Question about Sanyo MM-8300
Text messaging on a Sanyo MM 3800
My cell phone, will not receive messages from nextel or cincinnati bell phones. I can send them messages but I can not recieve them. Help!!!!
4 Suggested Answers
  • 9 Answers
SOURCE: keys won't work on sanyo mm 8300 phone
I used a very small eyeglasses-repair flat-bladed screw-driver that was the same width as one side of the tri-angle screw head to remove the screws on half of a sanyo scp-8300 phone that I found on the road. I do advise caution when releasing the hidden plastic clips around the edge of the phone where the seam between top and bottom is. Once open, you will find a ribbon-cable that leads to the top half of the phone, a rubber pad that has all the keys on it, and the phone's circuit-board, where there is a white plastic sheet overlaying the actual physical buttons mounted on the circuit-board. My advice would be to gently clean the rubber key-pad with warm water and dish-soap. Also, check for sticky gunk around the edges of the key-holes in the plastic case of the phone, if you find some- carefully wash it off with a wet tissue or a cotton swab, use rubbing alchohol if it won't clean off. But, be aware that some plastic can melt or turn gooey when cleaned with alchohol, or it might just remove the color from it. Hope this helps, TechnoWolfy.
Posted on Jul 08, 2008
SOURCE: Can't delete recent text message contacts on Sanyo phone
I have the same problem. I called Sprint and they said the only way to get rid of the recent text message contacts is to completely erase the incoming calls you have. Don't know if that includes locked ones, too, but I'm trying it now (I have one locked message). Will let you know.
Posted on May 25, 2009
  • 7 Answers
SOURCE: Can you recover deleted text messages from an
no you cant
Posted on Oct 09, 2009
SOURCE: need internet access to katana 3800 user manual
Posted on Dec 07, 2009
0 characters
1 Points
How can i download pictures from lg cu920 to my pc, i have cable but not work, can i insert mirco sd card to store the pix i took and burn a dis.
Well, I think iPubsoft Android Desktop Manager works very well, I often use it transfer my android phone photos to computer. By the way, you can also use it transfer other kind of files, like contacts, photos and so on. Read this guide to know how to use it:
How to Download Copy Photos Videos Between MEIZU and Computer
Sep 17, 2011 | LG Vu CU920 Cellular Phone
Send an email to you cell phone that comes in as a Text (SMS) message.
If you have someone, or if you decide, that you want someone to be able to email your phone and have it come in as a text message. Or for anyone without email on their phone, the email address of your text message box is:
Virgin Mobile:
where phonenumber = your 10 digit phone number
Give it a try and see for yourself!!
on Dec 28, 2009 | Cell Phones
I had an old nextel phone it was a i730 and i had to go on the internet on the phone every time i got a text message and i just got a i290 and i still have to go on the internet to send and receive text....
The Text messaging on the I290 is based on Java technology the requires you to go use the web portal..
Newer phones like the i776, i465,i410,i9,i856 no longer require that...
May 20, 2010 | Motorola Mobility Boost i415 Cellular...
How to send a text message without my number showing up on the other persons phone
go to settings then go to display then go down to text settings or whatever it is called then change it
Mar 30, 2010 | Verizon Communications Samsung Alias Cell...
Trying to send a text message from the nextel I710 motorola phone but text message is not an option under messanger center list how do i send text?
To send a text message for the i710, you may need to go to WEB, and go to send text message, there should be an option for this. Recommended that you get a texting package, due to it may run $0.15-0.20 per text. Let me know how it goes,
Please Rate Me :)
Jan 09, 2009 | Nextel i730
How to unlock text messaging on nextel phone i 580
How to block/eliminate any text message coming to my Samsung Stripe cell phone?
May 07, 2008 | Cell Phones
SMS is Short Message Service. This is coming from a email address. you can send your self one to. to send a normal Test alert via email send it to were you see the 0000000000 put your Nextel number.
Apr 15, 2008 | Motorola Mobility i880 Cellular Phone
How to text message on a i730 nextel
i cant text at all on the nextel i730.idk how to get started on it
Feb 20, 2008 | Nextel i730
Nextel i850 Can't send/receive text messages - says
i have the same problem...
but have no idea how to fix it
Oct 20, 2007 | Motorola Mobility i850 Cellular Phone
I530 text messaging issue
To be able to send and reply to text messages you must have NOL net access. Press menu(left of the left arrow key), scroll to net, press ok(if an error message appears contact nextel for internet service), scroll to text messaging, press ok. From there you can write, read and reply to text messages. The reason for having to do it this way is because this phone as well as others with nextel were being produce when text was first being introduced to nextel, at that time motorola wasn't making nextel phones with the option of text, so it was up to the provider to give text access(via. net).
Sep 25, 2007 | Motorola Mobility i530 Cellular Phone
Cell Phones Logo
35 people viewed this question
Top Sanyo Cell Phones Experts
Jose Cada
Jose Cada
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
