Question about JVC TH-M505 System
Black and white picture on the JVC TH-505
My sound works fine but everything is in Black and White. One day is was fine and the next time I used it everything was black and white. I have only had it for about 1.5 yrs. Any suggestions. Thanks.
  • leahja Dec 26, 2007
    TV is working fine. Connected the JVC system and the dvd's are playing in black and white but excellent picture quality and sound. I have changed the VPF settings as far as is possible, there is no colour option available. Does anyone know if there are any actual colour settings that can be changed? We have tried new connections, new scarts etc. and nothing seems to help it. Would really appreciate any help. Thanks Carla.
If you hold the VFP button while a movie is on, you will get a small box on the corner that shows your color. My default color also turned black and white. I just moved over to a user1 color setting (push the right arrow on your remote), and it allows to the change the colors. You might be able to put the colors to come out through here. Hope this helps.
Posted on Aug 03, 2007
Great it worked
Posted on Mar 05, 2009
Yes you should go to VFP button but not only move into user 1 or 2 but playing enter such you put on 0: gamma, brightness, contrast, saturation, tint and sharpness, then you adjust at your preference!!!! It worked for me after 3 hour try to fix it, beginning with the below advice.
Posted on Oct 28, 2007
    Genius:
  • 1,074 Answers
Check your connection if you had tampered with it before it turn black and white.if the connections is okay then the tv is having problem in the color circuit take it to a tech for repairs.goodluck.
Posted on Apr 02, 2007
I had this problem when I first got the JVC TH-505 and the picture was black and white. It turned out that I had the cables hooked up improperly.
I was trying to connect my ps2 with Panasonic vieara tv but picther is in black and white and no sound
A black and white picture suggests you are trying to use a composite video input but the TV may be NTSC format while your game is PAL, or the other way round. Use a game with the correct format or use the separate RED, GREEN & BLUE inputs (may require a different type of lead).
Jun 01, 2016 | Panasonic Viera TH-42PX80U Plasma TV
Why wont play color
TH-M505 can display in black in white if connected iimproperly using COMPONENT connections or if cables have gone bad. Try replacing component or changing connection to COMPOSITE. Does it play in black in white using COMPOSITE?
Jul 26, 2014 | JVC TH-M505 System
Panasonic TH-42PD25 The picture is black with
Make sure if your using the video input jacks, that the yellow is plugged into Video 1 and the same with the audio.Red & White. If your using Component, they are color coded- Red Blue & Green along with the Audio In -Red & White. It sounds like you have the video in the wrong jack.
Oct 28, 2009 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
Color Adjustment Problems - Reception in Black and White
satelliteand cable TV is only comes in black and white.
this a HTML type plug or a coaxial
select menu and source
very weird... should default to colour
if no luck try plugging in a desk top digital box tune using that
TH-42PX20 TH-50PX20 Operating Instructions High Definition Plasma ...
ftp://ftp.panasonic.com/television/om/th-42px20_en_om.pdf
Apr 24, 2017 | Panasonic VIERA TH-65PV500 65 in. Plasma...
BLACK AND WHITE DVDS ALL MY DVDS PLAY IN BLACK AND WHITE.THIS JUST HAPPENED ONE DAY, ANY HELP?
If you're using component video cables from the DVD player to the receiver, remove and reconnect them.
May 04, 2009 | JVC TH-M303 System
TROUBLE SHOOTING JVC DVD PLAYER DOES NOT SHOW COLOR PICTURE
Press and hole Scan Mode button for 2 seconds, Y/C will show in front display, use > to change to RGB then press OK.
Feb 25, 2009 | JVC TH-S11 Theater System
Don't worry you dont have to buy a new camera :) When you press the menu button there should be an options menu. look around for the "effects" options or something along those lines. There is a black and white mode on the camera, my guess is that it turned on somehow. All you gotta do is turn it off.
I hope that this helps, feel free to ask more questions. I have a jvc video camera just like this one, so if need be i can just look at mine!
Jan 15, 2008 | JVC GR-AX940 Camcorder
No color picture
Have you looked at the menu to see if it is an international system? If you have more picture posibilities than NTSC you may need to make that selection. Terry
Sep 03, 2007 | JVC TH-C50 System
Black and white picture........
TAKEN FROM ANOTHER THREAD------
take the disk out. on the remote slide the bottom down. press and hold down the scan button 2 to 3 sces,then press right on the directional pad.your options is displayed on the machine
with disk i machine repeat above for brightness options
hope this is useful
bigdaveyl@hotmail.co.uk
Thank u big davey :P
Oct 01, 2006 | JVC TH-S3 System
JVC TH-M505 System Logo
2,212 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
