Getting an Error Message when trying to scan
Im using the Canon DR-5080c scanner and when I try to scan a page using "scan batch to file" I get an error message that reads:
Can't locate SCSI device; check cable and power. (-4536)
I have checked to be sure that everything is connected properly, and as far as I can tell, there is not a problem.... Can anyone help me with this?
  • Anonymous Dec 31, 2008
    I have the same problem
    Problem Solver:
  • 16 Answers
SCSI devices are detected as the computer is booting. If your scanner was powered on after your computer was already up and running, it may not have been identified by the SCSI card. Try leavinging the scanner connected and powered on and then reboot your computer. Also, the pins on the SCSI cable connectors are easy to bend; inspect the rows of small pins with a flashlight or just try a different cable if you have one.
Posted on Dec 06, 2008
Can i skip blank pages while scanning duplex with a 5080c using capture perfect 3.0?
There is option to skip Blank pages. You have to specify in terms of percentage, above which the scanner will save and discard images below the specified percentage.
S. Mohan, India
Feb 28, 2013 | Canon DR 5080C Path-Through Scanner
I have a canon 6080 scanner. getting a error "no
Clean the two 'black dots' in the paper tray, just under the roller. They are actually paper sensors. Try 'page counting'. If this works, the scanner is okay. If the problem still persists, try reloading the scanning software.
S. Mohan, Chennai, India
Nov 17, 2010 | Canon DR-6080 Path-Through Scanner
How do i get my Canon 5080C scanner to scan in a PDF format?
Assuming you are using CapturePerfect Scanning software, you need to select the output as PDF. If you want multiple pages in a PDF file, you need to select 'multipage' option.
S. Mohan
Nov 09, 2010 | Canon DR 5080C Path-Through Scanner
Are you able to send me a driver for: Cannon DR 5080C Cannon DR 4010C rgds BT
You can get the correct drivers from Canon for free. Get teh correct one for yoru printer and OS.
Oct 27, 2010 | Canon DR 5080C Path-Through Scanner
Auto detection can not be set as default
A 'Driver' is only the software portion to connect two hardwares. You need to install a printer driver for Printer, or a DVD driver for a DVD drive. Similarly, the scanner driver just connects the scanner to the computer.
You need to use a Scanning software to use the scanner. Canon offers CapturePerfect 3, using which you scan documents, do rotation, convert to PDF etc. CP3 has option to detect the page size. CP2 is available free of cost from Canon sites. CP3 comes with the scanner.
Apr 01, 2010 | Canon DR-5010C Scanner
Acrobat and Canon DR-9080C not working
You are right, it is driver related issue. Acobat 9 has more features that may not be compatible with the existing driver. may be you can use CapturePerfect and directly create PDF and then use the Optimising features of Acrobat 9. Ofcourse you have to do it twice, but you can use the 'batch' process and do it automatically.
S. Mohan
Jul 09, 2009 | Canon DR-9080C Path-Through Scanner
I have a new DR-5010C scanner. I used to use the
I havent used Canon 2580C and hence cant comment on Scan Panel. But you can download SU5000 or Captureperfect 2.0 from Canon website (http://software.canon-europe.com/). This is easy to use and probably offers more features as compared to ScanPanel. Canon 5010C is a higher model as compared to 2589C and Captureperfect may offer better user interface.
S. Mohan. Chennai, India
Mar 19, 2009 | Canon DR-5010C Scanner
Color page in Batch to file
If you select color mode and scan grey and color pages, the output will be Grey for Grey abd color for color. If you had chosen to scan in grey mode, color will appear in Grey only.
There is an option to scan in both color and B&W simultaneously under multistream option.
S. Mohan, India
Jan 27, 2009 | Canon DR-9080C Path-Through Scanner
P00 Error with no paper jam
See this link:
Look for reference to P00 error
http://74.125.47.132/search?q=cache:CSQKZT0GyBEJ:downloads.canon.com/cpr/software/scanners/5080QRG.pdf+DR-5080C+p00+error&hl=en&ct=clnk&cd=1&gl=us
Jan 23, 2009 | Canon DR 5080C Path-Through Scanner
Canon DR-3080 CII Scanner
I recieved this error when trying to scan pages in using our new Kofax scanning solution with a DR-3080CII. I discovered that the latest canon driver for that scanner was not compatible with the software and it made the application hang in the background. I found an older driver that was compatible and installed it, no more error.
Sep 10, 2008 | Canon DR-3080CII Path-Through Flatbed...
1,616 people viewed this question
k24674
jasbo
jasbo
