Question about Sony CFD-606 Boombox
Speaker making a buzzing noise
The left speaker occasionally makes a buzzing noise. It kind of sounds like some sort of feedback or interference. I'm wondering if this is a problem with the speaker or with the hookup (speaker wires, input etc). Thanks
0 characters
1 Points
Ilive bluetooth computer speaker system
replace the speaker with a new one :-)
it can be aproblem with the amplifire !!!
if it bad in high levels and good in low its a speaker
if its bad all the way its a burn chanell in the AMP.
Dec 11, 2013 | Boomboxes
Sound comes out of left channel only in my Lasonic L-30K boombox
Check the speaker wire for proper contact, swap speakers around to rule out the speaker, if okay suspect the left audio output chip.
Jun 15, 2012 | Lasonic L-30K Cassette Boombox
XMI X-Mini Ii Capsule Speaker won't charge
The rechargeable battery may be exhausted and probably needs to be replaced. Try type make and model of Capsule Speaker and scroll through the list. The only other option is try the manufacture, contact customer support and the technical department.
Jun 01, 2012 | KB Covers Xam4-r X-mini Ii Capsule Speaker...
My Panasonic rx-d14 every so often when listening to the radio makes a fwupping sound through the speakers, this only lasts a few seconds but has me curious to what it is, the volume of the radio doesnt...
Sounds like local interference by nearby electronics. If it regularly makes this sound when used in an entirely different place, then I would begin to suspect an internal malfunction. Otherwise it could be a baby monitor, or police scanner, etc. Or something on the same circuit making electric noise. Try plugging it in a different room ( maybe you have done this already). Perhaps one of these is it. I hope so.
Sep 02, 2010 | Panasonic RX-D14 Cassette/CD Boombox
Panasonic rx-dt610 the speaker port at the back
A port is only an opening into the speaker enclosure. If "it is not working" it is obstructed, something blocking it.
Apr 11, 2010 | Boomboxes
Left speaker (as I face unit) has ceased to function. Any reasonable solution?
Speaker could be blown, wires could have come off the back of the speaker inside. Balance knob could have short.
Apr 06, 2010 | Sony CFD-S550 Cassette/CD Boombox
Speakers shorting out
at medium volume push the speaker cone with your hand ( be gentile and push it several times) if the speaker make sound again then the problem is the spaeker and must be replaced , if its possible switch the speakers from one channel to the other channel to see if the problem is the speaker or the output channel
Feb 26, 2010 | Boomboxes
My wharfedale titan 15 passive loudspeaker only sounds the tweeter but not the driver
If you have never overdriven the speaker, it'll probably be a dry solder joint in the crossover. Take all the screws out the back panel, the crossover is mounted on that. Unscrew the crossover board, redo all the solder joints, finaly make sure the cheap spade terminals are connecting to the speaker properly, then put it all back together. You can check all the connections if you have a multimeter. Same happened to me.
Dec 23, 2009 | Boomboxes
Pioneer SA 9800 Ampliffier Output transistor going off frequently
I assume these are the complimentary pair that drive the speakers. On one of the speaker. You know I think you have a short in the speaker that it drives. Speaker can fuction even if there was a problem with it. I think what happened is when the original transistors shorted out it overloaded the speaker, but not to a point where it is burnt. There is nothing that can overload a power transistor except the speakers, I design a lot of amplifiers, the base input can overload it if you put dc in there, but that would make a the sound all distorted, I assume the sound seem fine. Solution is try connecting a known good speaker and I bet it wont burn out anymore. Even if the speaker look fine don't trust it.
Jun 30, 2009 | Lasonic TRC-931 Cassette Boombox
Boomboxes Logo
29 people viewed this question
Top Sony Boomboxes Experts
Are you a Sony Boombox Expert? Answer questions, earn points and help others
