Question about HP DesignJet 500ps (42 in.) InkJet Printer
Designjet 5500 admin default passsword
Just did a front panel reset of admin password and now need to login via the gui to config but do not know the lonin id or password
SOURCE: C5500 default admin login
I got in by using "admin" as the user and the last 6 characters of the MAC address as the password...with CAP lock on.
Posted on Oct 06, 2009
  • 123 Answers
SOURCE: after print heads alignment its getting error 1004
The trailing cable is probably runing the printhead. Try replacing the printhead and trailing cable together. Parts available at: http://www.lpscomputer.com/c-622-designjet-5000-5500.aspx
Posted on Apr 15, 2010
SOURCE: system error 1290 on Designjet 9000s
System error 1290 on Designjet 9000s
Posted on Jun 04, 2010
apkb29
  • 174 Answers
SOURCE: how can i install hp designjet 5500 PS on my com
You are doing some mistake.
All peripherals will attach directly to the main server or main system.
Then from the main system you attach the network switch and share the peripherals with other
system.
you connect the printer, plotter, scanner etc to your computer directly through the aproprite cable /
port.
Posted on Apr 15, 2011
Forgot login password
Default User and Password on Everfocus is usually
Admin
Admin
Nevertheless, you should contact your local distributor, and after providing the product serial number, they can generate a reset user and password, that shall be used only once, and then, you must enter a new user/password combo.
Nov 16, 2012 | EverFocus ECOR264-9X1/2T ECOR264 Series 9...
Forgot password...I know username
What username do you know? Is it for the login for the GUI when you type the 192.168.1.1? There is no way you can retrieve the password you had set if you changed it before. The only way to access your router GUI again is to hard reset the router so that it will go back to default as admin for username and password is admin as well. The problem is all the settings that you saved before like port forwarding, NAT configuration and wireless setting will go back to default and you will need to reconfigure it back again.
Aug 27, 2011 | Linksys Wireless-G WRT54G Router
How to find ip address in hp 5500
To locate the IP address with the HP Designjet 5500, follow these steps below:
Press the Down Arrow keys on the front panel until the Setup Menu is displayed. Press ENTER. Go to the Utilities menu and select Test Prints.Press ENTER. For the HP Designjet 5000 series, select Service Config. Press ENTER. For the HP Designjet 5500 series, select Network-card Config. Press ENTER
Feb 12, 2011 | HP Color LaserJet 5500 Printer
How do i start up my labtop without using a cable to access the internet
Login to the default router config page from your desktop pc. This is usually plugged straight into the router via a network cable. Go to http://192.168.1.1 in w web browser. Default login is usally "Admin/Admin" or "Admin/Password" keep trying different combos.
You may also need to press the "Reset" button on the back of the router.
Nov 25, 2009 | NetGear RangeMax NEXT WNR834B Wireless...
Set up password on blitzz bwa711 router
Nov 25, 2009 | Blitzz Technology BWA711 Router...
I forgot password of my linksys rv042 vpn router how can i recover it without resting the router becoz they have a some special configuration on this. thanks gil
You may may have no choice but to "Reset" the router. The button is on the back of it. Just press it and hold it
Nov 25, 2009 | Linksys RV042 VPN Router
How can i change my linksis wifi password
access the GUI if it still on the default settings otherwise press the reset button at the back
Sep 17, 2009 | Linksys Wireless-G WRT54G Router
Need passphrase from D-Link router DI-524
1. if the default login never been modified b4, u can hook a network cable to the router, type "192.168.0.1" to enter the router config. Once inside, u can edit the password or disable it.
*U may prompt for username (admin) and passsword(empty).
2. If the default login has been modified and u r not able to enter the router config, u can just reset the router by inserting a pin to the small hole to get back the factory default settings. Then u can perform above step again to reconfigure your wireless router.
Mar 13, 2009 | D-Link DI-524 High Speed 2.4GHz (802.11g)...
Password block
if you dont know the password than last option is to reset the unit to company default and than you can login with admin and password admin. To reset it to company default there is reset button behind it so press it by pen point for 5 to 10 secs. So this my resolve your problem
Jan 29, 2009 | Linksys Wireless-G Broadband Router
I need to recover a WEP key on a Linksys WRT150N Router, I already tryed getting into the http://192.168.1.1. thing, wouldn't let me in with the pass. admin, Help??
Hi Commewe
You will need to get the crrect password to get in to the web enabled setup. If you don't have the password any more you will have to reset it back to factory default. This is done by pressing the reset button at the back covered with a red plastic tab. Move the tab out of the way and press (with a pen) and hold the reset button in for +/- 20 secconds. You will now be able to login with user=admin and password=admin.
Regards
Go-Tech
Dec 18, 2008 | Linksys Wireless-G WRT54GS Router...
HP DesignJet 500ps (42 in.) InkJet Printer Logo
632 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
