SOURCE: The 'Smart Wash', 'Heated Dry'
Hi To
resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat
Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub,
energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run
for 2-3 minutes and then you press the Cancel/Drain button and allow it to
completely drain and reset. If this doesn't work then it's an issue with the
wash pump not pumping the water past the heater efficiently or due to lack of
water to heat. Please make sure that heater is not open circuited and is
heating the water efficiently. You'll have to check the heater using a
multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on
Rx1 ohm setting). If heater is fine then make sure water pressure is optimum
and fill valve is working fine. Hope this helps...please post back
for further assistance. Daniel
SOURCE: My Haier dishwasher won't start,
Hi A
beeping sound indicating the dishwasher door was unlatched during the cycle. To
correct this condition, close dishwasher door to resume cycle and the beep will
turn off. This beep will be heard approximately once every 30 seconds. Blinking
"Start/Reset" light. This indicates that the dishwasher has been
reset and is in the process of turning off. This light will continue to blink
for a time period between 75 to 90 seconds depending on the model. Or check for a faulty control panel. Please
get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
SOURCE: My VZ9996U1 built-in dishwasher won't lock &
sounds like the door latch is broken, turn off power to unit and remove in side of door, about 20 screws, at th etop of th edoor you will see the latch it will have several wires going to it, you may even find broken parts (PLASTIC ) you can order parts from here http://www.appliancepartspros.com/ they have very fast shipping you just need all the info on the machine
SOURCE: Flashing lights on Amana SofSound...nothing will
Hi First make sure that nothing is blocking the drain pump
assembly located inside the lower front panel of the dishwasher. If the issue
returns after its cleaned then try to reset the dishwasher control by pressing
the HEATED DRY button and hold it for 15 seconds, if its still not resolved
then it means that the control board has gone bad and should be replaced. Hope
this helps...please post back for further assistance. Daniel
flood float switch at the bottom of the dishwasher must be faulty.
