TruTech PVS31170S1W 17 in. LCD Television Logo
Posted on Apr 04, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Black Rectangle Box appears shortly after turning on TV
A friend's child played with the remote control and ever since a black rectangle box appears mid-way on the screen. Otherwise, picture and sound is perfect.
I have noticed that at the top of the screen "TV-PG" appears which I don't think use to be there.
This trutech 13 inch TV is not used much as it just sits in our guest room and used once in awhile by guests staying in our home.
Any idea what the black rectangler black box is from and how to remove it?
I did click the menu in hopes of seeing something I could change in settings but didn't see anything that would remove it.
Please help - thanks!
Marvin
Level 3:
Top Expert:
  • TruTech Master 85,242 Answers
  • Posted on Apr 04, 2017
Marvin
TruTech Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29058526
Points
266281
That is the PIP (picture in picture) setting, on the TV's remote control. locate the button marked PIP and press the button, it should clear the little box.
5 Related Answers
A
Anonymous
  • Posted on May 01, 2008
SOURCE: black rectangle on screen
Try making sure Closed Captioning is turned off. Press the CC button on your remote.
Anonymous
  • 2559 Answers
  • Posted on Jun 03, 2009
SOURCE: Black Rectangle appears on screen for no reason
Just use your remote or the tv menu to turn off closed captioning.
Anonymous
  • 5 Answers
  • Posted on Jun 24, 2009
SOURCE: Big black rectangle in the middle of the TV
sounds like an advanced closed caption service is on. go to menu then audio then closed caption and turn off closed caption.
Anonymous
  • 144 Answers
  • Posted on Mar 30, 2010
SOURCE: our TV has a black rectangle in the middle of the
Go to the menu and turn off "closed captioning" that is likely the culprit.
Anonymous
  • Posted on Dec 05, 2010
SOURCE: Vizio VX37L HDTV black rectangle in lower right corner
Turn off the Picture in Picture (PIP) option using the remote control. I had this problem and it worked for me!
We have a black rectangle appearing on TV when playing DVDs and can't get rid of it. We were setting up to watch a DVD, pushed some buttons inadvertently on the remote and ended up with menus that we...
it sounds like someone turned on the text box on the closed caption feature on the set there may be a button on the remote or look in the set-up features in the main menu
Techman.
Zenith SL2773W problem
The dark rectangle appears because you have the closed captions on and set to TEXT. Closed captions set to CC1 puts the words on the screen and TEXT puts a black box on the screen. Go into the menu, navigate to the page with closed captions and set your captions to OFF.
2helpful
2answers
Black Box in the lower portion of the screen will not disappear
Check your Closed Captioning settings in the menu. I would bet money you have the "Text" feature enabled. Change it to OFF and you should be all set. I hope this was of some assistance.
Why did a rectangle box appear on the screen
PIP is on (Picture in Picture) either from your cable box or the TV. Check your remotes for "PIP". If you still have an issue, post a comment and I can help you more
2helpful
Black rectangle on screen
The box you're seeing is the "closed caption' box. You need to use the remote and disable CC mode on it, and the box will go away :)
Trouble viewing DVDs
I signed up for the "chat" and the problem was solved very quickly. Thank you - great service!
Unwanted black rectangle on the TV screen
I'm not sure what type of TV you are using,, but most all Large Screens have a reset button someplace. You should be able to reset the TV and fix the problem. Its not the remote, making the image appear, but a command from it was misinterpeted. Sometimes turning the set off will work, but most often it needs to be reset.
EXCEPTION... if you are using a cable box. Disconnect it from power, wait 1 minute and then see if the problem exists. If the cable box is on even with the DVD you may still have this issue. Please reset the cable, and if that doesn't work, reset the TV.
Thanks! //D
2answers
Picture Problem
Some how or some one switched on the closed caption feature in the set as thats a text box.. your going to need the original remote to turn off the closed caption.
Picture Problem
Turn off the closed caption with the original remote. If you do not have the origianal remote borrow one or buy one as you cannot remove the box or turn off the closed caption without it.
Top TruTech Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
ExpressFiX
ExpressFiX
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
