Question about Vehicle Parts & Accessories
Mitsubishi shogun key fob not working
Recently the key fob on my 2004 model shogun stopped working. I replaced the battery, but it still doesn't work. Do I have to key in a new code? If so, what is it and how do I do it?
blueextc3221
  • 15935 Answers
SOURCE: remote key fob will not work-battery replaced
VW/AUDI/SEAT/SKODA
Remote Control Programming (1997 ON)
Procedure
1. Switch Ignition ON and leave the key in the ignition.
2. Mechanically lock the vehicle using the Drivers door using a second
key.
3. Using the remote control press the Unlock button once, and the horn
will sound once.
4. Wait 6 seconds and press the unlock button once to activate the coding
procedure. The remote control will now be programmed.
NOTE : When performing programming on additional remotes the procedure
is the same, except you press the unlock button 2, 3 or 4 times for the
different remote.
For example : If programming 2 remotes press the unlock button twice with
a 1 second interval between each press, repeat for 3 and 4 remotes.
5. Switch Ignition OFF.
6. Remove key from ignition and check for operation.
7. The coding procedure can be repeated up to 4 times for additional remotes.
8. The ignition must be switched OFF between programming each remote
control.
Remote Control Erasing (1997 ON)
Procedure
key.
3. Press the remote control unlock button 5 times in 1 second intervals.
A short horn will sound.
4. Wait 6 seconds and press the unlock button once to activate memory
erase.
5. Switch ignition OFF, all remotes are now erased.
Posted on Dec 24, 2008
  • 9 Answers
SOURCE: key fob not working after changng battery
Bring it to a "Batteries Plus" type store; they can repair the fob if it is ony a broken battery clip. They did it for me for free! IF it is not the fob, then bring it to a dealer??
Posted on Jul 11, 2009
  • 166 Answers
SOURCE: key fob lights up but doesn't work even with a new battery
I'm more familiar with Range Rovers and Saab's when it comes to key fobs but if you changed the battery you have to re-program the key fob. If you do not have an owner's manual that can take you through the steps you might want to try: push and hold the lock button on the key fob, put it in the driver's side door and turn to lock. With the button still depressed turn back to open, remove the key and release the button. If this doesn't work check any and all fuses associated with your system and last but not least you could take it to a dealer. Good luck!
Posted on Aug 25, 2009
Testimonial: "thanks ill try what you've suggested"
SOURCE: renault key fob doesnt work
Hi.
I have a clio II, 2001, i have the same problem and i fixed it.
Don't know if will work for you but here it goes:
1 - no key in ingnition
2 - press the unlock button in console off the car for about 10 seconds(dont let go)
3 - it should work the central doors one time and then 2 times( hear)
4 - press the remote a few times until it starts working
It worked for me hope the same for you.
Please tell me if it worked and pass the message.
Good luck
Posted on Sep 15, 2009
SOURCE: Have 56 plate seat leon 1.6 .the alarm keeps going
I have Seat Leon 07 and my alarm has gone off loads of times in the last 18 months. The first time it was the window motor that went - went in under warranty and part replaced - it's now back in the garage getting the same problem fixed again. the neighbours are fed up with the alram going all times of the day and night. Hope this helps
Linda
Posted on Sep 18, 2009
My second hand 2004 Mitsubishi Outlander immobiliser fob has stopped working and i can no longer start my engine. I only have one immobiliser fob and one non-remote/buttonless engine key.
The immobiliser works with a chip in the fob. This is a signalling device which, via a pick-up situated around the ignition lock, sends the signal to the engine computor which the allows the engine to be started.
Jan 08, 2017 | 2004 Mitsubishi Outlander
Is there a way to reset keyless entry for 04 endeavor?
Search Results
    2004 Mitsubishi Endeavor Key Fob Remote Programming ...
    blog.keylessentryremotefob.com/.../04/2004-mitsubishi-endeavor-key-fo...
    Apr 25, 2013 - 2004 Mitsubishi Endeavor Key Fob Remote Programming Instructions ... you might have visit us at Keylessentryremotefob.com You can also ...
    Mitsubishi - Free Keyless Remote Fob Entry programming .
    How To Replace Mitsubishi Endeavor Key Fob Battery 2004 ...
    ? 2:04
    www.youtube.com/watch?v=yeQRdre7O0Q
    Oct 31, 2014 - Uploaded by Keyless Entry Remote Inc
    ... will show you How To Replace Mitsubishi Endeavor Key Fob Battery 2004 2005 To Order This Remote ...
Nov 01, 2015 | Cars & Trucks
I REPLACED BATTERY IN KEY FOB FOR 2009 MITSUBISHI LANCER AND NOW IT WON'T WORK
hey guys. I own a 2013 lancer ES. My remote key fob stopped working because the battery ran out. I replaced the battery and it doesn`t lock and unlock the doors anymore. The fob because its lights come on and a locksmith checked that and it`s definitely working. I checked the WEB and youtube for reprogramming but all the tutorials were for 05-12 models. I also did the manual instructions but nothing happened. The dealership told me they charge me 220 dollars for that. I only have one fob, it is the only i got from the previous owner. Would you plz help me? thanks
Jun 10, 2012 | Mitsubishi Lancer Cars & Trucks
MY KEY DO NOT LOCK DOORS AND SET ALARM
I would try disconnecting the battery for five minutes like resetting a computer. Replace the battery in key fob. Body computer does strange things with lights hope it doesn't need to be replaced about 350 dollars if you have it replaced and any thing else doesn't work after they replace it tell them. I had two of them replaced for me because they are rebuilt
Jan 11, 2012 | 2004 Chrysler Pacifica
Bought key fob but don't know how to program them
recently the key fob on my 2004 mitsubishi endeavor stopped working after I replaced the vehicle battery. How do you program the key fob to start the vehicle?
Jun 11, 2010 | 2004 Mitsubishi Endeavor
How do you re-link the key fob to the car after
Try this,,turn the key on ,wait 10 minutes,then turn the key off,then right back on,do this three times,a total of 30 minutes,this should reset the key fob,if this is the problem.
Apr 17, 2010 | 2009 Mitsubishi Outlander
Key fob connection
Some ebay sellers sometimes offer spare casings, often taken from scrapped vehicles. Or try contacting the wrecking yards yourself.
Mitsubishi are correct in stating that fob casings are not supplied as spare parts though, the reasoning is that after around six years the fob buttons are usually almost worn out as well so it makes sense to replace the entire fob. Afterwards, the vehicle and all fobs need to go to Mitsubishi or to an automotive locksmith to be programmed as a matching set. Mitsubishi aren't alone in this, many fobs need replacing at around six years old unless the vehicle is used less often than normal.
Mar 12, 2010 | Vehicle Parts & Accessories
Key fob problem
Not to be a smart azz but have you replaced the battery yet in the fob?
If so then it could be a bad fob, reciever, power issue, etc...
Apr 02, 2009 | 2004 Volkswagen GTI
Programming Key Fob
how to reset key fob after changing battery on a mitsubishi carisma
Jan 02, 2009 | 2002 Mitsubishi Montero Sport
Vehicle Parts & Accessories Logo
1,028 people viewed this question
Top Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
