Could mean something is vibrating hard enough to make a sound that can be heard--usually a coil or a transformer--if it bothers you consider replacing that board.
More information please. The make, model and year of the vehicle. What kind of noise is it? A Squeak? A thump? A rumble? A squeal? A whine? Without this we cannot work out what the problem could be.
Hi check if speed button is on high & check if freewheel lever is in drive position CHECK THE BATTERIES WITH A LOAD TESTER U CAN BUY THEM ON E/BAY COST APROX $35 THIS WILL GIVE U AN ACCURATE READING ON THE CONDITION OF YOURE BATTERY'S ..,, CHEERS
Go to http://www.carlsalter.com/motorcycle-manuals.asp , and go through the available manuals. Although yours is not listed, perhaps the 750 manual may have all the information you require.
Hi there. Clean both fans if dirty. (inside and outside) Check for foreign objects like insulation caught in the squirl cage blower. Make sure unit is level. Check for vibrating tubes. Thanks Paul
