Question about Zanussi ZJD1219 Front Load Washer / Dryer
Drum noisy when spinning
When machine is spinning, drum is grinding, then when it is spinning fast the noise from the drum is very loud, idea"s how to fix would be much appreciated.
  • nikip May 13, 2008
    noisy whilst spinning and also leaving rust like stains on clothes............
    Problem Solver:
  • 13 Answers
Main wash bearing fail parts for this £48 if you are mechanicaly minded then its a 3hr job if you have all the tools appliance doctor
Posted on Feb 02, 2007
SOURCE:
My Kenmore stackable washer makes very load noises in the rinse and spin cycle but still works. Anyone have idea why it's making so much noise
Try spinning the drum by hand when empty, the faster the better. Does it sound noisy or is there a grinding sound? It should sound silent or whir as everything turns. If noisy then it may well be the drum bearings. If it clunks then it may be one of the arms that holds the drum in place has broken.
Oct 05, 2015 | Kenmore Washing Machines
Loud grinding noise meile washing machine drum when spinning?
It can that the spin drum is touching the body if not you can leave it until its broken my machine is doing tht also
Sep 17, 2014 | Miele Washing Machines
Spin - loud noise - switched off - drum wont turn
I'm just hazarding a guess here, but it sounds like the bearings have gone (if you try to turn the drum by hand and it sounds noisy and grinding/crunchy then I think it would be the bearings). I'm certainly no expert though.
Feb 02, 2014 | Zanussi Washing Machines
Loud grinding noise when on when it starts to spin?
If it is a front loader, then it sounds like the drum bearings have failed, spin the drum from the front by hand, if it feels rough or is noisy, then bearings have failed.
Jan 26, 2011 | Washing Machines
When on a fast spin it is extremely loud, too loud...
Water in bearings causes rust, and rust in bearings creates noise...This is the most likely reason for the noisy spin....Check for any slop in inner drum....Bearings and seals and likely the shaft probably need to be replaced....Quite a big and complex job....Good luck....Nomess
May 18, 2010 | Washing Machines
Spinning cycle has become very noisy on fast spin
Hi
The most common cause of this is the main drum bearing seal has failed and water has washed all the grease out of the drum bearing and knackered it. You will hear a loud roaring noise on the fast spin when this has happened. As it's certainly not a 5-minute-job, it's not economic to have this fault repaired on an older machine if you are paying for the repairs yourself. Get a new machine.
It is fairly unusual for balance weights to come loose as they are usually held tight by locking nuts. I've seen it happen but not very often. Sometimes they break off the drum completely. Symptoms of this are loud knocking noises, the machine attempting to leave the building while on a fast spin and a heavy piece of metal/concrete on the floor under the machine!
Thanks for contacting Fixya.com
Oct 11, 2009 | Zanussi FLA1201W Front Load Washer
Loud grinding noise when machine operating
Hi
Oct 11, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
Grinding Noise
Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Hope this helps.
God Bless.
Jul 08, 2009 | Maytag MED9700S Electric Dryer
Loud noise on fast spin
The drum must be removed to get at it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Elite 45986 Front Load Washer
Hotpoint WMA42 - Noise!!
appliance sounds like it has bearing failure.common on this machine.advise looking for a new machine.sorry
Dec 30, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Zanussi ZJD1219 Front Load Washer / Dryer Logo
260 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
