Bose lifestyle 20 sound cuts off
My bose lifestyles 20 system powers on fine then the sound will cut off after about 5 minutes. If I turn the power off then back on the system will cut the sound off after about 5 to 10 seconds. If I turn the power off and let it set for about 15 to 20 minutes before powering it back on it will again stay on for about 5 minutes then cut the sound off. I think the system is overheating but not sure where to start (head unit or base amp) or what to do or check for. Any assistance in this matter would be appreciated. Thanks for any help.
  • Marc Wiggins
    Marc Wiggins May 11, 2010
    Disconnect all the speakers from the headend, turn it on and see how long it runs. Then connect one speaker at a time for 15 minutes each. Connect Right front spkr, let it run 15 min. if no problem, connect LF spkr and let it run...and so on...it'll either be the amp or a shorted spkr line. Good luck,
    Marc
  • Anonymous Apr 01, 2014
    Bose Lifestyle SA3 unit green light flashing and no sound
    Scholar:
  • 48 Answers
It sounds like the digital signalling processing chip has bomed out, (assuming it is the digital version, this can be verified by the 9 pin connector on the bassbox beside where the speakers are plugged in) perhaps it has recieved some un freindly electromagentic interference.
if this is so, i'm afraid there is no way you can fix it or reprogram the EEPROM (well of course there is but even if you had the correct equipment you need the program)
I would be supremely confident that BOSE could quiclik fix that for you with little difficulty, the neaserst dealer probably has the correct programming cabling and equipment.
if its not the digiatal version or even if it is, there is a second potential problem,
either the CD head unit or the powered bassbox is tripping out due to either circuit overheating or electrical fault,
in either case ? that is difficult to rectify, as the highest likely hood is the baords are covered in dust taht could be conducting static or a fault has developed.
the bassbox could be opened, but you might damage the cover (leave this as a last resort, especially if you havent done that before!) so bring a broken cover to the dealer will be a bit embarrasing ;-(
worse a broken cover will rattle when reinstalled and working again and will result in starnge sounds too.
honestly, seeing as i'm recommending taking to the delaer anywya, try aand bring cd unit and bassbox back to dealer a quick test by swopping modules will quickly eliminate or find the source of the problem, alternatively try doing the swop test with a similar unit around at your friends house !
hope this helps.
Posted on Dec 10, 2008
Tip
Bose LifeStyle 20 Manual Download
Download Bose Lifestyle 20 Audio System Manual
Would you like to review the features of the Bose Lifestyle 20 Audio System?
Have you lost your Bose Lifestyle 20 Audio System Owners Manual?
Would you like a digital, searchable, pdf version of the Bose Lifestyle 20 Audio System Users Guide?
Follow this link (& click FREE) to download a pdf version of the Bose Lifestyle 20 Audio System documentation.
I hope that helps.
___________________________________________
on Jul 03, 2010 | Audio Players & Recorders
Tip
Bose Lifestyle 20 Manual Download
I hope that helps.
on Jul 03, 2010 | Bose Lifestyle 20 System
Bose Lifestyle 235 system: setup button not working
Contact the authorised service center for Bose at your town.
May 02, 2012 | Bose Lifestyle 235 Theater System
Not good surround sound Is the bose lifestyle 5 support 5.1 surround sound?
The Bose Lifestyle 5 is not a 5.1 surround sound system. It is a 2.1 sound system, meaning it is stereo with a subwoofer/bass unit. Having two speakers that can be angled in different directions, the Bose Lifestyle 5 employs Bose direct/reflecting technology,providing greater audio presence. Still, it is definitely not a surround sound system.
Jan 24, 2010 | Bose LifeStyle 5 Series-III CD Shelf...
I am experiencing distortion on my bose lefestyle 38. I only notice when playing dvd's or hd channels that have 5.1 sound. Any ideas?
Completely power down the system, by first turning it off, then removing the power cord from the wall socket. Wait a minute or two. Then, reconnect the power, and turn on the system. This should clear up the problem.
For future reference, it is good to use a top-quality surge suppressor, at the power source, to protect your Bose Lifestyle sound system.
Dec 29, 2009 | Bose Lifestyle 35 System - black Theater...
BOSE LIFE STYLE SYSTEM SOUND (AUDIO) GOES QUITE FOR A SECOND
This was posted a while ago, so I'm sure it's probably been solved by now. For anyone with audio issues using this or any other Lifestyle system: If you experience audio problems (no audio, intermittent audio) from more than just 1 source (especially if it involves internal sources like DVDs or the radio) then just reset this by unplugging the power for about 30+ seconds from the bass module and the media center DC power. Check the audio input cable (multi-pin din going from the media center to the bass module) for bent pins.
If this doesn't solve the problem, you could try replacing the input cable, but those are usually pretty robust. You could call Bose at 800-367-4008 for tech support or to set up a repair if this fails.
Dec 14, 2008 | Bose Lifestyle 38 DVD Home Entertainment...
Bose surround sound system cuts off
Hi when you turn on check all your speakers work check connections make sure the wire has no stray strands touching the fault could be in the sub unit this is possible / or your speakers one or more could have gone short circuit due to exessive volume thats if you play loud. Had a party lately .Just joking .Regards kirk
Dec 10, 2008 | Bose (321GS) System
Bose Lifestyle 5
Hi it could be R428 open circuit replace with a 330 ohm resistor
Dave
Oct 12, 2008 | Bose LifeStyle 5 Series-III CD Shelf...
Bose Lifestyle 38
No reset button. Simply unplug the power cord in the rear, wait 20 seconds and power back up.
Dec 22, 2007 | Bose Lifestyle 38 System
383 people viewed this question
 Grubhead
Grubhead
