Question about Dryers
Dryer won't run anymore
I have a 3 year old Amana NDG5805AWW gas dryer. I was using it and it shut off. I found that the door for the exhaust air was closed. Is there a reset button on it inside or did I burn something up and an automatic shut off for over temp shut it off?
  • 706 Answers
Hello opirono,
Please use the attached link
to show the details of your dryer.. In all probability, you smoked the thermal fuse and that needs to be replaced, Feel free to contact me if you need additional assitance,
Posted on Dec 02, 2008
Dryer won't continue to heat and doesn't shut off.
The coils on the gas assembly get IFFY with age. They work a little then get hot and quit. My Video
Jul 08, 2012 | Dryers
Dryer is not heating enough to dry the clothes. It is 9 years old, is it better to just invest in a new dryer?
After 9 years you are going to need to replace some parts. If the ignitor works and the flame sensor is shutting down the gas but the flame stops after a while or not at all then them cols need to be replaced. themobilian_2331.jpgthemobilian_2332.jpgthemobilian_2333.jpg
Amana Dryer Service Manual Gas and electric models (printable)
May 09, 2011 | Amana ALG230RAW Gas Dryer
Have a gas dryer...brand getting gas but will not get hot. Is there a shut off valve or something we need to turn on
Is the exhaust vents old? If so clean them out or replace with new. Clogged up ones will shut down the burner automaticly by the sensor built into every dryer made
Sep 11, 2010 | Amana Dryers
Amana NDG2335AW Gas Dryer runs but doesn't heat
Check the spark ignitor when firtst starting the dryer up. It should click within the first 15 seconds to light the pilot up
May 31, 2010 | Amana NDG2335AW Gas Dryer
Gas dryer continues to run on the Auto cycle.
try to get the manual for the dryer you got and locate the moisture sensor if this sensor is bad what happen is that the automatic timer thinks that the clothes still wet and continues to dry once the sensor detects no moisture then it shut off the dryer normally is located behind the dryer on the exit line of the air duct and tested for conductivity and see if is good or not
Mar 27, 2009 | Amana DLG330RAW Gas Dryer
Maytag electric dryer INTERIOR ehaust vents have come apart and are obviously not exhausting hor air through the side opening.
take of screws holding door on, and screws opposite door hinges. the front will know be able to take off. just unplug first.
Oct 30, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Amana gas dryer only heats first 20 minutes
Check your ducts that the heat blows out through. make sure there is no plug up in the dryer or in the ductwork.
You may have a problem with the termosensor or the high temp cut out safety switch/sensor. This sensor would be somewhere in the exhaust of the dryer.
Feb 04, 2008 | Amana ALG331RAW Gas Dryer
Dryers Logo
71 people viewed this question
Top Dryers Experts
