Question about Panasonic Lumix DMC-LS2 Digital Camera
Droped my LX2 with the lens out, the lens will no longer extend, it tries but seems stuck and out of alignmet
  • Anonymous May 26, 2009
    Thanks for the tips. My lens was tilting to one side trying to open, and tip #6 was the only thing that worked. I tapped the bottom of the camera against my palm several times and it finally came out. We'll see how long it holds up, but at least I know what to do now.
    Novelist:
  • 157 Answers
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera. The following photo illustrates unseated guide pins that would cause a lens error.
Posted on Dec 01, 2008
    Scholar:
  • 83 Answers
There's no easy fix for this I'm afraid. I had LX1 and LX2 with exactly the same problem caused by the same thing. On both the issue was due to broken plastic guides on the inner lens barrel. (The guides move in the grooves on inner lens barrel when zooming/extending). There are three guides-if just one breaks you might be able to extend the lens but most probably won't be able to focus and the lens barrel will wobble. In my case I tried various tricks to fix it, including moulding new guides and gluing them onto the inner lens barrel-none worked 100%. In both cases I ended up getting donor cameras from ebay and swapping the lenses and this is what I would suggest. LX2 is relatively easy to dismantle and put together.
Good luck,
Raf
Posted on Nov 05, 2009
Help ur self and buy a new one
Posted on Jan 17, 2009
Stuck lens on on lumix dmc-LX2
u could go to best buy but it might be cheaper to buy a new camera
Jan 13, 2010 | Panasonic Lumix DMC-LX2 Digital Camera
Lens is stuck,camera wont stay on
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 02, 2009 | Cameras
Lens is stuck
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Sep 10, 2009 | Cameras
The lens is stuck and I am getting a lens error
The number one problem in digital cameras today is the lens, impact damage, dirt, sand, pop, water or even age can kill a lens. Once the lens is faulty your camera is usually history. The sad reality is cameras today are so cheap to buy that camera techs can no longer afford to repair when a new camera can be bought for less than $200.00.
Jul 02, 2009 | Nikon Coolpix 4600 Digital Camera
After a drop lens is not closing properly, photos are dim
Jun 09, 2009 | Canon IXUS 80 IS Digital Camera
Samsung L730 wont extend lens and dosent turn on right
Try removing the batteries and memory card. Let the camera set for awhile. Put the batteries back in but not the memory card, restart the camera. Does it work know? If it does, turn the camera off put the memory card back in. Turn the camera on, does it work now? If it doesn't, replace the memory card.
Dec 27, 2008 | Samsung Digimax L730 Digital Camera
I just droped my camera and the lense isn't straight anymore, its jamned, is there anything i can do or anyway to get this fixed/repaired?
Oct 08, 2008 | Cameras
Lens stuck on i830 polaroid digital camera
Gently pull on the lens when its trying to extend, you may be able to get it back on track. This is by far the weakest point on any camera that has a retractable lens. So much that Olympus sold a lens guard/adapter for their C5050 that was basically a screw on tube that was the length of the extended lens and people bought it just to protect their extended lens.
Jan 18, 2008 | Polaroid i733LP Digital Camera
Lens stuck help anyone
if you feel that the camera is making effort to extend the lense out and the lense is still jammed, get the help of a repairer.
Sep 15, 2006 | Sony Cyber-shot DSC-W70 Digital Camera
Panasonic Lumix DMC-LS2 Digital Camera Logo
204 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
