I have a hitachi kc1000d dab/fm cd alarm clock radio. it has just stopped working when i press the power button it comes on for about 2 seconds then goes off. any advice
2 Suggested Answers
  • 71 Answers
SOURCE: how to reboot hitachi dab radio
Sounds like what happened to my Sharp DAB receiver recently . - Swtch OFF completely from all power sources and proceed with the recommended RESET function.
Move set and/or aerial to be sure of a good strong signal before attempting a complete re-start and full AutoTune as per the instruction manual.
This operation certainly cured my problem although I never have found out what caused the failure in the first place!!!
Posted on Feb 29, 2008
How do you put a cd in
Kylie, if there is a CD tray press the eject button and put CD in tray, push tray in easy to load. If no CD tray insert CD into CD slot and push gently to load. Some have a lid on top that you simply open with your finger then load CD. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Jensen JCR 310 AM FM Stereo Dual Alarm Clock Radio with CD Player
Christmas Presents 2013 RCA RP5605 AM FM CD Clock Radio
Magnavox alarm clock radio CD player
Problems With My GE General Electric 7 4901A CD Player AM FM Clock Radio
Jun 17, 2016 | Audio Players & Recorders
How to set presets on nelsonic clock radio nlc 618
To set this alarm first ensure that when you press the Mode button several times the FM/AM radio does not turn on . If the FM or AM radio does turn on or the lcd displays "AU" press the Power button that is next to the Mode button 1 time (pressing the Power button toggles you between 2 settings). You should now be able to press the Mode button at least 3 times without the FM/AM Radio turning on.
Next you press and hold the Alarm 1 or Alarm 2 button and (while continuing to hold down one of the Alarm buttons) press the Hour or Min buttons to set the time of whichever alarm button you are holding down.
When you have the alarm time set you can release the Alarm 1 or Alarm 2 button and press the same button (do not hold the button down this time) to cycle between the types of alarms you can use. You will see the blue circle indicator move between Buzz and Radio when pressing the buttons (Blue circle on left side is for Alarm 1 and blue circle on right side is for Alarm 2). There is a third option as well but I'm not sure what the alarms will do if you set them to it because the blue circle indicator disappears entirely after cycling to Buzz and then Radio.
Hope that helps!
Apr 23, 2014 | Audio Players & Recorders
I just got a Memorex Digital CD Alarm Clock with no manul the modle number is MC 7101. I'm not able to set the clock or alarm. I just need the instructions.
To set the clock:
1. With the power off, press the TIME button; the time will blink.
2. Press the MINUTE button to set the present minute and the HOUR button to set the present hour.
Make sure to set the correct AM/PM setting.
3 Press the TIME button (or wait approx. 15 seconds) and the time will be set.
To set or reset alarm time:
1. With the power off, press the desired ALARM, Press and hold the desired ALARM 1 or ALARM 2 button; the alarm time will blink. The Alarm 1 or Alarm 2 time and settings will appear.
Press the MINUTE button to set the alarm.
2. Press and hold the desired ALARM 1 or ALARM 2button; the alarm time will blink.
Press the MINUTE button to set the alarm minute and the HOUR button to set the alarm hour. Make sure
to set AM/PM setting. Press the ALARM 1 or ALARM 2button again (or wait approx. 15 seconds).
3. Repeatedly press the ALARM 1 or ALARM 2 button to select alarm off, alarm on, for buzzer, radio or CD.
If you needed the manual it could be downloaded:
http://www.retrevo.com/support/Memorex-MC7101-Clock-Radios-manual/id/1081dj880/t/2/
Thanks.
gylacz
Aug 01, 2011 | Memorex MC7101 Clock Radio
Set clock, date, alarm on SI686 CD/ Radio / Alarm Clock with Sound Soother
Can you clarify what you need help with? To SET THE CLOCK push the "Mode" button twice. (The current time setting flashes on the display) Once it is flashing, Decrease the hours by pressing "1" Increase hours by pressing "2" Decrease minutes by pressing "3" and increase minutes by pressing "4". If no additional buttons are pressed the time will reset in about 10 seconds and the display will stop blinking.
TO SET THE DATE press the "mode" button 4 times. The current date setting will flash on the display. Decrease the date by pressing 3. Increase the date by pressing 4.
Decrease months by pressing 1. Increase the months by pressing 2. The date will reset in about 10 seconds when you stop pushing the buttons.
TO SET THE ALARM Press the "mode "button once. The display will begin to flash. Change the hours by pressing either 1 (increase) or 2 (decrease). To change the minutes, press 3 or 4. 3 decreases the minutes and 4 increases the minutes. Once you have the time reset, leave the unit alone for about 10 seconds. the display will stop blinking indicating the time has been reset.
TO ACTIVATE THE ALARM push the round button on the far right. You will see the alarm icon come on or off on the LCD display on the right side. Be sure you have set the AM or PM time correctly on the alarm time. It helps to recheck this now as I have made this mistake several times.
If you get stuck on military time and want the 12 hour clock the answer is posted on this site, as well.
Hope this helps.
Dec 25, 2010 | Sharper Image SI686 Clock Radio
I have lost the operating manual for a technika DAB 109 Radio
I HAS SAME PROBLEM BUT FOUND THE ANSWER. PRESS STANDBY AND TURN UNIT ON, THEN PRESS ALARM BUTTON, DISPLAY SHOWS ALARM 1, PRESS SELECT BUTTON DISPLAY SHOWS FM/DAB/BUZZ, PRESS LEFT/RIGHT BUTTONS TO SWITCH BETWEEN WAKE UP OPTIONS, THEN PRESS SELECT AGAIN, DISPLAY SHOWS OFF, PRESS LEFT/RIGHT BUTTON TO TOGGLE BETWEEN ON/OFF LEAVE 'ON' SHOWING, PRESS SELECT AGAIN DISPLAY WILL SHOW ALARM TIME, USE LEFT/RIGHT TO SET HOUR THEN PRERSS SELECT, USE LEFT/RIGHT TO SET MINUTES TEHM PRESS SELECT AGAIN, DISPLAY WILL NOW SHOW SMALL ALARM CLOCK IN DISPLAY WINDOW, THIS MEANS ALARM IS NOW SET.
Mar 07, 2010 | Audio Players & Recorders
I have a proline DAB 100 alarm clock radio, I went
I am finding difficulty to set the clock on Proline dab 100 fm
Jan 03, 2010 | Audio Players & Recorders
Instructions for setting alarm on Alba PD2 DAB/FM radio Thanks.
Hello All,
I have an Alba PD2 DAB radio and have set the alarm to come on with the radio. The problem is it comes on at a very loud level. Is there a way to set it at a lower level ??
Dab Des
Oregon Scientific RRM326P Snooze button won't work with radio
this is internal speaker control volume defect, please send to repair shop for repair.
Nov 29, 2009 | Audio Players & Recorders
How do you set the time and alarm on the RP5600A
Setting Clock
1. Press SET repeatedly until a clock icon
shows on the display.
2. Press REV or FWD to set the clock
time. The time decrements or
increments will follow by a faster rate
when you press and hold the buttons.
AM or PM icon will also show beside
the time.
3. Press SET when finished.
Setting Wake Time
This unit allows two wake times to be set.
1. Press SET repeatedly on the top of the
unit until you see WAKE 1 or WAKE 2
flashes on the display.
2. Press REV or FWD to set the respective
wake time. The time decrements or
3. Press SET repeatedly until you see no
WAKE 1, WAKE 2 or icon the
display.
Selecting Wake Source
You may be woken up by radio, CD or alarm.
1. If your desired wake source is radio or
CD:
• Wake by radio - select an AM or FM
station (see directions on “Radio”).
• Wake by CD - insert a CD in the CD
compartment. If you want to be
woken up by a specific track on the
CD, press and hold wake up - cd
track
on the top of the unit and at the
same time press REV or FWD to select
a desired track.
2. Set a wake time (see above direction).
3. Press WK-1 or WK-2 repeatedly at the
front of the unit to select a waking
mode. Corresponding icon lights on
the front of the unit.
- Wake 1 by alarm
- Wake 1 by radio
- Wake 1 by CD
In case of Wake 2, “2” shows at the
centre of the icons.
Sep 30, 2009 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
How to reboot hitachi dab radio
Feb 29, 2008 | Audio Players & Recorders
161 people viewed this question
 Grubhead
Grubhead
