Question about Bulldog& Remote Alarm System With 1-wire Hookup
Hooking up new tv to old dish network system - Bulldog& Remote Alarm System With 1-wire Hookup
  • 344 Answers
Are you using a bulldog product for this ?
Posted on Jan 25, 2010
Hooked up the vip722 to my new 1080HP vizio ( with hdmi cables) and I am only getting a 480p signal. When I hit the info key on my vizio remote, it says 480p on the corner of the screen. Yes, I do have...
bestone890,
Go into the Main Menu. From there go to System Setup (6) -> HDTV Setup (8). Make TV Type 1080i and Aspect Ratio 16x9 and select Done. Your picture should now be showing a HD picture.
Tommy Faust
DISH Network
Apr 12, 2011 | DISH Network ViP722 DTV Receiver /...
I am replacing a 50' run of RG-6 Quad Shield cable from my central box in a closet to a wall jack. I am simply unplugging the current run because the jack is in the wrong place and replacing that run with...
Hello, I am a Dish Network technician.
The most likely reason you're having this issue is may be some type of switch between your closet and your TV jack, that you're bypassing when you install the 50' lead. Your best bet will be to schedule a technician to come for a visit, we have the tools and training needed to find and eliminate your issues with ease. Most likely, this is something that the average person won't be able to tackle.
Aug 22, 2010 | RCA DISH Network(r) 311 Satellite System
Lg lht854 does not work tv sound
Ok your dish network wont play through the LHT854? Which Dish network receiver do you have 211, 311, 625, 612, 722? From the owners manuel for the LHT854 it looks like you can only hook up the audio from another source by an optical cable, so how is the LHT854 hooked up to the dish network receiver?
Aug 19, 2009 | LG LHT854 Theater System
Screen is black and won't pull up dish network
not sure on what dish system in use - but if you are running a sky box or freeview the box will reset it self when turned off-
if so do away with ch.60 and fit av(scrat) lead to back of tv. & box.and progames will autom. come up on av channel.if this dose'nt work drop me an e-mail with more detail of your system and I'll try again.
pbviewingsky@yahoo.ie
P.
Aug 07, 2009 | Televison & Video
Philips flat tv. Can't get it to hook up to dish network. The room where the tv is there isn't a dish box. We have to watch what is on in the other room. It only has one coax cable to hook up. Don't know...
I should be channel 3 or 4. This assumes that this coax cable is coming out as a TV R.F. connection of a Dish Network Box (Satellite Receiver) intended for direct connection to an old fashioned NTSC (channels 2-13, 14-83, possibly even has cable channels depending on how old?) TV.
If this coax is the output of a coax going directly to the Satellite Dish or through what might might look to you like some kind of fancy splitter (called a Multi-Switch) the you WOULD NOT want to hook that to your old NTSC tv. The frequency is too high ... etc. etc... you would need Dish Box (as you call it) a.k.a. a Satellite receiver - with a good and active satellite card from your provider.
Jul 07, 2009 | Televison & Video
Hooking Up Panasonic sc-ht670 home theater to Dish DVR 625 and Panasonic TH-42PHD7UY Plasma TV
You will need to run a set of audio cables from the TV1 output on the rear of the 625 directly to one of the three audio inputs on the surround system. Thanks for using Fix Ya.
May 13, 2009 | DISH Network DVR-625 DTV Receiver /...
Tv has sound but no picture.
If it works on DVD but not on your Dish, and when you connected it to another house it had the same problem then it sounds like your input connection is bad on the TV. That is if I am understanding this right. From what I am reading your Dish network is not showing a picture but the audio is working fine. The DVD player works fine on the TV though. Then you took the TV and hooked it to another dish system and it was the same problem. That sounds to me like you TV is having a problem, either that or the cables for your Dish network are bad. Try switching to a different input, like the one the DVD player is on and seeing if it works there. If not, then the cables are bad and you just need to replace the cables. If it does work though where the DVD was working before then your TV input is bad on that port you were hooked to before.
Let me know if you have any other questions and if this was helpful. If you need some more clarification let me know, I hope this is helpful. Good luck and have a good weekend. Get it fixed before the Super Bowl.
Jan 25, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Connecting DVD to cable only TV and Modulator box and Dish Networ
Without knowing the actual ports on each of these devices, all I can suggest is that have you tried connecting your DVD to the Dish box (thru VCR scart connection at the back of the Dish box) and then the Dish box into your modulator (and then modulator into your tv.
I have a similar system set up but we have a Sky Digital box here, no idea if its the same as a Dish box but im assuming so.
Jan 01, 2009 | GPX D1816 DVD Player
No signal when hooking up to dish network.
I unhooked the new tv and hooked up the old one to see what channel it was on and then rehooked up the new tv and put it on the same channel as the old one.This worked but I also had to put the cable into the hook up on the back marked cable instead of the one marked HDTV.
Dec 11, 2008 | Polaroid FLM-323B Television
Bulldog& Remote Alarm System With 1-wire Hookup Logo
57 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
John
John
baire
DROPNDEAL
DROPNDEAL
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
