Question about HP Office Equipment & Supplies
I just instaled a new cartrage. I had trouble instaling it and now my printer won't move the cartrages so that it can print.
    Sergeant:
  • 291 Answers
Check out while installing the cartridge you did not brokeout anything which is moving the cartridge carriage on the steel rod..if everthing is perfgect nothing broken then just unplug the printer from main power outlet and wait for two minutes.then plug it in and on the printer and check out.
Posted on Dec 01, 2008
Why does my printer not print
Ink cartrage could be installed inproperly..the machine Must be close and latched properly also. p.s. Make sure the safty tab is removed from the new cartrage.
Jun 07, 2012 | Brother MFC-3360C All-In-One InkJet...
I installed new epson ink cartrage, but printer has red x and tells me to change ink again.? Can i just change only the bkack ink?
Yes you should be able to just change the black ink cartrage, A lot of printer wont allow other third party cartrages, is it a genuine epson ink cartridge? if so try cleaning the contacts on the cartrage.
Apr 25, 2010 | Epson NX415 All-In-One Printer
I have installed a new ink cartrage but the
Restart the computer. Turn off the printer. Turn the printer back on after the computer is fully started.
Mar 29, 2010 | Brother MFC-210C All-In-One Printer
I installed new ink cartrages in my Epson C86
this is idicative of a waste pad counter overflow, the ssc printer utility can clear the inbuilt counter but if your using your printer a lot it would be a good idea to replace or clean the waste pad, its inside the printer and will bee messy but if your doing lots of prints it will be less messy than if it overflows
Sep 26, 2009 | Epson Stylus C86 InkJet Printer
I'm using an Epson 1400 for dye sublimation and have installed a bag feed system. The 1400 is alerting that the cartrages are not the correct cartrages for this printer and will not let me print. Is there...
Hi I know if you go into Start, Control Panel, printers & Faxes, epson 1400, right click printing preferences, maintenance, speed & progress, and click on Disable Epson Status Monitor - this stops the printer 'thinking' the cartridges are running out... Joy
Jul 01, 2009 | Epson Office Equipment & Supplies
Color ink cartridge says empty i just filled it
When you put in a "new" cartrage the printer sens an electrical charge to the cartrage to set it up properly. So I would treat this as a new cartrage, rather than a refilled one. Go to the printer menu and re install the ink cartrage in question, it should recognise it and start the function as a new one, good luck
Mar 24, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Dell 922 All-In-One Printer will not print anything
The printer does not feed paper from the tray and then states that there is a paper jam. I have removed all paper and there isn't a paper jam. It will feed paper through the lower roller and straight into the printed paper tray, but will not feed a new sheet.
Nov 01, 2008 | Dell 922 All-In-One InkJet Printer
INK CARTRAGE PROBLEM ?
Hi
You must define in printer Properties that you install a new cartridge!!! Just go on Printers and faxes, right click on printer, select properties, advance and click install new cartridge!!!
good luck!!!
Jan 23, 2008 | HP PSC 1210 All-In-One InkJet Printer
22 people viewed this question
Ben Johnson
