My Gateway CX200 Laptop monitor is getting darker with a pinkish hue to it. is it my LCD display or the inverter chip or what?
    Master:
  • 474 Answers
Most likey, bad news im affraid, its the screen just going bad. Usually theres nothing that can be done. You can try reseating the ribbon cable and see if that improves it, but most likely it wont, they usually have only so many operating hours before the crystals or plasma goes out, depending which it is. Plasma usually goes out quicker than LCD.
Try finding a replacement on Ebay or online somewhere.
Good luck.
P.S. im asuming of course that you know a little about what you are doing and it isnt something like the display settings or contrast.
Posted on Dec 01, 2008
Hallo , I have compaq presario c745ee , and suddenly the screen getting black but every thing is working , sound , fan sound .. every thing , I connected the laptop to a lcd and it is working probably , I...
Hello !
Since an external monitor works, it is the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim rather than a slow degradation, the inverter would be indicated.
In either case, a technician in your area should be able to help. Evaluate to see if the repair is cost-effective.
Hope this helps.
May 02, 2011 | HP Compaq Presario C700T
I have a Gateway 450ROG with very dim video on the display, I can hook up an external monitor and the video on the external monitor is fine but still very dimvideo on the monitor of the laptop. You can...
Hello !
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation the inverter would be indicated.
Hope this helps.
Oct 26, 2010 | Gateway 450ROG Notebook
Asus laptop and red shadows on letters and bad picture. is this a lcd inverter problem? External monitor works ok.I check lcd panel cable and replace lcd panel but all same
Yep, it's the inverter. Anytime there is a red or pinkish tint or hue you know it is the inverter. Usually the inverter is very easy to change. I would buy one on eBay for your best price...
Good luck!! EJ Kudelka
Oct 18, 2010 | Computers & Internet
This lap top has no picture - the screen is black
Hello.
Connected a monitor to the laptop to see if the video card is faulty.
If an external monitor works, it is the display's backlight or inverter board.
Hope this helps.
Jul 03, 2010 | Computers & Internet
T23 Ibm laptop no video
Hello !
Test with an external monitor. If it works, it is the display's backlight or inverter board.
Hope this helps.
May 08, 2010 | IBM ThinkPad T23 2647 Notebook
Dull laptop screen back light
You may have a faulty CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight or a faulty inverter that supplies high voltage to the CCFL lamp. Usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.lcdparts.net
Dec 30, 2009 | Dell Latitude C610 Notebook
Turned my gateway mx3414 laptop off, when I turned it back on the screen was black, turned off and restarted several times always just a black screen.
You may have a faulty inverter or defective CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
www.ladparts.net
Dec 13, 2009 | Gateway Computers & Internet
Power stays on but screen goes black on my Gateway laptop.
If the laptop appears to boot up and the hard disk LED flashes then you have a backlight problem.
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
www.ladparts.net
Nov 22, 2009 | Gateway 450ROG Notebook
My monitor screen get pinkish , and its get automatically to normal but its not permanent . whats d problem
i gotta know if ur monitor is crt or lcd??
if lcd, Geekman's solution sounds good....
but for crt, u gotta look for dry souldering esp at the crt base..also check the resistances, good heater pin contact, the crt base therein..beware u shld b a professional !!
Oct 23, 2009 | SAMTRON 55V 15" CRT Monitor
Monitor too dark....
inverter board bad. this runs your lcd lamp(s) but is not in the screen.
Oct 02, 2008 | ViewSonic VA702b 17" LCD Monitor
Computers & Internet Logo
47 people viewed this question
Alun Cox
David Payne
David Payne
