Question about Dell E773C 17" CRT Monitor
Monitor settings can't be adjusted
I just bought a second hand monitor and can't seem to get the screen dimensions right. everytime I adjust the pincushion or other settings, it does not seem to correct the problem. My screen saver looks "ok", but when I go to use hotmail, or anyother site, I can't use the red x to close, or the back button due to the fact they are not even on the screen. If I want to scroll up and down using the arrows on the side of the screen, can't be done either. I have had to "shrink" my screen so that I see everything. When typing a hotmail message, it it slanted to the left very badly.
  • bwolc Mar 23, 2008
    reinstalled windows on pc, everything is fine except monitor picture is off icons to large and pic not the same as before. have tried control panel go to display go to settings it wont do nothing, is there more i need to do since the re install.
If you will right click on the screen,select graphics properties, and aspect ratio. You can select full screen(no border. If this is a CRT, then adjust with the buttons on the front of the monitor.Vertical and horizontal.
Posted on Oct 03, 2007
    Novelist:
    Champion:
  • 202 Answers
You may need to check the resolution for your graphics card. Check the display settings in the control panel.
Posted on Jan 29, 2007
Monitor is in slef adjust mode how can i turn it off
It seems like graphics resoluation setting is changed and is beyond the range your monitor can support, what colour is the power light of monitor? as there is no model of the monitor, I can recommend to connect a bit newer version of monitor and see if the screen is on, if not then it will be graphics card settings.
Nov 13, 2012 | Dell Dimension 2400 PC Desktop
I have a 22" Hanns
Right click on the desktop, go to properties. Click on the settings tab, change your resolution settings, try a very high resolution and see if that fixes the problem. Your monitor may have an auto adjust button as well that you can try. If that is not the issue, then you may need to get the mechanical issue repaired.
Jun 11, 2011 | Hannspree 22" widescreen LCD Flat Panel HD...
Need to get screen size to show all . cant see
Things to check: Are your display settings set to "native resolution" of your screen. The native resolution is the actual dimensions (in pixels) of your flat-panel screen.
Looks like the Dell E153FP 15" has a native resolution of 1024x768. In windows, go to your control panel, in display settings, and ensure the resolution is set to 1024x768.
If that does not work, you can try the "auto adjust" feature on the monitor. On many Dell monitors, you can get this by pressing and holding the + button (on the monitor). You'll see the words "auto-adjust" appear on the screen if this works. If that doesn't work, you may be able to find auto adjust by navigating the menues in your monitor's menu, which you can get to by pressing the "menu" button on your monitor (sometimes this looks like a little rectangle icon). If it's an alignment problem, this should fix it right away.
If neither of the above work, it's probably your video card. Make sure your video card drivers are the correct ones for your card and OS, and up to date. You can also mess with display options under Control Panel > Display, under the "settings" tab, and at the bottom click the "Advanced" button, and it will bring up the advanced settings for your videocard.
Apr 23, 2010 | Dell E153FP 15" LCD Monitor
Instruction how to adjust the monitor settings fro DELL DIMENSION 2400, thanks.
what version of windows do you have if its vista or windows 7 you can right click on the screen go to personalize and you will see screen adjustment you can then fiddle about with it in there hope this helps
Mar 14, 2010 | Dell Dimension 2400 PC Desktop
Just bought Acer X203H. Hooked it up to windows Xp 2003.I make greeting cards with Print Shop 12 The cards or out of shape. They are to long horizonally and to short vertically when I am trying to design...
This is because your screen is widescreen and it is hard to get the dimensions right because when you look at the monitor, the aspect ratio is unusual. You would have to manually adjust your monitor settings (using the buttons on the side of the monitor) to make it look like a normal screen.
Nov 06, 2009 | Acer X203H bd Monitor
The view on my monitor is very truncated - about two inches top and bottom are not filled
Press the MENU button on the monitor and adjust the width and height of the picture to full screen.
Oct 10, 2009 | LG Computers & Internet
Running as second screen, drivers WILL NOT download from cd
on your display settings ehere you genreally adjust your resoultion. if you have connected 2 monitors ,you can now sww 1,2 monitors there on the sampl screen. click on the other monitor and change the resolution.
Aug 06, 2009 | LG W1934S-BN 19" Monitor
Can't get external monitor to work properly
  1. Right-click on your desktop (anywhere there is not an icon).
  2. Click Properties.
  3. Click the Settings tab.
  4. You should see two monitors with a "1" & a "2."
  5. Right-click on "2" and click enable
  6. Your external monitor should come to life.
  7. You may want to make some adjustments with the resolution, and this option is on the same screen.
Apr 23, 2009 | Computers & Internet
Onscreen controls don't respond
You have five buttons at thee right-hand bottom of your screen (just under thee edge). They are (from
left to right) the Main Menu button, the Down button, the Up button, the Input button and the Power
button (under the light).
To adjust your screen press the main menu button. Once the main menu screen is up, toggle
through it using the Up/Down buttons. Once you see what you want to adjust, move over to the
right side of the menu by pressing the Input button. Now use your Up/Down buttons to highlight
what you want to change. Once it is highlighted, press the "Input" button again. Now use the
Up/Down buttons to adjust your settings.
Once you have adjusted the settings, simply press the main menu button to exit.
Sep 10, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Monitor
On the monitor there should be an auto adjust button. Press that and it will adjust to your windows desktop.
Jun 13, 2007 | ViewSonic VE155b 15" LCD Monitor
Dell E773C 17" CRT Monitor Logo
112 people viewed this question
Clive
Clive
Alun Cox
