Question about Toshiba REGZA 47HL167 TV
How to change my aspect ration from 4:3 to 16:9 using remote
My TV model is : Toshiba REGZA 47HL167 TV
  • 1779 Answers
SOURCE: THE TV WILL ONLY DISPLAY THE ASPECT RATIO 4:3
On that model set you must use the Component input (1) which will give you the ability to change the format. If you are using A/V sources, they will accept 480i. So, in short you can get away with using the DVI input as long as your cable or satellite receiver has them. My recommendation is to always use the COMPONENT INPUT with the jack colors of Red-Green-Blue. Don't forget to connect the Audio input also.
Posted on Nov 26, 2010
mbelectronic
  • 147 Answers
SOURCE: my tv wont turn on
yes he is right.the digital main pcb is the brain of the tv and has the microprocessor which
controls unplugging the tv and plugging it back in.you are resetting the micriprocessor which is part of the digital pcb.
Posted on Jul 17, 2009
  • 11 Answers
SOURCE: I have a Toshiba Regza 42A3030D TV but no manual.
Paid for only:
http://www.user-manuals.com/advanced_search_result.php?keywords=42A3030D+manual&forward=plist
Or try eBay.
Posted on Sep 13, 2009
  • 115 Answers
SOURCE: 47" Toshiba Regza 47HL167 - No picture but with sound
My guess would be to suspect the inverter. but from what i can tell that model had two possile inverter types used during production.
toshiba P/N 75008432 Rev C3
AND
75008433 V470H1-L
Posted on Oct 06, 2009
Testimonial: "Thank you.. I will look into that."
SOURCE: my toshiba regza remote will not operate the tv at
check to see if it is set to vcr or dvd at the switch on the top left corner.
Posted on Oct 21, 2009
How do i turn the Panel lock function off on my Regza 42xv600a without the remote?
This may not be possible; it may be designed to prevent children from operating the set without an adult with the remote present.
You can probably buy an original remote or a known substitute from:
Remotes.com
Sep 10, 2011 | Toshiba REGZA 47HL167 TV
How do I change the resolution on my 47HL167 Toshiba TV?
Not knowing the model right off but they are all basically the same it is on the on-screen menu.
Mar 28, 2011 | Toshiba REGZA 47HL167 TV
TOSHIBA REGZA 24" LCD/TV cannot
"JUST PRESS CINEMA MODE ON YOUR REMOTE CONTROL AND SELECT APPROPRATE VIEWING MODE" it might be located under the left of 0 with an image like stretching as indicated on my remote. It is the issue about the overscanning and underscanning of tv using HDMI connection. I have been the same problem as you but I did solved it using this. Hope this would help!
Mar 10, 2011 | Toshiba REGZA 47HL167 TV
NEED TO GET A MANUAL FOR A TOSHIBA 37 tv AS I HAVE MISLAID THE MANUAL
MANUAL FOR: Toshiba REGZA 47HL167
go to : http://www.manualnguide.com/dl/10402/
you can view or downlaod the manual for free
Dec 29, 2010 | Toshiba REGZA 47HL167 TV
Can i play movies off a USB in the tv's USB port, if so, how ??
OK, well I have used this many many times. You simply need to copy the Movie in any of the Formats that the set can use, and copy the Movie to the USB stick. When the stick is inserted, using the remote you simply "Select" that "USB Input" and select the Movie, and select "Play", IF the right Format, has been used, the Movie will "Play" as if it was a DVD.
Consult your manual. link below.
http://www.tacp.toshiba.com/dvd/product.asp?model=47HL167
Jul 21, 2010 | Toshiba REGZA 47HL167 TV
How do I remove the stand from a Toshiba TV 19DV616DB
Mine isn't exactly the same model (I've a Toshiba Regza 32AV615DB) but on mine there are 4 small black screws at the back of the TV, near the lower edge. They're recessed into channels and quite difficult to see. Remove these 4 screws and you can lift the TV off the stand. Good luck.
Jan 15, 2010 | Toshiba REGZA 47HL167 TV
Toshiba REGZA 47HL167 TV Logo
396 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
