Question about Hauck I'Coo Targo Marine Standard Stroller
Where can I get a harness replacement for my Hauck jogging stroll
Model # is 30010. This is the plastic part that clicks the belts together.
  • 3 Answers
You can always contact the customer service department from www.gtbaby.com. They would be happy to help you out.
Posted on Dec 29, 2008
I would like lyrics to I want to strool over Heaven with you.
"I Want To Stroll Over Heaven With You" by Alan Jackson
If I survey all the good things that come to me from above
If I count all the blessings from the storehouse of love
I'd simply ask for the favor of him beyond mortal king
And I'm sure he would grant it again
I want to stroll over Heaven with you some glad day
When all our troubles and heartaches are vanished away
Then we'll enjoy the beauty where all things are new
So many places of beauty we long to see here below
But time and treasures have kept us from making plans as you know
But come the morning of rapture together we'll stand a new
While I stroll over Heaven with you
Source:
Want To Stroll Over Heaven With You lyrics
Aug 14, 2017 | Computers & Internet
Hauck eagle
Hi Sally
We recommend you contact Hauck directly for assistance
We are there for you
Jul 11, 2014 | Baby Gear
Helpline number
Hi Lynne
We'd recommend you contact Hauck for assistance.
Mar 25, 2014 | Hauck Baby Gear
2005 Yamaha Jog VIN decoder
Hi, John they were still making them in 2014 for more information about your question and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
VIN Decoder Motorcycle Identification Cyclepedia
Yamaha Jog RR 2014
http://www.scootermasters.com/manuals/02-05%20Zuma%20SM.pdf
OEM parts for Yamaha
Yamaha CS50 Service Manual
YAMAHA JOGR JOGRR CS50 Owner Manual
Jul 16, 2017 | 2006 Yamaha Jog R
How do I save my phone contacts on to my sim card
From the phone menu click on it and then stroll down to contact click on nit and then stroll down to move contact click on it and then and then stroll down to FROM PHONE TO SIM CLICK ON IT with this all contact will save from phone to Sim.
Good luck.
Dec 06, 2010 | Nokia E51 Cellular Phone
How do you reset time date etc on model fm112 after replacing the batteries
Click on the menu of the phone,stroll down to setting click on it then stroll down to phone setting and then click on it then stroll down to date and time setting click on it to set the date and time of the phone and other setting.
Good luck.
Dec 06, 2010 | Cell Phones
Need replacement tire for Hauck funfor kids jogging stroller 2006
You can buy any size tire at any bike shop and put it on you yourself,do you have inner tubes also,check them to.
Aug 25, 2009 | Hauck Sport - Smoke Umbrella Stroller
Same problem with volume control
I had this problem. The jog dial just stopped functioning. I repaired it by doing this:
1. Remove the batteries and leave the battery cover off.
2. Remove the case screws from the radio using a jewelers sized Phillips screw driver. There is one screw inside the battery compartment.
3. Gently separate the two halves of the radio just a few inches. Remove the wrist strap; it will just be laying over top of a screw post.
4. Inspect the wring of the jog dial. You will note several wires soldered to the dial, including one small bundle of wires leading from the jog dial to a white plastic connector on the faceplate of the radio.
5. Study the bundle of wires from the jog dial to the faceplate. Is it twisted? Has it been crimped inside the case? Smooth and straighten the wires with your fingers gently. Remove severe bends.
6. Detach the small white plastic connector from the faceplate and untwist and smooth the wires. The connector should slip off easily. Now clean the metal pins that the connector mates to with a Q-Tip. Seat, remove and re-seat the connector 3 times to scrape off any built up corrosion. Ensure the wire bundle is smooth and untwisted and reattach the connector.
7. With the radio still apart, reinstall good batteries. DO NOT USE AC POWER! and check that you have returned the proper function of the jog dial.
8. Reinstall the wrist strap over the top corner post and carefully mate the two halves of the radio together. Continue to test and check the jog dial as you seat the halves together. Reinstall one or two case screws at a time, checking that the dial still functions until the radio is fully reassembled and the case is tight.
Jul 18, 2009 | Kaito KA1103 SW/FM/AM Radio
Wont run after I cleaned it
On the model 30200 there is a safety interlock switch actuated by a plastic tab (about 4" down from the top of the front filter cover) on the right side. Assuming that all you did was take off the front cover and clean or replace the filter(s) and the unit was working previously, this should be your answer. If in taking off the cover the switch actuation tab was broken off, you could (carefully) wedge a tab into the slot where the switch resides. This defeats the safety aspect of certifying that the unit isn't running when you remove the cover. The safe work-around is to unplug the unit before you open it for service.
Feb 09, 2008 | Hunter 30200 \ 30010 (Set) Air Purifier
Hauck I'Coo Targo Marine Standard Stroller Logo
219 people viewed this question
Top Hauck Baby Gear Experts
ray gallant
Dorel UK
Dorel UK
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Hauck Baby Gear Expert? Answer questions, earn points and help others
