Designjet 5500 default admin login id and password
  • Anonymous Apr 07, 2009
    cannot login password not in the manual
4 Suggested Answers
SOURCE: Konica Minolta Admin Password
Try 12345678.  That worked for me for my Bizhub C250.
Posted on Apr 02, 2009
SOURCE: C5500 default admin login
I got in by using "admin" as the user and the last 6 characters of the MAC address as the password...with CAP lock on.
Posted on Oct 06, 2009
  • 240 Answers
SOURCE: default admin password?
Is the installation software being installed on an account with administrator privileges? If not, log off and log back on with an account that has admin privileges. If your account has admin privileges, and the install asks for the password, and you know you have not set such a password, pressing the enter key may skip this problem.
Posted on Dec 03, 2009
I donot remambar password
Most default user credentials are - admin/admin.
If you are unable to log in, then most routers come with a reset key. For Zyxel NGB-417N router, press the reset key with a pin. hold on the pin till the device reboots.
Login with the default user id and password and setup the router.
Sep 30, 2013 | Zyxel NBG-417N Wireless Router
I 'm trying to get my wifi..it wont work, i called comcast and they said to reset it and the password. i dont remember any login or password...help
The default password for Linksys routers is admin the user is left blank
some routers have slightly different than this user id admin and password also admin the last possibility is user id admin and password is just password
good luck!
Sep 16, 2011 | Linksys Wireless-G WRT54G Router
Need to reset, but don't know ID or password, no idea how to get into it. We got it from Verizon when they hooked up our 2xT1, but they refuse to manage the router. HELP!
That model isn't familiar to me, but try default login ID "admin" and Password "setup". If that doesn't work, the following procedure might allow you to log on and delete the config. That will delete everything, though, so make sure you read out all the configuration info before you reset.
  1. Connect the Console cable to the Console port on the Secure Router
  2. Connect the other end of the DB-9 Console cable to the COM-1 port on the workstation
  3. Start the Hyper terminal (VT-100 or equivalent) application on PC-1
  4. Configure the COM1 port for 9600 bps, 8 data bits, 1 stop bit, no parity, and XON/XOFF
  5. Login SR with the factory default login ID "admin" and Password "setup"
You can also reset those routers by deleting the config file like this:
  1. Login as above
  2. type "SR > clear cfg_file system.cfg"
  3. message will read "removing contents of '/flash1/system.cfg' ...done.
  4. now type SR > reboot
Jan 13, 2011 | Nortel Networks SR1004 4P ACTIVE T1 ...
Default login and password
reset the router buy holding the rest button down for 10 seconds once all the lights start to blink leave it for 20 seconds or more so the lights get stable and then use the default user id admin and password admin
Don t forget to say thanks
admin
Aug 18, 2010 | Dell Wireless 2350 Router
Login for d-link 524
you can try some of these combinations:-
Username Password
admin (blank)
user user
user (blank)
(blank) private
Please come back to vote, it would be a great appreciation for me and boost my determination to help so that I can keep on helping.
Hope it works for u
All The Best!!!
Zooless
May 15, 2010 | D-Link DI 514 Wireless Router (DI-514)
I have a linsky wireless G 2.4 Ghz 54Mbps (model WRT 54G) I have the cd, but I do not have the password. I am not sure if this is the reason, I can't set up my network. How do I get another password
Linksys WL router always has default password "admin" you will have to reset router to factory defaults by plugging Pin in to Tiny Hole on Router back side for 5 seconds. and then login by default ID "admin" and password "admin" to configure router again. [Remove Inverted Commms from User name password while entering
Mar 09, 2010 | Linksys Wireless-G Broadband Router
I forget my sonicwall admin password how will reset this password
If the SonicWALL's admin password is lost, there is no backdoor or other mechanism to bypass the administrator login. Please note that prefs files do not contain the admin name and password. So if you reset the firmware and import a current prefs file, you can gain access using the default login credentials ('admin' & 'password'). Without a current prefs file, you must reset the firmware and configure from scratch.
For models running SonicOS (Enhanced or Standard), you can reboot to factory defaults. This resets all settings including the admin name, password and LAN IP address. Import the current prefs file. The configuration is restored and use the defaults 'admin' and 'password' to login.
For models running Firmware 6.X, you must reset the firmware (wipe and upload using the reset procedure). Import the current prefs file. The configuration is restored and use the defaults 'admin' and 'password' to login. The 'Reset to Factory Defaults' button does not reset the admin name, password or LAN IP address for these models
Feb 03, 2010 | SonicWALL PRO 1260 SonicOS Enhanced...
How is login and password in router wg 414b-i
The by default Login ID and Password is (admin , admin).
If it does not work please check on user manual given by the manufactures. Or could be the case the some budy manually changed the router details.
Regards,
Raman
Sep 07, 2009 | LanReady (WG414B-I) Wireless Router
Forgot my passwordfor the router
login with user/user open password.html
http://xx.xxx.xx.xxx/password.html
where xx.xxx.xx.xxx is your ip
view source and there's your password
May 16, 2009 | Computers & Internet
I am trying to set up zoom x6 modem/router to my computer and i cant find the vci/vpi and i dont know the the encapsulation for my isp. anyone know where i can find this?
Sir,
U can login ur ISP u can find. go to browser type your IP address for ex. http://192.152.185.1 and press enter. it ask user and password. u can login ur user id and password of your internet provider. u can find there. default user id and password is admin and admin
Thanks Good Luck
Appreciate to rate as "Fixya"
May 04, 2009 | Zoom X6 (5590) DSL Modem (55900003)
1,814 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
