Question about AIGO DIY MP3 Player
My mp3 won't play songs
My mp3 player won't play any songs, since it says that there aren't any songs on there. wen i go on navigation it shows loads of files but there isn't any music on them. and worse it says that my memory is being taken up. and when i try to put on more songs it just says that there aren't any there. what do i do?
  • sarflo Apr 17, 2008
    I have had the exact same problem-in navigation it showed the names of the artists as a folder but these were empty when I tried to play them-it would only play about 14 other tracks. What I tried this morning - and it seems to have worked-is copy the tracks individually from where they are stored on my pc using the right click and send to removable disk,instead of making a playlist on Windows Media player and then syncing it to the MP3 player. Don't know why or how this has worked but my 8 year old is now very impressed with me!!
  • claire T Apr 17, 2008
    my problem was the same as sarflo. but i still can't navigate. have i a duff MP3 player? my son can't get it to navigate properly & he is studying to be an ICT network manager!!!!
You need to convert your mp4 to mp3 i had smiler problems with my mobile
Posted on Dec 04, 2008
SOURCE:
Tip
It sound like similar problem I had with Coby MPC896 playing only 27 songs of...
I have a stunning new breakthrough on the frequently cited problem - "I cannot add any more songs to my Mp3 Player." Before we proceed, I am assuming that the reason you cannot add any more files has nothing to do with available memory space. Of course, if your Mp3 player is full, it will not accept any more songs. But, I am assuming that this is not your problem.
Apparently, if you add too many folders, especially via Playlist, via Windows Media Player, the Mp3 player's file system will become unstable - it can only handle a certain number of additional folders.
To resolve the issue:
1. Connect the player to the PC using the USB cable.
2. Open Windows Media Player.
3. Go to the Sync or Devices tab and delete all content from the player.
4. Go to the Tools menu and select Options.
5. Select the Devices tab, highlight the ILO or Siren player and click on Properties.
6. Uncheck the box "Create Folder Hierarchy on Device"
Now, when music is transferred, it will be placed in the root directory of the flash memory disregarding the folder structure and allowing all tracks to be seen.
This procedure was designed for Siren Mp3 players, but is applicable to many other Mp3 players. It is not a guaranteed fix for every Mp3 player and every error of this type, but it is certainly not a widely known or reported solution. i hope that this benefits many Mp3 player owners who are experiencing this issue.
-Tha Mp3 Doctor
on Dec 10, 2008 | Philips GOGEAR SA6045 MP3 Player
The mp3 only plays about 40 songs on a 2 gb card. Plus i drag music files over only some download from ITunes
The reason only some songs are playing is because the other songs aren't in a format that it recognizes. Make sure all the songs are in mp3 format, if they're not you can get programs that will convert any song into mp3. If you need more help let me know =)
May 14, 2011 | Harley Davidson Road Tech HA90 MP3 Player
If we add songs to mp 3 player it won`t show songs when it on
MP3 players can only play music files that have been converted to mp3 file format. For instructions on converting music file, please click on this link and follow my instructions :-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Nov 08, 2010 | Sony NW-E405 MP3 Player
Can't create a playlist on rca pearl mp3 player; it wants to play all songs by genre, etc. additionally, it won't even ''import'' certain songs.
Step 1. Put the playlist in a regular Windows folder on your desktop.
Step 2. Open a window for Window Explorer and navigate to your Rca Pearl which should show up as a portable USB device.
Step 3. Open the Explorer window for the device and navigate to the "music" folder.
Step 4. Drag and drop your playlist folder that you created into this folder.
When you navigate through the pearls songlist the name that you gave the folder will show up AND all the songs in that folder will play in order...... DONE!!!
Apr 03, 2010 | RCA Pearl TH1102 MP3 Player
Video songs
this is because your mp3 player isn't meant to play video songs. its an MP3 player, meaning it won''t play AVI video files.
Jul 28, 2009 | SanDisk Sansa e250 MP3 Player
Sandisk 240m mp3 not playing
the radio and mp3 uses one audio amplifier, check if you have loaded your music with mp3 songs, if not load with mp3 songs. if songs used to play and just stopped playing, then follow these steps,
i does your display show song playing, if it does then your set is fault, and if it doent and display unsuppoted, load with mp3 songs.
ii if it was playing and just stopped, than take it to a tech, who can open it and check the change-over switch, or selector of that set.
iii the problem is to very big.
Mar 30, 2009 | SanDisk Sansa m240 MP3 Player
I've downloaded songs but they don't show up on my player
Each mp3 player can only play songs in certain formats. A Philips GoGear, for instance, can't read iTunes format. Some players cannot read DRM-encrypted WMA files, which is what most music services use. When you load a song in the wrong format to an mp3 player, the song appears to transfer, but the mp3 player won't actually play it. The best workaround for this problem is to only load songs that are in true mp3 format - they are accepted by 99% of digital audio players. If you give us your manufacvturer/model #, and music service name, we can tell you exactly which formats your player plays.
-Tha Mp3 Doctor
Jan 02, 2009 | Audio Players & Recorders
Shoqbox not playing or showing song loaded
Make sure you have the version of the Musicmatch from the Philips website first, and try again - Musicmatch discontinued their service in Oct 2007, making this particular Philips mp3 player obsolete.
Also, make sure the files you are trying to load are in Mp3 format specifically - this player cannot take DRM-encrypted WMA files.
Jun 09, 2008 | Philips PSS110/17 MP3 Player
Shuffel not playing
Forget the itune software. Download everything free via bittorrent and put it on your player using windows explorer.
Oct 06, 2007 | Apple iPod shuffle MP3 Player
AIGO DIY MP3 Player Logo
321 people viewed this question
Top AIGO Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an AIGO Audio Player and Recorder Expert? Answer questions, earn points and help others
