Question about Yamaha HTR-5850 Receiver
HTR-5850 will not turn on
My htr 5850 will turn on just for a few seconds.  it will do it three times in a row.  after the three times it won't turn on at all.  i must unplug it to make it turn on three times again.  please help, this things cost $450 and i don't want to buy another one.  thank you
tech48
  • 624 Answers
SOURCE: HTR-5850 crackles between Dolby Digital and Pro Logic when I play
This is most likely a problem with the receiver. When this type of thing starts to happen it is most often a problem on the DSP board of a receiver. Sometimes it can be fixed by reflowing the solder on the right IC's of that board, but sometimes it requires the replacement of one or more IC's. Many service centers will just try to replace the entire DSP board because troubleshooting the DSP board is a very difficult task and can take many hours of testing and checking parts resulting in a huge labor cost. Unless you are very good with soldering and electronic troubleshooting you should really just take it to a authorized service center near your home. I am sorry there is no quick fix for this. If there was, I would have surely told you. I have been repairing home theater receivers since they started making them and have never seen an easy fix for this type of problem.
Let me know if I can be of any further help to you. Just so you know, finding out what the problem is with your equipment is worthy of a FixYa! rating. The FixYa! rating is not just for getting your equipment fixed, if it were, not many experts here would ever receive a FixYa! because electronics can rarely be fixed by just pressing a button or something simple like that. And it would also require that the people asking these questions had all the right tools and equipment as well as the knowledge to identify parts and problems to help in the repair since we can not be in your home to see it for our self.
Dave
Posted on Nov 11, 2008
SOURCE: Bi-Amping my speakers with HTR-5850
You can at a minimum, bi-wire your speakers by wiring the speakers with the A and B speaker outputs. The A speaker outputs end up running the tweeters and the B will end up powering the woofers.
Posted on Dec 30, 2008
  • 128 Answers
SOURCE: How do I connect pc to htr-5850
You will need an adapter cable available on ebay or at radio shack.
Should have a 1/8" mini male stereo plug on one side and a set (left and right) male RCA plugs on the other end.
Simply plug into the output of your sound card or motherboard (usually blue or green) into any available input (EXCEPT PHONO) on your receiver.
select that input and it should work
hope that helps
Posted on Jan 12, 2010
dunnbiker
  • 8546 Answers
SOURCE: My htr-5850 just stopped producing sound while
How is TV sound coming into your Yamaha? If it's from the TV analog audio then maybe the TV's audio output is muted.
If it's from the Cable Box maybe ITs audio is muted. I'd refer to the guide for the Cable Box.
MUTE on the receiver is not source-specific.
Posted on May 25, 2010
dunnbiker
  • 8546 Answers
SOURCE: how do I hook my ipod to this yamaha device
Get a 1/8" miniplug-to-RCA-cable adapter and plug the headphone output directly into any compatible input on the receiver. Press PLAY.
Read the article (it's short). Don't buy into the hype about better cables. IPOD's don't stack up as hi-fi to begin with and cables are cables are cables....
http://www.dummies.com/how-to/content/connecting-your-ipod-to-a-home-stereo.html
Posted on May 29, 2010
I got yamaha htr 5850 350watts i dont have manual and wiring how do i connect to my tv toshiba?
EVER HEARD OF SOMETHING CALLED GOOGLE???
GOOGLE SEARCH! USE IT!!!
yamaha htr 5850
Google
The very first thing on the GOOGLE list is that model on the Yamaha website where you can download the manual.
The second thing on the GOOGLE list is the very manual itself.
Sep 18, 2016 | Yamaha HTR-5850 Receiver
My htr-5850 just stopped producing sound while using the cable TV. I muted it once and when I took it off mute I have not been able to get the TV's sound to work since. I have no idea what to do. Any...
May 25, 2010 | Yamaha HTR-5850 Receiver
Yamaha HTR-5850 Receiver Audio -left front speaker output problem
Does the speaker setup fail the same way?
Yes? Internal amplifier problem.
If No - What source(s) do this?
If just one - reverse its Left and Right inputs to determine which cable or channel on the input device is faulty.
May 23, 2010 | Yamaha HTR-5850 Receiver
How do I hook my ipod to this yamaha device HTR-5850 -- is there a piece of hardware I can get to interface? thanks
Feb 21, 2010 | Yamaha HTR-5850 Receiver
hope that helps
Jan 09, 2010 | Yamaha HTR-5850 Receiver
Is it possible to play my ipod nano through my Receiver?
If it doesn't have a jack made for plugging Mp3 players into it like the new car stereo's do than you just have to go buy an FM transmitter that is made for Mp3 players. It will play through one of your low FM frequency's on your receiver. You can generally pick one up for around $20
Jan 02, 2009 | Yamaha HTR-5850 Receiver
Dec 30, 2008 | Yamaha HTR-5850 Receiver
Yamaha HTR-5990 Audio no longer works
MichaelM
Did you ever get this resolved?  I have a similar problem, my video feed seems to work but I have never been able to get any sound from my speakers using this component.  I'm not sure what YPAO setup is but I just read a suggestion to reset the receiver to factory settings in the event something is programmed that causes the problem.
Jun 21, 2007 | Yamaha HTR-5990 Receiver
Sound cutting out
I'm presuming you are referring to a Yamaha HTR,right???(Night Listening Enhancer (Cinema/Music) and SILENT CINEMA)..see page 32 in this manual at this link,here's the owner's Manual,also available to download for free in .pdf (Adobe) format.......https://www.manualslib.com/manual/197349/Yamaha-Htr-5940-Av.html
May 09, 2017 | Yamaha HTR-5850 Receiver
Yamaha HTR-5850 Receiver Logo
46 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
