Question about Acer AL1716B 17" LCD Monitor
Lines on monitor display
I have vertical lines on my monitor. Makes it difficult to read text and see pics clearly.
    Sergeant:
  • 291 Answers
It does sound as if the graphics processor of the video card has died but I suggest downloading the lastest driver for that card on the off chance it is simply a software hiccough.
If, after installing an updated driver it is still there, you might try changing the resolution via the Control Panel/Display, to see if the anomalies change in dimensions but this won't cure anything, only confirm that the card is at fault.
Posted on Dec 01, 2008
I'm having an issue with the monitor when I turn it on i get vertical lines up and down full length of screen. They are intermintent pattern. Like a vertical striped shirt. In between the vertical...
Please check the connection between the logic board and the LCD panel T-CON board, also check for cold solder joints on the circuit boards. Notes: it is not easy to get to the cable. It can be bad LCD panel.
http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 21, 2011 | Dell E173FP 17" LCD Flat Panel Monitor
"Lines" or irregularities through the monitor image display
Check power supply section for bad caps with bulging top first, may be a sign of failing power supply: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Jan 27, 2010 | ViewSonic VX2235WM Monitor
My NEC Multisync LCD 2080ux + has developed a weak display which makes text harder to read. I have adjusted the ATI Radion 9600 graphics card with no success. Any ideas?
One thing that will affect how clear the display is if the monitors resolution is set to the wrong value. your monitor must be set at at its native resolution of 1600x1200. Any other value will result in a degraded display.
Nov 05, 2009 | NEC LCD2080UX (Black) 20.10" LCD Monitor
Display jumping vertically
I had same problem.
Narrowed it down to C637 on logic board.
Replace C637 or logic board.
Sep 21, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Vertical gray stripe on left edge, all pics and text gave a blur
any vertical or horizontal line (any color any size) showing stable on the screen that is the hardware damage at the LCD panel back board ( call panel driver board) . it repair complicate but easy to do change LCD panel (common parts). you need find a PC service dealer to do so.
Feb 07, 2009 | Dell E207WFP LCD Monitor
Vertical lines
1st print a report, can you see the lines? Then either the drum is faulty or the laser scanner is. If the lines are not present when printing a report, make a copy and see then if the lines appear. If so, the scanner is faulty. Try cleaning the glass with glass cleaner. However, blank lines mean that bits are missing from the scanner itself and the scanner will need to be replaced.
Feb 27, 2008 | Brother IntelliFax-2820 Laser Fax
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
Vertical lines more or less... baclk is grey and blured
It could be a bad connection somewhere. Try checking: -Where the video cable plugs into the PC. Remove and check for bent pins, corrosion and replace and firmly reconnect using the thumbscrews on the connector. -Where the video cable plugs into the monitor. Some LCD monitors have removable cables some don?t; if yours does follow the same procedure outlined above. -Could be a problem with an internal connection. A quick test and perhaps even fix would be to grasp the right and left sides of your display while it is on (displaying the offensive lines) and gently twist like you were wringing out a towel. Again, and I emphasize, gently using only a couple of ounces of force. Watch to see if the lines disappear, get worse of make the screen flash or change. If you do then its likely cause is the connector from the LCD panel to the electronics has oxidation or a loose connection. If you?re lucky the flexing might even fix your problem, if not you will have to take it apart to find out exactly what is going on. If that doesn?t work then the next thing to try is connecting the display on another computer to see if it also displays the same lines. If the lines are still there then the problem is in your display and depending on its value and your finances you might consider taking it to a repair shop for an estimate. If the lines are gone take it back to the original PC to see if the lines reappear. If they do then I would suspect your video card or drivers as the likely candidate. Let us know if you have any more questions and please don?t forget to rate this post.
Feb 21, 2007 | Samsung SyncMaster 913V 19" LCD Monitor
Acer AL1716B 17" LCD Monitor Logo
103 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
