Question about Samsung HL-R4266W 42" HDTV-Ready Projection Television
42 Inch HLR4266wx/xaa DLP - Samsung - Screen jumpy and fuzzy
Screen started to go Jumpy and fuzzy as if you could see the lines being ran accross the screen. Jumbled up like distorted digital signal. TV stopped turning on fully. LAMP led on power button was blinking - was not getting audible that tv was turning on. Then would shut off and standby/temp red LED would light.
Turned off TV for 12 hours and it came back on - gave audible and slowly all of the above happened again in about 2 minutes time. Unplugged.
Help.
  • jonnytowers Jan 02, 2009
    I have close to the same problem. Check your "Picture in picture" is the little picture clear? Mine is, as is my TV Guide option. I have a 80% hit ratio by quickly unplugging and then re-plugging in the TV when it is on and "fuzzy".
    Sure would like to know why it's doing this??!!
    Jonny
  • TheScreenGuy May 11, 2010
    Check the other source Inputs. Does the DVD input also act this way? Use the Menu key on your remote. Does your On-Screen Menu also appear "fuzzy"?
SOURCE: No picture on my Samsung HL-P4667W
The lamp probably needs to be replaced, http://www.samsung.com/us/support/popup/howToGuidePopup.do?howto_guide_seq=45
Posted on Feb 09, 2008
Axle80
  • 73 Answers
SOURCE: samsung DLP TV won't turn on
This sounds to me like one of two possibilities. First, check your ballast. If you're going through bulbs faster than you think you ought to be, you may have a ballast that is overloading. Its the 3" x 8" circuit board that connects directly to the bulb. They are plentiful and often cheap. Thats what I'd try first. If that doesnt' do it, I would invest in a new power supply board. That the board that the tv power cable hooks directly in to. This should give you a start, Comment back if you still need further help. Good luck.
Posted on Jun 06, 2009
  • 197 Answers
SOURCE: i have a samsung hl-s6187wx/xaa standby light
bad color wheel
Posted on Jun 07, 2009
  • 3 Answers
SOURCE: WILL NOT POWER ON, STANDBY, LED, TIMER LIGHTS ARE BLINKING.
Check the capacitors on the power supply first. If any have domed tops or signs of leakage, replace them. I had two go bad on mine. Call electronics parts supply stores first as these are not your average capacitors.
Posted on Aug 18, 2009
sharmamickey
  • 6 Answers
SOURCE: jumpy picture on tv from
YOU HAVE PUT ANY MAGNETIC PRODUCT NEAR UR TV.CHANGE IT'S POSITION
Posted on Sep 01, 2009
I have a Samsung Hlr5667wax/xaa DLP TV and the screen has gone green/green plaid pattern.
when the color wheel stops the picture will be all over the place. and you will have lines when it starts to fail as its not going fast enough for the picture. wining sound is it wearing out.
May 29, 2017 | Samsung Hlr5667w 56-inch Dlp Hd Tv
The bottom of my compaq screen is fuzzy
It would be easy to advice something if you can kindly post an image. But for the time being it seems like a problem with:
1) Either your graphics driver
2) Falsified Screen
3) Bad Setting of O/S.
Oct 31, 2012 | Compaq Computers & Internet
Samsung NP-NC10 Screen all lines and 'jumpy'
got the same problem before with my compaq laptop. i replaced the screen with a new one.
Dec 03, 2010 | Samsung NC10-14GW Notebook
Tv shut off and wont come back on
fuses first, than powersupply, next lamp inverter.
Dec 04, 2008 | Televison & Video
Screen gets horizontal lines and jumpy screen.
Your problem is capacitors CP204 and CP205 by the 9 volt regulator on the main board. Cp204 is a 47 microfard @ 50 volt and the other is 100 microfard@ 16 volts
Nov 13, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Philips x57 laptop. screen has suddenly went fuzzy. distorted colour and images jumpy.
Have you set the right screen resolution. Check screen resolution & color quality setting in display properties.
Aug 17, 2008 | Computers & Internet
Half fuzzy screen
you have too get a wet tissue and put soap on it if you do that it will get fixed.
- Psp master
Dec 24, 2007 | Sony PlayStation Portable (PSP) Console
Fuzzy screen on a 41 in. Samsung DLP hdtv
use the "Perfect Focus" feature on my TV and let me know what happens
Dec 15, 2007 | Samsung HCN4226W 42" Rear Projection...
Open Questions:
Samsung HL-R4266W 42" HDTV-Ready Projection Television Logo
1,099 people viewed this question
Henry  Thomas
Henry Thomas
