Old VCR with NTSC tuner
Once the switchover to digital takes place, will my current connection (coax from the wall - no settop box) directly into the VCR work or do I have to get a converter box?
Thanks
  • jason May 11, 2010
    is it basic cable or just an antenna? cable -- you don't need the digital box , if it is just an antenna then yes you will need the digital converter box , the vcr does not pick up the digital signals
  • 905 Answers
Is the coax cable tv? if yes then no you will not
if it is just an antenna , then yes you will need the converter box
Posted on Dec 03, 2008
I have a DMR-ES35V DVD/VCR. Yesterday I recorded a TV show on the VCR and when I tried to play it back there was only snow. The TV is also Panasonic (TC-P42S1).
The DMR-ES35V only has an analog tuner (NTSC). Most TV channels now transmit in digital format (ATSC). Since the remaining analog stations are associated with low-power tuners, the tuner may not have picked up the signal. If you have an aerial antenna directly connected to the DMR-ES35V, it probably didn't find a signal. In that case, you need an OTA ATSC to NTSC converter or a stronger signal for a station giving an NTSC signal.
However, if you tried to record from a set-top box (cable/ OTA ATSC to NTSC converter), then check your connections. Several cable boxes will not transmit the analog signal if it is also sending a HDCP signal (high definition copy protection) to another monitor. (Thus if the TV is connected to a set-top box by an HDMI cable, no analog signal is available on composite video or RF outputs.)
Please add a comment to indicate what your TV source is and whether the source is connected to the DVD/VCR and TV separately or in a daisy-chain fashion.
I hope this helps you identify your recording problem.
Mar 05, 2018 | Panasonic Televison & Video
Coax to RCA plugs
You need a tuner. For example, you might try a vcr. Most vcr's have a tuner built in, and have rca outputs. Tune the vcr to the channel of the converter box output.
Apr 28, 2014 | Televison & Video
How to record to my Sony SLV830 VCR from Sony Bravia 32" after digital switchover
You can't really record from the TV while watching something else. The only way to do that is to have two tuners. What you would need to do is get another converter box and connect that to the VCR, via the second VCR socket. But as you have a Satellite box, you will need to find a scart switching box like the one shown below (try Amazon for them).
This will allow you to connect all your items to the one TV.
Mar 18, 2017 | Sony Bravia S-series Kdl-32s3000 32-inch...
How to set up vhs taping
Most VCRs need to be connected in a daisy chain or a splitter from your input source. (You may need a tuner with some VCRs these days; either a digital to analog converter for a VCR with an NTSC tuner or a different tuner source.)
If you have analog cable or a cable box with coax out and a VCR with an NTSC tuner, use the daisy chain method. Connect the incoming cable or the coax out from the cable box to the VCR's coax input. Then connect the VCR coax out to the TVs coax input.
For a VCR without a tuner, you'll probably find a RCA composite video line in option on the VCR. Connect your cable box or converter box composite output to the VCR composite in. For an OTA source, you'll need a splitter to send the signal to both the TV and the converter box.
Most TVs do not have a video output option.
I hope this helps.
Mar 08, 2012 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Having trouble hooking up vcr
I've never seen a VCR use anything other than Composite, S-video or RF analog outputs. That's because VHS uses the NTSC or PAL analog video standards. (In the US, it is NTSC; in Europe PAL is the old standard.)
To use the Composite output, get a triple RCA cable (red, white and yellow connectors). Connect one end of the cable to Video Out (yellow), Audio Out right (red) and Audio Out (white) on the VCR. The other end of the cable goes to the corresponding Composite Video In jack and the adjacent Audio In jacks on the TV. If you are using S-video, (both units must have S-video jacks), the S-video cable replaces the Composite section of the triple cable, so you only need an audio patch cable (two RCA plugs on each end). Be sure to use the audio input corresponding to the S-video input. Note: S-video is generally better quality than composite, although HD digital is still superior.
If you wish to record from the TV, the TV must have a composite video or S-video output. This is not very common. If you wish to record programs from an RF source (cable or antenna), see the next paragraph.
In the days before digital, a typical connection scheme was to run the cable or antenna RF source to the ANT IN coax connector on the VCR, then run a short coax cable from ANT OUT to ANT IN on the back of the TV. This may not work with a digital source. Pre-HD VCR tuners would not be HD compatible, and may even filter out the digital signal in bypass mode (VCR off). You would need an HD to analog converter box at the VCR input to retain this setup. I have no information on your TV's support for NTSC video through the tuner (especially since you did not mention the model : /).
Jun 21, 2011 | LG Televison & Video
Do these TVs have tuners that allow then to pick up and view digital broadcast stations without being hooked to a cabelo or satelite system?
The Emerson LD195EM8 has both an NTSC (analog) and an ATSC (digital) tuner with an RF (coax) connector. So you will be able to watch current OTA TV without a set top box (cable/satellite/converter).
I hope this helps.
(assuming no damage to the tuners or the input jack)
Jun 06, 2011 | Emerson LD195EM8 19 in. LCD TV
I have lost the manual and would like to hook up the VCR to my TV in order to record programs. Can you help? JVC Video Cassette Recorder HR-D18OU Thank you.
Is the incoming signal OTA or cable? (If cable, is it analog (CATV) or digital (QAM)?)
Most TV's do not have a video out but you should check your TV. Assuming the usual TV with no video out, then you will need a set top box to record any program other than analog signals (CATV or a low power OTA option). The VCR only has an NTSC (analog) tuner.
For an OTA signal, take the coax from the antenna to a digital-to-analog converter coax in, then coax out of the converter to the coax in (tuner) of the VCR. Then set the VCR to channel 3 or 4. Set the switch on the converter. (Some VCRs will record Line In or Input, so you could use the composite out of the converter to the VCR.) Then coax out from the VCR to the coax in on the TV and set the TV to Channel 3 or 4 as well. Set the switch on the VCR. (Alternatively use the composite (A/V) out on the VCR to the composite In on the TV and set the input to AV1 (or whatever the TV calls the input). Digital cable will be set up like the OTA, except for using a cable set top box instead. You may want a splitter to allow for watching one program while recording another. In that case, put the splitter before the set top box if the TV has the digital tuner. Otherwise put it after the set top box. In both cases, you will need to use the AV (composite out) on the VCR to the TV.
For analog cable, take the coax cable and connect it to the VCR's coax in. Then connect the coax out or AV out to TV.
Set the VCR to the desired station and press REC. For timed record, enter the menu and set the time to start and end the recording as well as the channel. If you are using a set top box, set that to the desired station and then press record. (Leave the VCR set to Line in or channel 3 (4) as needed.)
Manuals for some JVC vcrs are here: http://support.jvc.com/consumer/product.jsp?categoryId=CATG0002&productId=PRD4600001&archive=true . A manual for a similar model will help since they all connect the same way. However the HR-D18OU is not in the list.
I hope this helps.
Feb 10, 2011 | Computers & Internet
Can't find where to hook up tv coax.
As far as I can tell your TV is just a monitor. You would have to buy a separate tuner. I had the same problem with mine and found it was cheaper just to use an old VCR. I hooked up the coax wire up to the VCR and hooked the VCR to my TV with composite cables and changed my channel through the VCR. That will only work now if you're using cable because of the switch to digital. If you're using an antenna you will need a digital tuner.
Aug 08, 2010 | Philips 32FD9954 32 in. HD-Ready Plasma...
VCR to TV
Your FIOS box is typically a Motorola Digital Cable Tuner. In order to record from the VCR your FISO will have control of the tuner, not the vcr. If your FIOS has two video outputs on it for video (av connections), one should be plugged into you tv set and the other should be plugged into the VCR input. Your cable tuner will have to be set for the channel you wish to record ahead of time while the VCR tuner has to be set to record the line input at whatever time you wish to record. If your FISO has one video output line (av connections), your VCR has to be set to channel 3 when you record (provided that is the channel your FISO box is set for when viewing TV over the coax cable) and you will have to attach the coaxial output from the FISO into the coax input of your VCR.
The only way around this is to get a splitter and split the coax line so that the FIOS is connected to the coax as it is now and the VCR is connected to a seperate line using the coax input, however using this configuration will prevent you from recording digital channels. If you have a cable ready VCR, it will probably only recognize channels up to 150.
If you really want to get it to record digital channels without the hassles find out if Verizon has a FISO box with DVR to it or connect a Tivo to your FISO. Tivo will tune the FSIO when it records and it's very user friendly to use.
Jul 28, 2008 | Sanyo DVW-5000 DVD Player/VCR
DVD/VCR Combo
your model is "tuner free" that means it does not have the RF screw in connector. Buy one that has a tuner, preferably both ATSC(USA digital) and NTSC(USA analog)
Jul 17, 2008 | Philips Magnavox DVD/VCR Dual Player
Televison & Video Logo
162 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
