Question about Mitsubishi WS-55819 55" Rear Projection Television
Mitsubishi WS-55819 HDTV won't power on
When I push the power button on the front panel, I hear no clicking noises and the timer light doesn't blink like all the other similar problems I've seen. The TV doesn't power on, and I've tried the Menu-Input method as well. I have the service manual on the way, it seems as if the TV just isn't getting any power. Any advice?
Thank,
Matt
  • 41 Answers
At the very least you are not getting any of the Standby power to the Microprocessor (5 vdc). I would concern myself with that area once you get the manual. In the mean time check all the fuses.
Posted on Dec 21, 2008
SOURCE:
G61-306NR power button doesn't work
Disk Drive works, Memory is good, so any Blinking Lights or Beeps when you hit the power button? Does anything ever post to the lcd screen when you press the power button?
It sounds like either you've got a memory issue or a video card issue. Just because the memory worked in your friend's computer does not mean it will work in yours. Your Slot where the memory goes might be bad.
When you plug in the power cord is there anylights whatsoever on the laptop, where the plug goes in or on the AC Adapter ofthe power cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Apr 11, 2012 | HEWLETT-PACKARD G61-306NR Notebook
Okay, so my Panasonic PT-43LC14 went black in mid show last night. The bulb is approximately 18 months old. The LED indicators upon Power On are; Power LED blinks green for approximately 70 seconds; Then...
Check the bulb again and look at the root of where the main stem comes out inside and be sure you don't see any bubble like appearence around the stem at the bottom there. If you do see this then the bulb is bad. Otherwise try this: Hold volume down on front of unit and pip on remote for about 5 seconds. Message will come on screen that timer has been reset to zero. This sets the lamp timer to 0
May 17, 2011 | Panasonic PT-43LC14 43" Rear Projection...
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Kenmore Dryer 70 Series. Push switch in and just a little clicking noise. No motion. Took top & front panel off, belt appears to be fine. Suggestions Please??
set timer push button in for dryer to start dryer did not start, timer is working and door light is on,what could be the problem
Oct 17, 2009 | Kenmore 60172 Electric Commercial Dryer
Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
May 21, 2009 | Televison & Video
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Hitachi 43FDX10B Power problem
Below is a few possible causes along with verified cures.
Symptom:
Intermittent shut off
Cause: Check auto link and 4 event timer. redress cabling from front control panel away from blue crt-yoke-hv lead
Symptom: NO PIC OR OSD, PWR LITE COMES ON
Cause: CHECK C603 LEAKY
Symptom: shutdown
Cause: T701
Billy
Jan 23, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Mitsubishi VS-50607
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Oct 04, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi WS-55819 55" Rear Projection Television Logo
67 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
