Question about Lasko Ceramic Heater w/Adjustable Thermostat, 3-Settings; 1500W, 900W, and Fan Only
Have a lasko ceramic element heater
I would like to know why when i got home it worked and then just shut down. i pressed the power button but the high temp and max light up for just a second then it shut off. can you tell me what the problem may be or how to fix it?
  • 1 more comment
  • Anonymous Dec 24, 2008
    I had the same issue. I called LASKO and it was suggested that I plug it into another outlet. I did that and it worked. Now I have the same issue. I plugeed it into different outlets and get only beeping sounds-no lights.
  • jhill573 Dec 30, 2008
    Having the same problem with mine, if anyone finds a sloution-please post.
  • Anonymous Mar 14, 2009
    exact same problem
    Problem Solver:
Just wanted to say that I am having the same problem.  I turn it on and it stops working.  When I push the power, it only lights up for a second and beeps and then goes off.  Is there a solution to this yet? I think the company owes us an explanation.  I have already tried to plug it in to different outlets and still get the same results.
Posted on Feb 07, 2009
  • machtuck Feb 07, 2009
    I just posted a comment stating that I was having the same problem with my lasko heater shutting off.  I pulled up the instructions and found out that the heater has a safety shut off for overheating.  Once it reaches a certain temp, it automatically shuts off.  To reset it, you must unplug it for 10 minutes and it should work again.
I had the exact same problem I used my air compressor and blew loads of dust out and now it works
Posted on Mar 04, 2013
How do I regulate temp on my lasko heater
My experience with Lasko heaters is with the small portable ceramic types. On mine there are two knobs. One is the "Power"; the fan symbol is for fan only, then (I) Low Power and (II) High Power 1500 watts. The other know is the thermostat from (-) to (+). Set the thermostat towards (+) until the temp in the room is the way you want it. Then turn the thermostat know towards (-) until the unit shuts off. This is now the temperature setting and the heater will cycle on and off to this setting. Hope this helps.
Jan 05, 2014 | Lasko Ceramic Heater
New lasko heater keeps shutting down
fatly over heat switch or tilt switch some r very picky
Dec 10, 2013 | Lasko Heating & Cooling
Hi, I have the Lasko Ceramic Elements heaters. When I plug it in, the light lights up to show it's plugged in, but when I try to press the POWER button turn it on, it beeps but does not do start heating...
If I am getting this right you just purchased this heater? I would return it and get another one. It sounds like the tip over switch is not made and will only show that power is getting to it but the tip switch is keeping it from heating.
Dec 14, 2010 | Lasko 5540 Ceramic Compact Heater
UI have a Lasko ceramic element heater with digital display, when the heater runs for a while, it will shut off, no display at all, I then have to unplug the unit for a couple hours to get it to function...
I do not know how to solve this problem but i will add my own solution. Like you said, you will have to wait for it to begin functioning again after you plug it back up.while its unplugged, you have to wait a moment until a small click it made.
Nov 26, 2010 | Lasko Ceramic Heater
I have a lasko tower ceramic heater that keeps shutting down.
mine does the same thing every year. I just clean out the dust from the vents on the back of the heater so the heater can breath otherwise it could get too hot and the safety fetcher kick in and makes the heater stop working.
Oct 19, 2009 | Tower Lasko 30 Inch Ceramic Oscillating...
Dont know what buttons mean
hai sir the button which you are confused in is used only for reseting the equipment.please find your equipment seller for a copy of users manual.
Jan 29, 2009 | Lasko 5365 Ceramic Compact Heater
Lasko 5350 will not power up. Tempermental.
I had the same problem with mine,, I called the 800# and they told me to either vacuum it out weekly or use a hair dryer to blow out the vents, both solutions seemed to have work for me ~ good luck
Nov 14, 2008 | Heating & Cooling
Lasko Ceramic Heater w/Adjustable Thermostat, 3-Settings; 1500W, 900W, and Fan Only Logo
780 people viewed this question
Top Lasko Heating & Cooling Experts
Steve
Craig Butler
Craig Butler
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
