Can't install super soho pack keep getting NTVDM:exe a problem has caused the software from running. (this comes up right when you click the startup exe file to install)
    Genius:
  • 1,061 Answers
Http://www.file.net/process/ntvdm.exe.html GO HERE YOUR PROBLEM AND SOLUTION ARE EXPLAINED.DO NOT FORGET TO RETURN HERE AND VOTE FOR THIS IF IT HELPS SOLVE YOUR PROBLEM.TY RICHARDM69
Posted on Dec 02, 2008
Qx3 microscope driver for Windows 8
Here are the instruction for installing the QX3 (or QX3+) Microscope with Windows 8 and Windows 8.1. You must be using a 32-BIT VERSION of Windows 8 or 8.1.
Note: The QX3 is not compatible with 64-bit versions of XP, Vista, Windows 7 or 8.
Note, DO NOT use the software from the CD that came with the microscope.
DO NOT plug in the QX3 microscope until Step 4.
Step 1. Download and run the QX3plus.exe program from:
http://tinyurl.com/QX3-Win8-1
After the program installs, uncheck "I would like to view the README file." Click "Finish".
Step 2. Download and run the qcodinstl.exe program from:
If asked about NTVDM, click "Install this feature" then click "Close"
Step 3. Download IntelQX3driverXP.zip and save (do not open) the file from:
Step 4. Now, plug in the microscope. The driver should load silently.
If the "Found New Hardware" wizard appears and you get a message saying that the driver installation was not successful. Click the Close box. You need to install the driver manually by following these steps:
a. Right-click START - Select "Device Manager"
b. Right-click on the Intel QX3 Icon and select "Update Driver Software", select "Browse my computer for driver software"
e. Browse to the Download folder with the extracted QX3 drivers from Step 3. above. The driver software should install successfully.
IMPORTANT: Before you run the QX3Plus program for the first time, right click the "Intel Play QX3 Microscope" icon on the desktop, click "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose "Windows 98 / Windows ME" in the drop-down box. You should also check "Run as Administrator" if your account is a "Standard user". Click "Apply" then "Ok".
Step 5. Finally, double-click the "Intel Play QX3 Microscope" icon on the desktop and the program should run.
If you get a message that the microscope is not plugged in, quit and restart the program.
If the program hangs or crashes, reboot the computer, then restart the program.
Comments and suggestions to mmehall [at] yahoo.com
Apr 05, 2014 | Intel Play QX3 Monocular Microscope
Reinstallation of nero 12 in same pc
Try this-
run msconfig.exe.
In the services tab, check the box to hide all Microsoft services, then, check the box to disable all services.
Under the Startup tab, check the box to disable all startup items. Reboot.
Right click on the .exe file for installation and select "run as administrator". Try the installation.
Whether it works or not, go back to msconfig.exe and restore everything back to normal and reboot, as soon as possible.
Nov 11, 2013 | Nero Software NERO Download - Nero 12...
Having WZCSLDR2.exe & AirGCFG.exe error at startup after installing xp service pack 3
Someone commented "If you re running windows XP with service pack 3 then make sure you are running the most updated driver for your d-link NIC, otherwise you may get an error on windows startup about WZCSLDR2.exe" here: http://www.file.net/process/wzcsldr2.exe.html
Jul 02, 2010 | D-Link AirPlus G DWL-G122 802.11g/b...
Ntvdm cpu encountered illegal operation Hi all! I just installed Maya 2010 from a torrent file and since then I got this famous error message. It's just appeears as three command prompts appearing at the...
If I am reading this right your issue is not the application but where you obtained the application. Maya 2010 is a modern design application and comes in 32 & 64 bit versions. It is not a 16 bit application.
When Windows encounters a legacy application it calls the NTVDM for the legacy application to run in.
The fact that the application is calling the NTVDM is highly suspicious. NTVDM is the NT Virtual Dos Machine, a way for legacy applications to run in NT environments.
NT environments are Windows NT 3.5, NT 4.0, Windows 2000 Professional, Windows XP (Home, Pro & Media Center Ed), Vista (all versions) and Windows 7.
Old (legacy) applications written for 16 bit date back to Windows 3.1 and include Windows 95, 98 and Millennium Edition.
I would obtain a copy of Maya 2010 from a reputable outlet instead of Bit Torrent as "warez" frequently contain malicious items that will infect and ruin your machine.
Feb 05, 2010 | Microsoft Windows XP Home Edition
I am getting error message for win32 generic host data executor prevention
Here is my resolution to the error
SVCHOST.EXE GENERIC HOST PROCESS OR
DEP ERROR
IT DOES NOT INCLUDE
DISABLING WIA
OR
DISABLING DEP (which is a good security feature)
I have tried it on upto 3-4 computers with success and complete software functionality
Turn the All in One Off
Uninstall the whole of the HP software on the computer
Run a level 4 uninstall
Start --> Run -->X:\Util\CCC\Uninstall L1.bat
Start --> Run -->X:\Util\CCC\Uninstall L2.bat
Start --> Run -->X:\Util\CCC\Uninstall L3.bat
Start --> Run -->X:\Util\CCC\Uninstall L4.bat
Restart the computer
Check the computer on the restart
Check if you still get an SVCHOST.EXE GENERIC HOST PROCESS OR
DEP ERROR on restart
Start --> Run
Type in Msconfig
Click OK
Click Launch System Restore
Run System Restore
Create a Restore Point named Hp
Click Start --> Run
Type in Regedit
Click OK
Open Registry Editor
Scroll to the following Registry Key
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentV
ersion\Explorer\
RemoteComputer\NameSpace\2227A280-3AEA-1069-A2DE-08002B30309D
Right click on this Key Click Export
On the Export Registry Window which comes up
Type Hpprinter as the filename and save it on the desktop
Get back to the same Registry Key
Right Click the Key and Click Delete to remove the key
THERE SHOULD BE NO DEP ERRORS THIS TIME
(IF you have any issues after deleting the above key <possibility is remote> restore the computer back to the Hp restore point)
Reinstall the Hp printer Wirelessly or on a wired network now the usual way
Once the software installation finishes
Verify functionality
NOW
Right-Click My Computer, then click Properties.
On the Advanced tab, under Performance, click Settings.
On the Data Execution Prevention tab
Click Turn on DEP for all programs and services except those I select to select the OptOut policy, and then click Add to add the following programs
Create an exception in the DEP for the following programs by browsing to the correct location. The following list outlines the locations:
Hpcmpmgr.exe (x:\Program Files\HP\Hpcoretech\hpcmpmgr.exe)
HPwuSchd2.exe (x:\Program Files\HP\HP Software Update\hpwuSchd2.exe)
HP Digital Imaging Monitor (hpqtra08.exe) (x:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe)
HP Image Zone Fast Start (hpqthb08.exe) (x:\Program Files\HP\Digital Imaging\bin\hpqthb08.exe)
Generic Host Process for Win32(svchost.exe)
(c:\windows\system32\svchost.exe)
Add all these files one by one by browsing to the locations
Click Apply and OK
Let the computer restart if prompted
Its also at times needed to disable
from the Startup of the computer in Msconfig
Hpcmpmgr.exe
HPwuSchd2.exe
The reason is the above mentioned exceptions to the Data Execution Prevention are loaded after the Startup loads and the DEP may try to shut them down at the startup itself and generate the errors
Unchecking the above files does not mean losing any functionality on the All in One all the features should work properly
Jan 21, 2010 | Dell Inspiron 6000 Notebook
16 bit MS-Dos Subsystem Turbo C++ IDE The NTVDM CPU has encountered an illegal instruction cs:0000lp:flboop:of00640352 choose close to terminate the application
I too have a problem on my PC,when running the Turbo C programThe error message is:
16 bit MS Dos Sub system
turbo c++ IDE the NTVDM has encountered an illegal instruction.
At last i found the solution, and it is simple.
After installing your turboC follow the steps..
1) go to TC directory and open BIN.
2)In "BIN" folder you can find "tc.exe". Right click on "tc.exe" and click properties (and make sure that do not click on shortcut of TC.exe).
3)In properties there should be a tab called "screen", In that you will find "usage" option. There.. select "window" option instead of "full screen".
4) Then click "OK".
5) Now click "TC.exe".
6) It will open in window mode, if you want you can change full screen mode by pressing "ALT + Enter".
Thanks & Regards
Shravan reddy Konnela.
Jun 02, 2009 | Microsoft Windows XP Professional with...
EXEPTION PROSSESING MESSAGE
tech support guy forum "I'm willing to guess it is being caused by a program called dit.exe which is installed by some card reader software to allow you to name the drives and for them to have individual icons.
It runs on startup and is a pretty much useless process.
Initially you should test to see if it is causing you problems.
Run msconfig and if it appears in your startup list disable it and restart
if that solves your problem then delete dit.exe from your windows folder (you can also get rid of dit.dll, dit.ini and ditxp.exe)
You should now do a registry sweep to get rid of any dit.exe entries
Hope that fixes the problem for you"
cheerz. let me know how did you go thanks
Apr 15, 2009 | Microsoft Windows XP Professional With...
The ntvdm cpu has encountered an illegal instruction
I took this from another web site:
Michael Chiew said:
What did you do before this happened? What were your last deeds on the machine before the pop-up appeared?
I think what you're referring to is NTVDM CPU, not NTDVM CPU. Am I correct?
What do you know about 16-bit and 32-bit applications? Well, 16-bit applications are those that must work within the DOS (Disk Operating System) environment, a real-mode arena. NTVDM stands for NT Virtual Dos Machine.
In Windows XP, as in Windows 2000, or Windows 98, there are 16-bit and 32-bit environments (real mode and protected mode respectively).
Windows XP can only operate in 32-bit mode. All 16-bit applications must work within its own theatre of operation, typically, the first MB of physical memory (ram). Conversely, 32-bit applications must function above the first MB memory line. If either of these applications happens to slip into "alien" territory, you get an error message like "something" has encounter an illegal instruction. In other words, the wayward application is trying to slip by the immigration checkpoint.
In your case, updatemgr.exe (I suspect updatemgr.exe is a 32-bit application) has in all likelihood wondered into the 16-bit arena. Hence, NTVDM CPU issues that warning.
Why do you continue to get the message. It's because updatemgr.exe incessantly misbehaves itself on start-up, always trying to load itself into a particular memory address where it is not welcome. Why the persistence? Updatemgr.exe has gone bonkers. It is either corrupted or damaged.
On the other hand, one cannot discount the possibility that NTVDM (NTVDM.EXE) is corrupted or damaged. So your problem lies with either updatemgr.exe or NTVDM.EXE, or both.
There are 2 things you could do.
First, establish who owns updatemgr.exe, Microsoft or some third-party owner. Second, rename updatemgr.exe and see whether the message goes away.
To establish ownership (and the function of updatemgr.exe), do a search for the file.
Click START, select FIND. In the FIND dialog box, type: updatemgr.exe. See the directory in which the file has lodged. In Windows Explorer, get to the file, right-click on it, select PROPERTIES. Who owns it? Is there an indication of its function.
Next, rename the file. Right-click it, select RENAME and rename it to, say, updatemgr.old. RESTART your computer. Do you still get the error message. Not likely.
To clean things up a bit, perhaps it is a good idea for you to replace the current NTVDM.EXE with a new copy. Find out where NTVDM.EXE is. Then, click START, select RUN. Type in the RUN dialog box SFC to run the System File Checker. Insert your OS CD, follow the prompts, extract a copy of NTVDM.EXE and send it to its place of residence. Of course, you should also replace a copy of updatemgr.exe.
That should eliminate your problem for good.
Dec 25, 2008 | Microsoft Windows XP Home Edition
Ntvdm.exe
boot to safe-mode - goto start then run and type msconfig -
Within Msconfig you should see a startup tab. Look in there and remove or uncheck all that appear to be using ntvdm.exe
Also check in start, programs, startup, remove anything there as well.
Let me know if that does not help.
G'luck
Oct 23, 2008 | Computers & Internet
VISTA:The NTVDM CPU has encountered an illegal instruction
The link below is a step-by-step troubleshooter from the Microsoft website. You'll just need to follow all the instructions on the site and you should be able to fix it all by yourself. This seems to be a common error with windows.
Troubleshooting NTVDM and WOW Startup Errors
Sep 10, 2008 | Computers & Internet
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
