Question about O2 Xda III
Bluetooth GPS Tom Tom to operate with PDA Xda IIi
Bluetooth connection set up ok. Shortcut created in bluetooth manager ok.Conneting to GPS ok.After accessing Tom Tom progam in bottom lefthand corner shows no GPS Device.Any suggestions gladly welcommed.
Have you tried using 'other wired device', try each com, rather than bluetooth, on tomtom configuration settings, works for me with TT5 and a Holux BT GPS reciever
Posted on Apr 13, 2008
Pairing ok but want shortcut to reconnect bluetooth headset
Go into your bluetooth manager, and there should be a check box to allow you to create a shortcut on your desktop.
Jun 26, 2010 | Microsoft Computers & Internet
Cannot connect phone
1-Your tom tom does not have the device driver needed to connect to your phone?
2- Turn off the bluetooth device the tom tom is a bluetooth device and the two of them are probably arguing the tom tom and your actual bluetooth.
3- You have to put the tom tom in discover mode and let the PHONE find the tom tom then the tom tom should find the phone, once this happens you enter the code and tell the phone that this is a trusted device. The same thing that was done with your actual bluetooth device. Hope this helps
Jun 19, 2010 | Tomtom GO 740 LIVE GPS Receiver
Conneting a Bluetooth
create one usually 1234 works
Aug 02, 2009 | Cell Phones
Mobile phone won't connect to Tom Tom go 540 live
Hi, I got round this problem by pressing and holding the ON/OFF button for 15 seconds untill system reboots. Then reconnect mobile,if not delete mobile and repeat process.
Apr 05, 2009 | GPS
S620 Using GPS with Memory Map software
In the Comm Manager, select Settings, then Bluetooth.  Again select bluetooth and then scroll down to your GPS receiver assuming you're paired correctly.  Click Menu and then COM ports.  Now click Menu and select New Outgoing Port.  Pick COM6 assuming you have nothing else on this as your outgoing port.                   Now go back to your map program.  In the GPS settings, select COM6 as your GPS and it should now give your position.  I use google maps and have no bother.
Aug 19, 2008 | HTC S620 Smartphone
O2 - XDA II
Hi Marky T, have a peruse on the site http://wiki.xda-developers.com/ there is a lot of discussion on Bluetooth headset issues and solutions.
Apr 19, 2007 | O2 Xda II Smartphone
Why does my bluetooth keep turning itself off ON MY 02 XdaII this even happens when it is all fully charged.
I has the same situation like you but opposite event. My O2 XDA II or Siemens SX66 or even calls Qtek 9090 is another version with your O2 has sometime Bluetooth keeps turning on. I turn it off for few seconds, it is on again. I tried to solve th eproblem by get ito the setting area to turn it off and reset my PDA. My PDA has the area calls Wireless Manager. I click on all three function including phone, wi-fi, bluetooth and go out of wireless manager area and get into connection and click on Bluetooth and turn it on or off then only Bluetooth get effected. I don't know why but that is I found out my own way. Just play around these features by testing it the way I mentioned above. i hope this help. This feature is not stable in these type of models. You are not the only one. ALSO, TRY TO GET IT ON TO CONNECT WITH OTHER BLUETOOTH DEVICES TO HOW IT IS REACTED. Good Luck
Mar 29, 2007 | O2 Xda II Smartphone
Bluetooth Problems with HX2755
As an update I have contacted hp Warranty Support via phone and we determined that all the criteria was made to have the hx2755 returned to have diagnostics performed and repair if needed.. All my computers and periphery are HP as I have full confidence in the product line.
Sep 14, 2005 | HP iPAQ HX2755 Pocket PC
E310 and GPS
Before you buy the GPS for your PDA please be careful if the GPS manufacturer guaranteed the functionality with your PDA. I have e800 and I plan to buy the GPS for my unit. Unfortunately at the moment I have no information which one you should you use. You should have a look at the following document, to see how to setup a BT connection to your BT -GPS device. http://aps.toshiba-tro.de/bluetooth/redirect.php?page=pages/howto.html http://aps.toshiba-tro.de/bluetooth/pages/howto/How_to_use_a_Bluetooth_GPS_Receiver_v002.zip
Sep 11, 2005 | Toshiba e310 Pocket PC
Connect to the internet via
Once the Socketcom Bluetooth card is inserted in the Toshiba Pocket e570 PC and the software has been loaded, the following instructions will set up the Toshiba PDA & Ericsson T39 mobile phone to connect to the Internet. Click on the Bluetooth icon in the bottom right hand corner. Click on Get Connected! Select the device under My Bluetooth phone is: In this case the Ericsson T39. The following information gives details on how to change the name of the Mobile device. Once this has been read, click on Next. The phone now has to be made discoverable so that the PDA will detect it. To do this, use the down arrow on the phone to select Extras and then click on Yes. Scroll down to Bluetooth and Click on Yes. Select Make Discoverable and a message on the phone will appear saying that the phone is discoverable for the next 3 minutes. Click on Next on the PDA. The PDA will now look for a Bluetooth device(s). Once the mobile is detected the PDA will search for the Device Name of the mobile. Click on Select and the devices will not connect and create a partnership. The following Device Bonding window should appear to create a bond between the PDA and phone. Click on Next. To create the bond a passkey must be entered on the PDA. This may be a between a 4-16 digit code. N.B. We would advise that the code be kept to a numeric sequence as the keys contain more than one letter on them, i.e. for the letter L, the number 5 key will need to be depressed 3 times. Once the passkey is entered, click on the Reply button. On the mobile, click on Yes to accept the incoming pass and then enter the same passkey. Click on Yes again to confirm. If the two values are correct, a message will appear on the phone telling you that the devices are bonded. The PDA should now congratulate you on your connection. For Internet access via Bluetooth, please follow the steps outlined below. The above instructions only need to be carried out each time a connection is required. However, the instructions below only need to be setup once. Click on Start, then Settings from the drop down menu. Click on the Connections tab at the bottom of the screen followed by the Connections icon utility. In the first drop box labelled "When needed automatically connect to The Internet using these settings" select New. Under the General tab you will be prompted to give the new connection a name, e.g. Bluetooth. Select the modem "Bluetooth Phone" and click on Next Make sure that the fields for the boxes titled Country code and Area code, are empty. The next field requires the full telephone number, including STD code, you wish to dial, i.e. your ISP telephone number. Put this in and click on Next. The next page contains a time out clause if the PDA is unable to connect within a set time. By default this should be 120 seconds. Make sure the tick box for "Wait befo
Sep 07, 2005 | Toshiba e570
O2 Xda III Logo
229 people viewed this question
Top O2 Computers & Internet Experts
zurysk8
Level 1 Expert
xxxxxx xxx
Jax Planet
Jax Planet
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
