Question about Whirlpool Dryers
How to replace fuse in dryer mod. #LER8648PQ1 Ser.#MT3806009
  • 706 Answers
Hello ringertfr,
Please use the following link to show how to get at the thermal fuse ( item #7 ..assuming that is what you are asking). The exploded view shows the mounting location and part number too.
Make sure you unplug the dryer before perfoming any service.
Feel free to contact me if I can assist you any further.
Regards,
Rick
Posted on Dec 02, 2008
Dryer will not heat
If it is electric, then the heating element has an open circuit. You will need to replace it.
Jan 14, 2016 | GE Dryers
Kenmore mod:11061082000 ser:mk3601729
Check for continuity at the heating element, hi limit thermostat, thermister, thermal fuse and the cutoff thermostat.
Nov 05, 2012 | Dryers
Motor wouldn't start replaced the motor and it still won't start?
Did you replace the thermal limiter fuse inside the cabinet near the motor? It is likely burned out. Contact the repairclinic.com for the part or Sears.
Jan 19, 2012 | Whirlpool Dryers
Hi, I have a Roper electric dryer (mod RED4340SQ1, SER MU2130244, Type 0433-ELE-2406026) that heats up when drying, yet does not heat up enough to dry the clothing. All other functions seem to work. ...
repairs should be performed by an authorized repair person. the heating element coil may be broken and grounding itself the the module housing. if so replace the heating element.
Jun 02, 2017 | Roper REX4634KQ Electric Dryer
Kenmore Electric Dryer , 700 series, MOD 64722400 , SER MR4136705 , Type DWJR-ELE-2406028-FM64 . Dryer is not heating, checked fuse it's fine, cleaned every nook and cranny with a swifter duster and...
Hi.
Be sure that you have checked the thermal fuse. The part is tested using a multimeter set on Ohms (impedance). Remove the fuse from dryer and read impedance touching the fuse contacts with the two multimeter probes. If impedance is Ohm infinity (open), then the fuse is bad.
If the fuse is OK because tested good or replaced, then the problem is either one of the three thermostats located in the heating group, or the heating element. All parts are tested similarly to what described for the thermal fuse. If any of the parts read open (infinity), then the part is faulty. After finding the defective part remove all the lint from heating assembly and air duct. The lint causes overheating and blows thermostats, fuse or element.
Regards.
Ginko
Jul 14, 2011 | Kenmore 64722 Electric Dryer
My dryer does not tuen off on its own anymore. how can I fix it?
More than likely the timer has gone out. It has a small electric(not replaceable) motor in the timer that advances the time. If the appliance works when you manually advance it to different cycles
thats probably the problem.
Leo Ponder
imufo2@sbcglobal.net
Jul 25, 2010 | Maytag MED5707TQ Electric Dryer
Whirpool Dryer Heating and timer issue
YOU NEED CHEK:
1-thermal fuse.
2-heater element.
3-hi-limit switch.
4-temp sw.
5- electronic control.
Oct 05, 2009 | Dryers
Dryer will not heat. Mod: 11066652500 Ser: MS2302035
If your dryer is electric, it's most likely a thermal cut-off or the heating element. if it's gas, it's probably the thermal fuse. i do lots of these each week. 90% of the time it's what i just explained. good luck :)
Jul 03, 2009 | Kenmore Dryers
Electric dryer drum turns, but getting no heat from coil.
hi todd not sure of reading you should get please use this site thank you for useing fixya please rate me http://www.partstap.com/
Feb 25, 2009 | Dryers
Dryers Logo
144 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
