Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Plastic melted on Dishwasher heating element
A plastic handled spatula fell on the heating element of my dishwasher. Need to know what and how to clean the plastic residue off of the heating element
  • bpinneo7 Dec 01, 2008
    can i use steel wool to clean the heating element while it is not in use?
    Can i use steel wool to clean the heating element while it is not in use?
You can also use blow dryer to heat up plastic
Posted on Feb 04, 2009
  • mugs54 Feb 04, 2009
    I am looking to buy a owners manul for FDB1050REC Dishwasher
  • 3 Answers
Youll have to run a whole cycle again and pay attention to when the heating element comes on again. Once its hot the plastic will be soft enough to remove it with a tight cotton rag. Use you oven mitts for protection. Hope this helps
Posted on Dec 01, 2008
  • titanservice Dec 01, 2008
    Steel wool is a good idea, but remember that the plastic has to be soft again...so make sure its hot and soft.
Burning smell from dishwasher
There is a heating element located on the bottom inside. Make sure you do not have anything that fell on it. And make sure it's in it's brackets it could be resting on the bottom of your dishwasher and melting a hole through the bottom.
Sep 04, 2014 | Dishwashers
A spoon will a plastic handle melted on the circular heating element on the floor of the dishwasher. It is stuck on there, should we pry it off? Will the dishwasher still work? What do you suggest?
Hello, Thank You for using FixYa. I will be helping you today. Yes i would remove as much as you can you wont damage the heating element. Then run a cycle with heated dry and check after the cycle if you can remove the fest.
Thank You and please rate my answer if it was helpful..
Jun 22, 2011 | KitchenAid KUDK03ITBK Built-in Dishwasher
I a Westinghouse dishwasher 920 and a plastic spoon fell onto the element while it was on and its melted the spoon on the heat element and i cant remove it. how do i replace the element i am a motor mech...
Break as much of the plastic off as you can and just let the rest melt off or melt it with a solder gun . won't hurt anything. If you want is easy to replace just hall machine from hole and tilt back remove the wires and the nuts holding it on .
Dec 03, 2010 | Westinghouse Dishwashers
Plastic is melted onto the heating element. is this a problem? what should i do?
I am assuming the dishwasher is not working.
You will need to check where the plastic has come from. The temperature has to be very high for the plastic to melt. This can happen if the dishwasher heater has been on with no water in the dishwasher. Normally the controller should not allow this. Also the thermostat should cut in to prevent the temperature from going high.
Most likely it is not plastic but a problem in the wash pump which is causing some residue to circulate in the water and deposit on heating element.
In any case, try to scrape off as much of the material as you can and then run the dishwasher with a Finish dishwasher cleaning kit. The instructions are on the kit label.
Hope this helps. Please rate the solution.
Oct 10, 2010 | Jenn-Air JDB6510 Built-in Dishwasher
Plastic dishes and utensils have white film on them
Check your heating element..
Dishwasher2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 03, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Plastic fused to hearing element
There are many ways to approach this. I assume it has melted and wrapped around the heating element.
One thought is to use a pair of wire-cutters ( called "diagonals"), and cut it off piece by piece.
Another thought is to run the dishwasher with heat option on, let the dish get soft again and pull it off (wear gloves).
May 09, 2009 | Whirlpool 24 in. DU810CWD Built-in...
Dishwasher had a burning smell and smoke was coming out
If the smoke was coming from inside the dishwasher... A common problem is a plastic item , utensil etc has fallen down onto the heating element. During the drying cycle this could possibly melt the plastic and generate some smoke.
Jan 04, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Frigidaire hot water problem
no, i don't think so. the heating element is located under the inside tub and out of the dish area. if you could supply me with the make and model #, I will try and find the exploded view for you. the element is replaceable.
Dec 11, 2008 | Dishwashers
Ge pdw7880j10ss dishwasher lower roller fell off and melted on lower heating element. need to know part number of lower roller and plastic clip that affixes the lower roller to lower rack?
(http://www.geappliances.com/service_and_support/parts/)
the correct # for your unit is pdw7880n10ss
just enter your model #(under repair or replacment parts)the site will walk you thru the rest.when you get to the parts list make sure you use the diagram to match your part exactly(click the red box at top of page)hope this helps.thanx for using fix-ya!!!
Nov 29, 2008 | GE 24 in. Profile PDW7800 Built-in...
Melted utensil on heating element
Hi amsaunders5,
I'm Harvey the Master Plumber.
Your problem is: Children tried to surprise you by doing dishes. The plastic spatula melted and stuck on the heating coil on the bottom
This is a common problem. First, thank the children, it really wasn't their fault.
It's going to take some effort but you'll have to scrape/remove the plstic from the element. Replaceing the element is not a repair I recomend for the average homeowner.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Sep 19, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
1,918 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
