Question about Nintendo Wii Console
Getting on line
Passes connection test when trying to get on line asks for DNS # what is Dns # ?
    Scholar:
  • 125 Answers
If you are connecting through your wireless router, you should just let it auto obtain an ip address and auto obtain dns. Is DHCP on in your wireless router?
DNS is the ip address of a server that resolves names like www.something into an ip address. Your ISP usually gives you these numbers.
dns=domain name system
Posted on Dec 02, 2008
I have samsung Wave 525, In home Wifi network I get DNS Failed. I have tried lot of options but never succeeded. send me the best options.
255.255.255.0 is the default dns
or else just give the default gate way ip in here too
For example your default gateway is 120.120.120.2 then try the dns as the same 120.120.120.2
Jun 13, 2011 | Computers & Internet
Problem with the Sony Playstation 3 (PS3) Console PS3 says DNS error (80710102) when i try to connect to the internet with a wired connection
Try changing your DNS settings on the PS3 or on the router
Changing the DNS on your router: Go to 192.168.1.1 Default password is: admin Static DNS1: 208.67.222.222 Static DNS2: 208.67.220.220
Those DNS setting are from OpenDNS
After doing this, reconnect your PS3 to the router and set it to Automatically adjust the settings. Once you have reconnected, check if you are still having the DNS problem.
If you are still experiencing the problem, try changing the DNS directly from the PS3 Go to Internet Connection Settings and set everything to Auto except DNS When asked if you should set the DNS automatically, choose "Manual" Input the same DNS settings: Static DNS1: 208.67.222.222 Static DNS2: 208.67.220.220
Apr 09, 2011 | Sony Playstation 3 (PS3) Console
Connected to access point but internet cannot be found
check the DNS settings that your router is passing.
some routers dont always talk the same language (they are suppose too thought) with other manfactures hardware. it might not be passing the DNS info to the computer.
get the DNS from the router (http://192.168.1.1) then place that into windows. network connections => device name => properties => TCP/IP v4 => bottom box where it says DNS.
if the router doesnt have DNS settings to give plug the cables in and reset the router and modem.
Jun 11, 2010 | Linksys (WMP54GS) 802.11g/b Wireless...
Network diagnostics = failed DNSServerSearchOrder
Click Start
Click Run
Type CMD and press ENTER
Type IPCONFIG /ALL and press ENTER.
Look for lines of output like:
Ethernet adapter Local Area Connection:
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
DHCP Server . . . . . . . . . . . : 364.259.160.040
DNS Servers . . . . . . . . . . . : 364.259.160.13, 364.259.160.15
especially the "DNS Servers" line.
Call the "Support Desk" of your Internet Service Provider, if that "DNS Servers" line is blank -- or even if it is non-blank -- ask the ISP what the values *SHOULD* be -- just in case your computer has been "hijacked" to point to "rogue" DNS-servers.
Nov 18, 2009 | Microsoft Windows XP Home Edition
Playstation 3
the DNS should be informed by your internet service, but most times the system recognises the DNS by looking for it on the router .
it's happening to you because the IP is got from the router (and it'll be always correct), but the DNS ,that allows you to connect to your internet service must not be correct .
try using the default automatic settings when asked, the ps3 system will try to find the DNS and everything else necessary for your internet connection .
Jul 28, 2009 | Sony Playstation 3 (PS3) Console
Connecting PSP to wifi
Change the primary DNS of your PSP to 4.2.2.1 and secondary dns to 4.2.2.2
Apr 25, 2009 | Linksys WRH54G Wireless Router
Connecting to the internet.
Ask your ISP for the correct DNS address....sodeep
Mar 22, 2009 | Sony PlayStation® 3 (80GB) Console
Signing in on live
You need to go to xbox.com and sign up for xbox live before you can sign in.
Jul 20, 2008 | Microsoft Xbox 360 Console
Dns
Try calling XBOX customer support. They will know exactly how to fix your problem. Their number is 1-800-4MY-XBOX. (1-800-469-9269). This is the best way to fix this problem because the technicians are certified and they know what to do.
Hope this helps,
C13295
Mar 06, 2008 | Microsoft Xbox 360 Console
CAN"T SIGN IN TO XBOX LIVE
You might not have been banned. Not being able to connect to the DNS or having it fail can be caused by a few things:
The DNS address serves couldn't be reached
The info on the DNS server couldn't be snagged from your ISP or the DHCP server
The DNS values in the dashboard are wrong.
I don't want to come off like I am insulting your intelligence, but check your internet connection to make sure you have the ability to connect. I'm sure it is all in proper order. So the next thing you need to do is check to see if you IP is set and passes all the tests. If it isn't then you can click the more link on the test page to follow the directions on how to fix it.
You may also want to check out if you are using a XBOX live compatible ISP. Click on Learn More to see if you are using the right ISP or to adjust your settings. You can also check out the connectivity wizard to find out if there are some other issues revolving around this.
Still running into problems!?!?!? try running the modem directly into your XBOX. This has helped me in a few time of need.
Here are some helpful links on what you can do when your DNS fails:
http://xbox360help.blogspot.com/2007/03/dns-failed-on-xbox-360-live-test.html
And a link to a forum discussion regarding failed DNS
http://forum.teamxbox.com/archive/index.php/t-411837.html
Mar 04, 2008 | Microsoft Xbox 360 Console
Nintendo Wii Console Logo
64 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
