Question about Sony Cyber-shot DSC-W50 Digital Camera
Recieving "Access" error on display
Camera powers on then the lens goes out and back in twice and then asks to turn the power off on the display. Cannot take pictures, but can view them. Could this be the battery? Or is the lens messed up. Would like to know before ordering batteries.
  • 6 more comments
  • paytonmail Nov 09, 2008
    Receive access error when camera is turned on. Camera lense goes in and out. Camera prompts user to "Turn the power off and on again.
  • Anonymous Nov 14, 2008
    same problem as described above
  • Anonymous Nov 17, 2008
    exactly as described by the original post. is there a solution or the lense is gone ?
  • njskypilot Nov 27, 2008
    I just received this same error on my DSC-W50. Anyone have a solution to this problem?
  • Anonymous Nov 27, 2008
    me too
  • Anonymous Nov 28, 2008
    same problem for me too
  • Jon_100G Nov 30, 2008
    my dsc w50 gives me a blank screen and "access" every time i turn it on, plus the lens extracts a couple of times before it tells me to "turn on and off" the camera, which never works. The picture viewer and menu options from the rotating dial still display on the LCD. Whats the deal?
  • wildguygoesc Nov 30, 2008
    i have the same problem
Lense i think
Posted on Feb 16, 2007
My Sony DSC-S60 camera lens in stuck open and my camera is stuck on access. It tells me turn off camera then back on. I have done that several times with no luck
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Sep 10, 2011 | Sony Cyber-Shot DSC-S60 Digital Camera
When the camera is switched on the lens goes in and out twice and then the message that appears on the screen is 'turn the power off and on again'
Turn on the camera.
May 09, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
My DSCS780 says Turn the power off and on again but, it does not turn on what should I do...I also heard you could reset the camera if so how do you do that?
The Turn off and on again error message displays when there is an internal malfunction or a malfunction with the Lens. The error message normally displays with the issue with the Lens. Try the following steps to check if the issue can be resolved.
Try power resetting the Camera.
Turn off the Camera.
Press and hold the power button for 15 seconds.
Then, allow the Camera to remain without power for 60 seconds.
Re-insert the battery pack and check if the Lens retracts.
You can also try resetting the Camera back to factory default. This can be done only if you're able to access the Menu of the Camera. To reset the Camera back to factory default, select the INITIALIZE option from the Setup 1 Menu of the Camera to OK. (Menu-->Setup-->Setup 1-->Initialize-->OK.)
This should resolve the issue. If the issue persists, service may be required.
Thanks for using FixYa
Jan 18, 2011 | Cameras
When I switch on the lens goes in and out a few times but no viewing screen. It asks to be switched off and then on. I can view stored pics but it won't allow me to take any?
· Turn off the camera.
· Remove the battery pack.
· Press and hold the power button for 30 seconds.
· Allow the camera to remain without power for 60 seconds.
· Reinsert the battery pack.
· Turn on the camera.
Thanks,
KenSolutions
FixYa
Oct 21, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Camera shuts off even with new batteries
"E18" indicates an error that involves the lens unit or lens cover in your camera .This error appears where the lens is prevented from properly extending or retracting .The error may also be displayed if the lens camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.Hold the camera so that your fingers do not touch the lens unit when you are shooting. Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service from canon.Or else try pressing the power button on and held it down while extending the zoom lens. The lens will extend out and the camera will be freed from the error.
Thank you !!
Jul 12, 2010 | Canon PowerShot A95 Digital Camera
When i turn the camera on, the lens goes in and out, and then there is a message on the camera saying, "Turn the power off and on again". I do this and I still get the same error message.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
Thanks for contacting FixYa.
May 11, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Turn the power off and on again message
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
E 18 error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 02, 2009 | Canon PowerShot S2 IS Digital Camera
Error C:13:10, displays ''access'', ''turn the power off and on agai
Lens jams can happen without dropping the camera. The lens motor is bad, or a grain of sand has got stuck in one of the lens cogs. Either way will need lens repair/replacement.
Nov 12, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Digital Camera Fault
ACCESS error could happen when lens gets stuck but if it happens when lens moves back and forth without problem it usually means that where the lens assembly plugs into main system board connection is loose. These connections are held in place by a very small thin fragile plastic clip and a few drops could be enough to snap it but not do any other noticeable damage to camera. Camera would need to be opened to see if clip is broken or maybe cable just needs to me reinserted. Either way only open camera if no longer under warranty and you are somewhat handy
Mar 20, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
194 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Terry Weaver
Terry Weaver
Are you a Sony Camera Expert? Answer questions, earn points and help others
