Question about NCR 7875
Cannot calibrate scale error 9 7876 help - NCR 7875
  • 4 Answers
Hmm... I know with the 7875, this is normally a power supply issue. But I am not sure how the 7876 gets power. 7875's have an external dc power supply brick. If you have one of those, I would swap it with another one and try to calibrate again.
Don't know if it will work though.
Posted on Dec 24, 2008
How do calibrate my scale. it is a asking for 500.0 grams of weight to do this. can i use coins? if so what
two cups of water are about 500g, 500ml of water is 500g, just measure 500ml of water, put it in no leaking plastic bag and use as a solution to your scales calibration problem, as i am assuming you will not use it to weighting 500g of d0pe or m eth, error of 2 or 3 grams will be of no importance!
regarding fixya - stupidity of censorship is astounding! d0pe and m eth in correct spelling are regarded as profanities...
Jan 02, 2015 | Home
How can you fix error on screen can it be reset
It often just needs recalibrating. Try turning the scale on while holding the mode/tare button with nothing on the scale. Then press the tare button again. It should show a calibration weight which you should put onto the scale. Then it automatically calibrates.
Nov 30, 2014 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Ozeri ZK 14, error code oVE2, what does it mean?
oUt2 means that it needs to be calibrated. I am not familiar with these scales so no sure if they can be re-calibrated.
Jan 25, 2014 | Ozeri Pro II Digital Kitchen Scale in...
My shippng scale is not working and is giving me an error. I need to know what the error is
It needs calibration. Turn it on while holding done the mode button. The display will read CAL
Let the button go and put the weight on the scale it is asking for to calibrate
If the weight is to spec it will read PASS
Turn it off and back on to use
If it still shows error it make be damaged
Sep 05, 2012 | Royal EX330 Shipping Scale 29533D
WE HAVE A MODEL 34700Z & IT IS GIVING MESSAGE WE YOU TURN IT ON ( SCALE ERROR UNIT DISABLED).REMOVED THE TANK & MANUALLY REMOVED TANK PRESSURE & DIDN'T MAKE A DIFFERENCE.
Your have to calibeate the scal.For Robinair Model-34700z scal calibration follow as bellow:
Form the main menu go to ''CHANGE DEFAULT'' then press 5454 & YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press YES key. now follow the on screen text.
NOTE:you should have 9KG/20LBS of weight for scale calibration. Do not change ''TANK TARE''. it must be on factory setup 16.30 lbs OR 7.40 kg.
Hope this will help you to solve thr problem & if my solution is useful to you please vote for it
Feb 28, 2011 | Robinair Cool Tech 34700Z Recovery,...
During tank refilling
With switch on press YES/ENTER & STOP/NO key at the same time and watch the screen to come back as normal condition. If it is the same then you have to replace SCALE assy.
After replacing SCALE assy.you must CALIBRATE the new scal before use the machine. For calibration follow as bellow:
Hope this will solve your problem & if my solution is useful to you please vote for it.
Jul 15, 2010 | Robinair Cool Tech 34700Z Recovery,...
How to calibrate seca 354???please help me...
I don't know if the 354 can be calibrated.
Here are calibration instructions for the 374. It includes a toll free number to call seca in case this doesn't work.
http://ons.wvdhhr.org/Portals/20/PDFs/policies/2.12%20Anthropometric%20Measurements%20Attachment%20-%202.pdf
May 19, 2010 | Seca 354 Digital Baby Scale Pediatric...
CALIBRATING A TANITA KD-200-110 DIGITAL SCALE.
According to Tanita, you must send the scale back to the factory to adjust the calibration. As of September 2011 the cost is $125.00
This is more the scale costs.
Moral of the story. Don't buy Tanita.
Aug 24, 2009 | Tanita 1479V - Digital Pocket Scale /...
How to calibrate a taylor scale 5571
The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight,to calibrate, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department.You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jun 13, 2009 | Taylor Body Fat Analyzer & Scale, Model...
Error 5 for ncr 7875 scale scanner
If the scanner read only two times is a problem with the communication protocol.
What protocol do you use?
Explain more about your problem with your calibration pricedure
Jul 29, 2008 | NCR 7875
Computers & Internet Logo
389 people viewed this question
Top NCR Computers & Internet Experts
Marvin
Marvin
gary433
 steve
steve
Are you a NCR Computer and Internet Expert? Answer questions, earn points and help others
