Nothing at all comes up when i put a cd rom in to the d drive. nothing shows up in my computer. i was windering if this could be fixed of if the actual drive is broken?? Thanks alot. xx
    Scholar:
  • 81 Answers
Try another cd. If that cd works then it's not the cd drive. The cd-rom may not be the right type of media (i.e. a +r or -r when you can only read one or the other). ALso look on the back of the disk for scratches, blemishes, and finger prints. Try to buss them out with just a cotton ****, papertowel, or a towel just as you would a pair glasses.
Posted on Dec 01, 2008
My cd-rom on dell Dimension 8250 pc desktop computer will not show up on my computer. Am i missing cd-rom drivers.
hello,
1.first go to http://support.microsoft.com/mats/cd_dvd_drive_problems
click on the green button that has run now
Run the microsft fix it tool
if it works GREAT! if not go to #2
#2 go to this site http://www.techsupportall.com/fixed-solved-cd-drive-not-found-not-detect-remove-upper-and-lower-filter/
follow instructions
IF THAT WORKS GREAT! if not proceed to 3
#3 turn off computer unplug power cord.
open your computer case unplug the cables that connect to the back of the cd rom. plug computer back in power it up. shut it down once it loads. then once it is powered down open case again and plug the cables back in make sure they are connected well. close case and power up the computer.
hope that helps
Nov 25, 2012 | Dell Dimension 8250 PC Desktop
My cd-rom location do not show up on my Dell Dimension 8250 computer devices. Why
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
You might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
If this does not fix the problem it might be a registry problem
"you only need to do the following"
if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Hope this helps.
I put in the dvd and nothing popped up.
does the cd show up " ICON if not down load this nd run it - it will reset the cd rom in the registry and 99% of the times fixes it after you run this file reboot PC
download this as open it run it reboot :()
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Dec 30, 2009 | Punch Home and Landscape Design Suite for...
I have a Dell Inspiron 9200 that does not reconize my cd/dvd drive. What would be the estimate cost for this repair.
Hello there:
Your drive may not necessarly be bad , what i would do is open the case and switch the ribbon from the harddrive and place it on the cd rom and then place the one that was on the cd rom and put it on the harddrive and boot the computer into the bios and see if the cd rom is now showing up.,
If so good which may mean that the ribbon cable that was originally attached to the cd rom may not be good .
But if still nothing than you can put every thing back the way it was and if the ribbon cable that was attached to the cd rom originally has a extra end to hook up to the cd rom try to use it and see what happnes if still nothing than yes replace the drive they usually run about 30 to 60 dollars ok?
best regards michael
Sep 29, 2009 | Computers & Internet
Cannot get CD-ROM to work,to come up on screen.
Ok with that you need to insert the disc and then go into the my computer section of your computer and then in the CD rom drive you should see the disc and you will click on it to start the process. However if that does not work then your CD rom drive is defective and you need to purchase a new one.
Jun 17, 2009 | Computers & Internet
Insert CD, close, nothing happens.
go to my computer and find your drive and open or explore.
if the drive isn't showing reload your cd rom driver
May 26, 2009 | Dell Dimension 2400 PC Desktop
I put a blank cd in side the slot and nothing happens i put a game game disk inside and still nothing it's not reading anything i put in i think it might be something to do with my cd rom drivers but my...
Can you see the drive in "My Computer", and did you look in device manager to see if it shows an error there.
if you cannot see the drive in my computer, but you can see it in Device Manager the instructions in this link
Jan 31, 2009 | Computers & Internet
My drive
The first thing to do if you have'nt already is check the ide cables connected aren't loose, then; right click on the cd rom in system properties and uninstal it, re-boot the system and let the pc find the cd drive again and try again. Failing that there is a cdrom checker on the microsoft web site, although you will have to search for it, as i can't remember the page, or if you use nero burning rom, it's got a drive checker also. If you have to buy another cdrom they are very cheap and easy to fit.
Oct 09, 2006 | LG CRD 8482B (CRD-8482B) Internal 48x...
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
