Question about Sharp Vacuums
I want to replace the hose but do not want to buy the handles, where could I buy the hose for Sharp part number 9HMSHPPAR7430?
    Scholar:
  • 55 Answers
Man that stinks burden.
Here's the deal. Sharp quit making vacuums and parts because, the same factory they were making the vacuums in, they were making regular T.V.'s in, and they decided to focus on the flat screens, thus it wasn't in the cards to keep the factory open. At least that's the way I understand it, and that's why you're having trouble getting the part.
The only thing you can do is call around to independent dealers and try to find it. A lot of times the ones that have the space will save spare parts, but the part numbers are not going to be on the parts, so that won't do you much good. You'll probably have to take them the those hose or the machine so they can see it, to make sure they have the right one, or if the tech is really good he may know that model and right hose off the top of his head.
Sorry I don't have a great answer for you, but I help people find stuff like that all the time, hopefully someone close to you will do the same. Good Luck
Posted on Dec 01, 2008
Top coupler on gas pump handle ONLY (Majestic 360 SS) is broken. Do we have to replace whole hose and handle assembly?
They now make a replacement tab so you don't have to replace the entire handle grip. The bad part is, most of the time it's the handle grip that has the broken place in the plastic, not the latch tab. That too can be bought seperately though, so you don't have to buy the hose. Call your local vac shop for assistance.
Oct 21, 2014 | Filter Queen Majestic Canister Vacuum
Riccar model 1700 hose broken near where it enters the handle. How can I open the handle to repair the end of the hose?
more than likely you can just take it into your local guarantee vacuum and sewing center and they will tell you the cost and get the part for you
Mar 24, 2014 | Riccar Vacuums
How to replace vacum belt on new Sharp EC-TU5306
remove bottom plate and pull brush roll out. buy a replacement belt and follow procedure to put back on. sounds like you have a clogged hose also.
Jan 29, 2013 | Sharp EC-TU5306 Bagged Upright Vacuum
Repairing contacts in Electrolux Z8240 handle
Hi There, Alec From VacuumSpot here. I work as a vacuum technician and unfortunately I am the bearer of bad news the handle is not really repairable. Even in warranty Electrolux allowed us to simply swap the hose over in favour of any repair. If you need to buy a new Z8240 hose the part number is 1131404541.
Nov 27, 2012 | Electrolux Vacuums
My dyson 17 wand does not work. When it is on and you stand it upright it turns off
Hi its Darran at Dyson.
If the suction is good from the base but not from the wand, this would indicate that there is a blockage in the wand handle or hose. To test this, stand the machine upright and release the wand handle. Switch the machine on and test the suction from the top of the wand with your hand. If its poor, remove the wand handle from the hose and try the suction at the top of the hose. If its good here, then there is a blockage in the wand handle.
If the sction from the top of the hose is poor, you can remove the hose to check this for any splits or blockages. If it needs to be replaced, you can buy a replacement online at www.dyson.com.
Alternatively, should you any further help or advice with your Dyson, please contact our Helpline on 1866MYDYSON.
Kind regards
Darran
Dyson Customer Service
Jan 25, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
I jammed a deodorant cap into the entry hard plastic part of the hose. can I open that up to get it out?
What goes into a vac hose enters the smallest part. The handle is designed to be a small reducer to prevent some blockage so the obstruction must back out. Do not attempt to use a sharp coathanger as you could tear the inside of t the hose and do not attempt to push the cover deeper as it will wedge tight. Your best bet is to draw this item back out with another vac. Sometimes bumping,( not smashing) the side of the handle against a carpeted floor area while doing so will help dislodge the item. Failing that you will need to open the handle itself.
If you look closely on this hose there are several small screw covers which will pop out with a pin to reveal hidden screws. Once removed the handle will open like a **** shell and then slide off the hose. The handle must be carefully aligned when reinstalling and the wire covers installed last, with the handle fully in place.
If all else fails and you must use a wire coat hanger, create a small 190 degree hook at the end so there is no chance of a sharp edge cutting the hose itself if pushed to far. Post back with results or if you need more help
Oct 28, 2009 | Electrolux Guardian Bagged Canister Vacuum
Replace interior hose for cleaning attachment for Hoover Steam Vac Agility
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=632107
Replace interior hose for cleaning attachment for...
Posted by castcomm on May 29, 2008
How do you dismantle handle to replace aforementioned hose?
Swing arm on unit goes all the way to the floor. Is this normal? Is there a "stop" broken that caused the hose to stretch, and ultimately break?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac Carpet / Upholstery Deep Carpet Cleaner.
There are handle screws that you can get into the handle and then you can back track the replace the interior hose for the cleaning attachment. There should not be a stop that caused the hose to stretch ad break. The hoses after a while do get old crack and break due from normal use or if the bend @ sharp angles, this is common among all vinyl vacuum cleaner hoses. You should really check with your local factory authorized Hoover vac dealer in your area or , please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 29, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Electrolux Renaissance Hose Replacement
Notice how the hose has a groove just around the outer edge of the gray plastic near the white plastic insert. The hose is held into the handle buy two "tongues" inserted into this groove. One of these tongues is on the end of the top plastic piece of the handle. The second is on the piece of plastic that is slid into the little hole at the base of the handle and it is visible in the picture.
To remove the first, you'll have to remove the two screws in the top of the handle that hold the top plastic piece. This can be a challenge unless you have the right tool. It's essentially a hex-star allen wrench tool that is required, I'm guessing about 1/16 inch. I had one in my tool box that fit. Remove the screws and pop the top plate off. This frees the first tongue from the groove. Now, just get a screw driver (or use your finger) to press the plastic piece inserted in the hole at the bottom of the handle. Press from the "t" side and this should slide right out. Now your hose will slide right out of the handle and you can replace the old with new. Re-insert the small plastic insert, and refasten the top plastic piece of the handle and you're good to go.
-DB
Dec 04, 2007 | Vacuums
Broken Handle Release Pedal
what is part number for broken pedal release
Oct 29, 2007 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
Vacuums Logo
336 people viewed this question
Top Sharp Vacuums Experts
jasbo
jasbo
Mike
Are you a Sharp Vacuum Expert? Answer questions, earn points and help others
