Question about Linksys Wireless-G Broadband Router
Trouble with installation disk
I am using the installation disk for my Linksys wrt54g v.3 and it cannot detect my pc is online. Any solutions?
  • Linksys Master
  • 4,338 Answers
Router setup
If you are using the cd that comes with the router, that is the problem. You do not have to use the cd. Go to the control panel and un-install the program that the cd installed. then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Dec 01, 2008
I lost the startup disk for my wrt54g router. How can I set up my router now?
Hello there
If you can get online with a computer that you want to use download the setup files from the linksys website onto the computer and then after this is completed you can install it from there
Just make sure you have the exact router model numbers there are a lot to choose from ok?
Best regards Mike
Sep 29, 2010 | Linksys Wireless-G WRT54G Router
I'm having trouble accessing my Quickbooks Online through my router model WRT54G
That is common problem, try to reboot your router as a temporarily solution. This router has weak stability when network is overloaded, check for settings related to traffic filtering and turn them off, any redirects, any firewall rules. Or make clean reset for the router and check will it work on basic WPA encryption setup only.
Jun 02, 2010 | Linksys Wireless-G WRT54G Router
Having trouble connecting to the internet
Hi, the problem you have described has many solutions..lets try
do you have any hard wired pc directly connected to your router..are you able to on line in that pc..if not connect your modem directly to your pc and check if you are online..if yes the you router configurations has to checked..and make sure your router is updted with the latest firmware..reconfig your router and that will fix your problem
Oct 19, 2009 | Linksys Wireless-G WRT54G Router
Cannot get online with Wireless G WRT54G router. Can get online by pressing Cisco Systems button but only temporarily.
Do U see the router signal on the wireless network connection search?
Sometimes the linksys systems cd does not want to work on some pc's. try using the control panel - add/remove programs and uninstall all programs for the linksys. Then goto the control panel - system - hardware and uninstall the linksys card. Leave the actual card installed and reboot. After it detects your card use the linksys cd to load only the driver.
In the properties of the wireless connection, let windows manage it.
The above is based upon the factory defaults of the router. Any keys to access the router would have to be used on the pc.
Jun 02, 2008 | Computers & Internet
My computer deleted my router when i got it fixed and i dont have the disk to re-install?
The setup wizard installer for a LinkSys WRT54G may be downloaded from here. Please select your version number.
Good luck and kind regards.
Feb 03, 2008 | Linksys WRT54G Wireless-G Broadband Router...
Problems with IP address
Possible three (3) solutions:
1. Purchase and install a PCI LAN card (NIC) inside your "old tower". Should not be that difficult using any available PCI slot. Most would be auto detect/install by Windows (XP) or should come with a driver CD;
2. Use a USB to Ethernet adapter/converter; and/or
3. Use static IP address for the tower Same IP add (+1 on the last digit, same Subnet Mask, Default Gateway and DNS (if any). Should you need additional information on this method you need to post back details of your modem (brand/model, normally in a sticker underneath) so we can determine if it will allow simultaneous connection on USB & LAN.
Hope this be of help/idea. Pls post back should you need additional information.
Jan 24, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G Broadband Router Logo
60 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
