Question about RCA D52130 52" Rear Projection Television
RCA D52130. TURNS ON FINE, BUT WILL SHUT OFF WITHIN 5 MINUTES
I can turn on the tv fine and it will show a picture for about 5 miuntes, when its cold. But within 5 minutes, it will shut off on its own. I can then cut it cback on and it will stay on for about 10 sec, and then it shuts off again. It acts like a coil does on a motorcycle, it works fine until it warms up. What is the name of the part I need to buy. I have worked on alot of LCD flatscreens, but never a projection. Thanks for any help
  • 116 Answers
SOURCE: Visual and power problem
Bad high voltage transformer. Most original transformers are not made anymore by RCA.
Posted on Mar 05, 2008
SOURCE: RCA L32WD12 32in. HGTV LCD Television
I had the same problem happen this afternoon, so I took it apart, and the source of the problem is the key controller panel (behind the buttons). It's held in place by 2 screws, if you take the case apart, which is literally only 15 or 20 screws, and then loosen the 2 screws holding the key controller panel on, and then use a small screwdriver to space it out from the button caps. Tighten the screws, and put it back together. Just be careful not to let it go too far to the other side, or you'll have a problem with the menu going on and off at random, which is just as annoying.
Posted on Aug 01, 2008
RehanZafar
  • 38 Answers
SOURCE: my sony projection model no kbfx532 in stand by mode
Dear its SOCKET CRT are faulty you can observe some sparking noise also come and during this LEED also blink. Just replace its JACK of CRT neck
Posted on Nov 13, 2008
ladywinn
  • 5138 Answers
SOURCE: Our RCA high-def 52 inch TV is shutting off on
It has you Posted as a projection TV and Not DLP, if Fan to Lamp stops running set will shut off to protect Lamp,I had a DLP that would play sometimes 30 mins then shut off drove me crazy trying to firgure it out and it turn out to be Fan would stop running I replaced Fan TV working fine . When you remove back engage toggler switch to up position put a piece of tape on it to hold it is a safty switch ,then turn tv on watch to see if all fans are running also if when tv trys to come on is there a spark coming from Ballast Board if so your new Lamp is defective it does happen if not your ballast board maybe Bad it is what turns on Lamp.If all fans are running Ballast Board.
Posted on Sep 22, 2009
  • 14 Answers
SOURCE: RCA D52W20 TV powers on fine, then shuts itself
it looks like the problem is in the 16v line..try to take it apart..and there's gonna be a 2200mf cap leaky.
that will solve your problem.
Posted on Jan 22, 2010
Westinghouse LD-4655VX Power on fine, nice picture, but around 5 minutes turn off self it
hi. the led tv turn off itseft aroun 5 minutes was complete shut off or another ?? need more data???
Jan 08, 2014 | Westinghouse LD-4655VX 46" LED TV...
Sep 22, 2009 | RCA HD52W56 52" Rear Projection HDTV
TV Picture problems
My samsung did the same thing right before my color wheel went out. Can't be sure but that is what was wrong with mine. hope this helps.
Jan 25, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Rca d52130 herd pop tv went dead
dear friend your tv has a defective fly-back transformer 99 times out of 100 that is your problem.
get the model number and call your local electronics parts distribuitor to see if they have it, if not call tritronics 1800-638-3328 they probably have it and is not too expensive.less than $25.00.now when you get here is the million dollar question can you do it yourself? if you can't call the repairman and by having the fly-back that will decrese the cost of the repair, is just the labor.
good luck
caypianan@yahoo.com
Sep 02, 2008 | RCA D52130 52" Rear Projection Television
Tv turns off after it gets hot
RCA TV's of that vintage are known for having bad solder joints in the power supply stages and they become very remperature sensitive.
Geno
Mar 17, 2008 | RCA P52937 52" Rear Projection Television
Nov 07, 2007 | RCA L32WD12 32 in. LCD HDTV
Sometimes no picture on RCA tv
its nothing really, if your tv is new then it is normal but if it continued to do it then its broken
Oct 28, 2007 | Quasar SP-3233 TV
LG Plasma TV 50PC3D
The TV should be under warranty. Send back. Sounds like the panel is faulty (half the value of the set).
Feb 06, 2007 | LG 50PX4DR 50 in. Plasma TV
Loose Picture (Goes completely Black)
Nothing special about that board as I cant seem to find that # but If my memory serves me correctly it sounds like a crt board and its a simple soldering job on the crt socket?? Altough Im not there to see the set still 550.00 seems like an awfull lot to repair a set even if they have to replace the entire chassis. I think you should cal rca and take it to an authorized RCA repair center and if the shop you took it to was an rca authorized center I would also report that to them(RCA). Good Luck
May 16, 2006 | RCA MM32110 TV
RCA D52130 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
