Question about Samsung HCM4215W 42" Rear Projection Television
HCM4215W SAMSUNG TV TURNS ON AND TURNS OFF AFTER ABOUT 5 SECONDS
I have a hcm4215w tv that I got from a friend with a convergence problem. I replaced the complete convergence board about 8 months ago and has been working fine. Over the weekend, the tv was on and it just turned off, then it powered back up and turned back off. It will keep doing this until you turn it off or unplug it. I unplugged the connectors on the convergence board and tried it again and still does the same thing. Is there another common problem with these units that I can replace or is it more involved to repair? Also when the set turns on for the short period of time, the audio turns on and you can hear the station that it is on but it turns off before the picture comes on. Thank you.
  • ctillerjr Dec 31, 2008
    I have that same exact same problem. What can be done?
    Top Expert:
  • Samsung Master
  • 74,136 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Mar 29, 2017
SOURCE: Samsung hcm4215w Convergence board problem
I found my convergence board on ebay being sold by partsstore.com. try looking there.
jim
Posted on Nov 07, 2007
easyab
  • 132 Answers
SOURCE: SAMSUNG HCM4215W Rear Projection HDTV shuts down
Low ohm resistors are open or poor solder connections on the bottom of a convergence IC.
You need to look at resistors in good light with magnifying glass. Bad ones may show as discolored or burnt.
The repair needs someone that has the schematic for the convergence cct, and can replace the burnt resistors or replace the whole convergence board.
http://calgaryconvergencerepair.weebly.com/index.html
If you are near Calgary, call me, if not, find someone that has done it before, preferably many times.
easyab
Posted on Aug 15, 2008
easyab
  • 132 Answers
SOURCE: TV set shuts down
3.9 ohm 2W
They are parallel in circuit and measure around 2 ohms when ok. Check the fuse associated with that circuit. FD101S 3.5 A
easyab
Posted on Aug 24, 2008
SOURCE: Samsung HL5067W power cycling
It's simple. Your TV does not like you. Perhaps you need to speak kindly to it before you force it to watch BBC for hours. Buy it a scone.
Posted on Nov 24, 2008
  • 2920 Answers
SOURCE: double images
you will need to have the tv re converged to make the picture right call a repairman
Posted on Feb 16, 2009
Samsung hcm4215w turns on and off again. Why? How can I fix this?
Hi there
Try resetting the TV by unplugging everything, and wait 3 minutes, then plug in the power lead only, and turn it on.
Hope this helps
TV_Doctor
Jan 03, 2011 | Samsung HCM4215W 42" Rear Projection...
Samsung hcm4215w tv Power,picture, sound problems
Replace the proscan module BP95-0007A Call Encompass Electronics for price 1-800-638-3328 or look for one one E-Bay Thats if TV comes on plays then starts shuting off/on If not replace power supply board.BP96-
Sep 10, 2009 | Samsung HCM4215W 42" Rear Projection...
Samsung 42'' HCM4215W image looks like it's in #D
Ill have to look up the part numbers , but it is a common problem caused by the convergence board at the back of the device. replace the TDA*** for the color that is faulty and the problem should be solved.
After replacing the TDA*** you need to adjust the convergence again and perform an auto-fucus and convergense adjust again
Jul 08, 2009 | Samsung Televison & Video
Blinking power light after replacing convergance board.
Your chips are most likely bad or you bridged the soldering.
For all others with similar convergence problems
This is a common problem.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 06, 2009 | Samsung HCM4215W 42" Rear Projection...
Cannot not line up the red and blue lines on my samsung projection tv. it is a 2002 samsung tv
Needs new convergence amps and possibly a few low ohm resistors.
Those Samsung amps usually run hot to the touch and sometimes only last 4 to 5 years depending on usage.
Apr 20, 2009 | Samsung HCM4215W 42" Rear Projection...
Double images
Feb 16, 2009 | Samsung HCM4215W 42" Rear Projection...
Red Convergence Issue( Samsung HCM4215W)
Bad chips or faulty soldering.
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
Dec 23, 2008 | Samsung HCM4215W 42" Rear Projection...
Ghost like shadows
It seems your TV Samsung HCM4215W has problem in convergence board and need to be replaced.
You can get that board from Parts Store on $76
If you have bit electronics knowledge and know how about tv repair, you can replace it by yourself or get help of local tv tech person.
Oct 06, 2008 | Samsung HCM4215W 42" Rear Projection...
Samsung HCM4215W
Unplug the power.
Remove largest plug from convergence board. Plug in TV, see if it starts. If it does, then a convergence IC is are shorted.
Repair convergence
easyab
Jul 28, 2008 | Samsung HCM4215W 42" Rear Projection...
Use PANASONIC STK's.They are expensive,but they hold up!Safe,durable repairs require OEM or BETTER quality replacement parts.
Sep 27, 2007 | Samsung HCM4215W 42" Rear Projection...
Samsung HCM4215W 42" Rear Projection Television Logo
37 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
