Question about HP Office Equipment & Supplies
Printer will not accept instructions from computer
    Sergeant:
  • 291 Answers
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Posted on Dec 01, 2008
Printer not accepting computer instruction to print, but gives no indication of why it does not want to print. New cartridges installed but still no response.
be sure you select it as a default printer in the printer properties right click the printer then select as default, or if it has a pending job delete it all
Aug 03, 2011 | Lexmark X5495 Printer
Printer wont print black ink
Before doing this, Please make sure that the black ink is in good level then try cleaning the print head of your printer.
to do that:
From computer:
- You need to launch the HP SOLUTION CENTER from your computer,
- at the bottom part, please click on settings.
- then, select the printer toolbox and select printer services.
- now, on the list, look for clean printhead and then follow the instructions.
From Front Panel:
- Press the Setup button. - Select Tools .
- Select Clean Printhead .
- it will print a diagnostic page. If the print out is not acceptable please do the second level of cleaning and so on.
- And if you do have the acceptable diagnostic page printout, please stop the cleaning process and try to print a document from your computer.
Cheers!
Jun 20, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
I lost the cd to my printer and need to install it on another computer.
If you did mention the Operating System installed on the other Computer, I can help you better. Anyway follow the instructions below;
Click on the link [here] After it's opened, click "Select" on the "Select you operating system" menu and select your operating system, and then click "next", again select "Driver" and click "Download" and follow the onscreen instructions, (if you are asked whether you agree the terms and conditions click "Accept" if not, that's better). Download will begin after few seconds.
Good luck.
Thanks for using FixYa.
Good
Jun 30, 2010 | HP Officejet Pro L7680 All-In-One Printer
Won't accept new ink cartridge
Look inside where the ink goes, there is a spring on the right side, if it comes out of place it can cut the ribbon cable at the rear. If thats the case, you need a new printer.
Jul 14, 2009 | HP Photosmart C6180 All-In-One InkJet...
I have an regular Epson Stylus C88+ printer and i do not have a cd or instruction manuel to know how to install it on my computer and i get it installed on my computer and need instructions on how to...
All the information you need to for your printer is available here:
Epson Stylus C88+
The short version for installing on your printer is to download the proper driver for your operating system from the "Drivers & Downloads" section (see link above).
Run the installer and only plug the printer cable into the computer when the installer tells you to...
After that it's just a case of accepting any warnings re: Signed drivers and following the instructions on the screen.
Hope that helps.
Mar 14, 2009 | Epson Stylus C88 All-In-One InkJet Printer
Adding printer to vista pc
here is a link to some instructions on how to fix this error http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=31926&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=1128309
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 17, 2008 | HP Deskjet F340 All-In-One Printer
Printer will not print.
Printer does not printIf the printer is sitting idle and there is no output, check the following:
  1. Make sure that the printer has power.
  2. Check that the printer is not out of paper, ink, or toner and that it is not in an error state.
  3. Verify that the printer hardware is working before continuing. Run a self-test (refer to the printer manual for instructions).
  4. Check the printer cable and make sure that it is attached properly to the port and the printer. Refer to your printer documentation.
  5. If the printer is a serial printer, make sure that the baud rate at which the computer sends data to the printer matches the printer's baud rate. For instructions on how to reset the baud rate, see ``Printer output is illegible''.
  6. Make sure that the printer is enabled and accepting jobs. See ``Enabling and disabling printers'' and ``Accepting or rejecting print jobs''.
  7. Verify that the system has the port configured properly. See ``Port does not respond'' for more information.
  8. Make sure that the port is configured for the proper interrupt vector and that no other hardware is using that interrupt vector. See ``Interrupt vectors'' for more information. See your hardware documentation for information on configuring your ports.
  9. Test the printer port connection by redirecting the output of a command directly to the device.
Oct 07, 2008 | Computers & Internet
I have a new HP All-in-one Inkjet printer which refuses to accept mating with the provided HP 4200 software. I contributed to this by hooking up the USB cable to the printer before installing the CD...
Turn off computer, hook up your printer as instructed, turn on computer and it will reconize the new printer. It will ask you if you have the cd for the printer. say yes, insert cd and follow instructions. make sure you make it your default printer.
Sep 23, 2008 | HP Office Equipment & Supplies
Failing to install: computer freezes on license agreement stage
Did you run the setup before you plugged in the printer? You are supposed to only plug it in when the setup instructs you to do so.
Apr 09, 2008 | Lexmark X1270 All-In-One InkJet Printer
26 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
