. What is maximum size SD card this camera can address?
The Z6 works with MMC and SD cards. Your 8GB card is actually an SDHC card. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. You need to use MMC or SD cards, 2GB and smaller.
Mar 12, 2011 | Konica Minolta DiMAGE Z6 Digital Camera
New sandisk 8 gb sd card reports memory error when inserted in camera. other cards work in camera. card is recognized by laptop. tried reformatting by Vista
There are no 8GB SD cards. Cards this size are SDHC (High Capacity). SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC cards. SDHC is not backwards compatible.
Dec 01, 2010 | SanDisk Cameras
Hp 8250 will nt recognize a promaster 4 gb sd hc card...i tied two
The 8250 works with SD cards. Your 4GB cards are actually SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work (SD cards will work in SDHC devices but not the other way around). You need to use SD cards 2GB and smaller.
Sep 13, 2010 | HP Photosmart 8250 InkJet Printer
What is the maximum SD size that will work with the DSC-4500Z camera?
The manufacturer of your camera specifies SD card compatibility without providing a specific number. This is not uncommon however, as the maximum size for SD cards is 2 GB. Cards that have a larger capacity than 2 GB in the "SD" format are "SDHC". Read the label of these cards (that have a larger capacity than 2 GB) that *look* identical to SD cards, and you'll see that they are in fact SDHC types. The SDHC card can have a capacity of up to 32 GB. A device that is compatible with the SDHC specification should be able to read any SDHC card *and* any SD card as well; because the standard requires "backward compatibility" to the older SD standard. A device that accepts SD cards should be able to read any SD card, *but* if an SDHC card be introduced to it, it may provide unreliable results (from being able to access only 2 GB of the capacity or not recognizing the card at all). Make sure your pictures are safe and don't get lost; use only SD cards in this camera.
I hope this helps!
Jun 08, 2010 | Apex Digital Digitrex DSC-4500Z Digital...
How big of an SD card can I use with my Casio EX-Z750 Camera? I'd like to use a 4 GB or 8 GB but was warned they may not work. Can't find this info on the Casio site, and don't want to waste money on...
The Z750 uses SD cards and is limited to 2GB cards. 4GB and up cards are SDHC (Secure Digital High Capacity) cards and do not work in devices designed for SD cards. This is a hardware issue and cannot be upgraded in firmware.
SD cards will work in SDHC devices, but not the other way around.
Jan 19, 2010 | Casio Exilim EX-Z750 Digital Camera
Is lumix dmc-fx33 compatible with sandisk ultraII 8gb sdhc cards?
No, 8 GB is too large. According to page 5 of the manual, 4 GB is maximum:
•When the term card is used in these
operating instructions this refers to the
following types of Memory Cards.
– SD Memory Card (8 MB to 2 GB)
– SDHC Memory Card (4 GB)
–MultiMediaCard (still pictures only)
More specific information about memory
cards that can be used with this unit.
• You can only use an SDHC Memory Card
if using cards with 4 GB or more capacity.
• A 4 GB Memory Card without an SDHC
logo is not based on the SD Standard and
will not work in this product.
The manual can be had below:
http://service.us.panasonic.com/OPERMANPDF/DMCFX33.pdf
Oct 05, 2009 | Cameras
What kind of memory SD card would work for Panasonic DVD Recorder DMR-ES46V? I was hoping to put in a 8 gig memory card but those are all SDHC. Will those cards work in this unit?
This info is straight from the panasonic website. The owners manual and more info for the unit can be found here.
Hope his helps!
Suitable SD Memory Cards
8 MB, 16 MB, 32 MB, 64 MB, 128 MB,
256 MB, 512 MB, 1 GB, 2 GB (Maximum)
Mar 16, 2009 | Panasonic DMR-ES46VS DVD Recorder/VCR
Palm Tungsten E2 doesn't recognize SD Card Card Info states that no card is inserted Card inserted with device on Card inserted with device off No recognition Kingston 4 GB
The problem is simply that the Tungsten E2 cannot read SD cards larger than 1 GB. However, there is a solution that will enable it to read larger cards. A driver called PowerSDHC is available from PalmPowerups.com that will enable the E2 to read cards of any size. I'm now running an 8 GB SDHC card on my E2!
Feb 17, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Dosen't reconize 8 GB SDHC memory card
Older model printers won't recognize high-density memory cards.
2 gb is probably the largest to be used in your printer.
Dec 26, 2008 | Epson Stylus RX500 All-In-One InkJet...
Philips DCP855/37 Portable DVD Player Logo
47 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
