Question about Alps MD 1000 Thermal Printer
Driver will not install due to "unknown error."
Hi guys,
I have an MD-1000, and I've been trying to install the XP driver from the alps yahoo group. It installs but before the window finishes I get an error saying saying "the service cannot be installed due to an unknown error." I have another copy of the same driver that came with my printer and I get the same error (hence why I went to get the yahoo groups one.) What could be causing this, is there a fix?
    Problem Solver:
  • 10 Answers
Windows XP Service Pack 3 (SP3) causes the printer to not work - Go to control panel and select system to see which version of Windows you are on. I chose the lazy way out by unistalling SP3 via the control panel programs feature and then adding the printer back in. This is a known issue http://support.microsoft.com/kb/951822 with a Microsoft fix available for the problem. Also check this site out for another way it was fixed http://social.technet.microsoft.com/Forums/en-US/itproxpsp/thread/e308274c-2990-42c0-a98b-9d97eb24981d If you are using Windows Vista, the only way I have been able to get it to work is with a 32bit system (not 64bit) networking into a shared printer connected to an XP computer.
Posted on Aug 12, 2009
    Sniper:
  • 58 Answers
If you read the instructions found at the Alps YahhoGroup, you will find the solution.
Posted on Jul 19, 2009
I am wondering if you have uninstalled all previous drivers .. I know in some instances the Alps Yahoo Groups suggest you un-install all drivers, so the program looks at it as a brand new install driver.
Try this.
Posted on Dec 03, 2008
Alps md driver error
For the ALPS printers, make sure you are using Windows XP SP2 or older. There are no Win 7 drivers and there can be problems with a Win XP SP3. Join the Yahoo ALPS group. In the files section they have a full description of the problem along with a work around. It usually is a conflict with the bi-directional communication and the LPT port. The LPT port needs to be motherboard based - not an add-on card.
I hope this works.
Nov 14, 2012 | Alps MD 5000 Thermal Printer
Is there a driver for an alps md 2300 printer for windows xp? I have tried many sites and they all turned out to be bull or busted links. Thank You. Kris
Join the ALPS Group on Yahoo. It is a great resource for ALPS users. They a file section where I down loaded a driver for my MD-2300.
Jan 04, 2011 | Office Equipment & Supplies
MD 1000 Thermal Printer: I need a driver for ALPS MD1000 printer that will ...
Go to the ALPS Yahoo Group. They have an extensive file section with drivers. Windows will use the default plug and play driver for the printer. The MS version is very limited. You should rename the MS driver to something else like "MS Alps Driver" and then install the ALPS driver you find at the Yahoo Group. These will give you full functionality.
good luck
May 16, 2010 | Alps MD 1000 Thermal Printer
Looking for driver or software for alps md 5000 printer.. i havethe printer but no software and need help ..or where can i get it ..
1st You download Printer Driver. Alps Printer Driver After this install the Printer driver in the system.
Installation of Printer Driver
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device or printer device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
Apr 05, 2010 | Alps MD 5000 Thermal Printer
Driver and software disc lost for Alps MD1000
Join the Alps mailing list at YahooGroups. The drivers are in the files section.
http://tech.groups.yahoo.com/group/Alps/
No Vista, 95/98/Me/NT/2000/XP only
Apr 29, 2008 | Alps MD 1000 Thermal Printer
NEED TO HAVE INSTALL SOFTWARE FOR wINDOWS VISTA
Apr 08, 2008 | Alps MD 1000 Thermal Printer
Alps MD 1000 self tests okay, but printing gives "nonvolatile error" (fast blink)
This is a symptom of the following:
You are running XP, and have installed SP3 and, you are using the microsoft driver bundled with XP.
The solution:
The m$ driver will have created a printer with "(MS)" as a suffix. Leave this intact, as it will cause major trouble on every reboot if you delete it.
Download the appropriate driver from the Files section in the Alps YahooGroup found at http://tech.groups.yahoo.com/group/Alps/
With your printer unplugged, install the downloaded driver
Shut down your computer and hook up the printer
Reboot
XP will detect the printer, and create a new printer in Control Panel without the "(MS)" suffix
Make the new printer your default printer.
The reason why you do not delete the printer with the "(MS)" suffix, is because every time you reboot, XP will ignore the fact that you have the correct Alps driver loaded, and will create a new printer using the m$ drivers, and set it to default. Of course, the m$ Alps driver is fundamentally broken
Nov 08, 2007 | Alps MD 1000 Thermal Printer
Alps md 1300 only prints in black
First of all, Alps MD inks do not "Dry up". They are dry to start with!
It sounds like you may be running XP, with the Microsoft driver for this printer installed. You need to load the Alps driver, which you can get by joining the alps or alpsdecal group at http://groups.yahoo.com. You can find the driver in the files section of one of the groups.
Oct 05, 2007 | Alps MD 1300 Thermal Printer
ALPS Printer MD1000 Driver
Several things about these printers.......
1. Do NOT use the MS XP driver for these - it has limited functionality. Download the Alps driver, which you can find in the files section at the Alps YahooGroup (http://tech.groups.yahoo.com/group/Alps/files/)
2. The printer requires bi-directional comms in order to feed back the printer status to the computer. While this is not an absolute requirement, it means that without bi-dir comms, the error light will flash, and you won't know what the problem is.
3. The driver is hardcoded to only communicate bi-directionaly with Alps virtual LPT ports - run this with a non-Alps cable (And all of the cables on FleaBay are non-Alps), and you will not be able to monitor the printer status.
Now, how to install.....
1. Plug in the USB cable to the computer (But not the printer), and let it install. Reboot if required (Unlikely)
2. Install the Alps driver you downloaded fron the Alps YahooGroup. Reboot if required. If you now look at Printers in Control Panel, you will see a nice Alps printer there, waiting to be used. Make a note of what it named.
3. Plug in the printer and turn it on. XP will now tell you it has found new hardware, and install the MS driver. Reboot if required
4. Go back to Printers in Control Panel. You will now see you have TWO Alps printers! The MS driver will be called something like "Alps MD-1000 (MS)". Rename (DON'T delete!) this driver to something like "Alps MD-1000 (DO NOT USE)". If you delete it, it will come back to haunt you every time you switch on the printer, and screw up your settings.
5. Open the properties page of the driver you made a note of in step 2 (Control Panel -> Printers and Faxes -> right click on printer, and select "Properties"), and click on the "Ports" tab.
6. Check the checkbox next to the port created for your USB-// cable, and uncheck the other box that will be checked.
7. Uncheck "Enable bidirectional support"
8. Click on the "Advanced" tab
9. Select the "Print directly to the printer" radio button
10. Click on the "Print Processor" button
11. Select ALMD224S as the Print processor and select RAW(FF AUTO) as the Default data type
12. Click Apply.
Sep 23, 2007 | Alps MD 1000 Thermal Printer
Alps MD 1000 Thermal Printer Logo
685 people viewed this question
Top Alps Office Equipment & Supplies Experts
Jesse Walters
Jesse Walters
Samuel Konger
Samuel Konger
Saleem Baig
Saleem Baig
Are you an Alps Office Equipment and Supply Expert? Answer questions, earn points and help others
