Question about Toshiba 51H83 51" Rear Projection HDTV-Ready Television
Toshiba 51h83 projection t.v. scrammbled lines across the screen.
The t.v. has a bunch of scrammbled lines from top to bottom. Sometimes a little stomp on the floor, are a shake of the t.v.(which i know is not good) clears it up for a bit. Just trying to get a little advice on what to do. It looks like when theres something scrambling your tv. The picture is there, but the lines make it a pain to see and rough on the eyes. I havent taken it apart are called the repair man yet, just trying to get some advice on what the issue may be.
  • Anonymous Oct 09, 2008
    No movement seems to make my lines go away...at random moments it will clear up. Any suggestions?
    Novelist:
  • 192 Answers
I've seen this problem before with Toshiba sets. Normally it's been caused by the hyper module. Usually, the set is worst when first turned on and clears up some, if not completly after it warms up. The problem does get worst over time.
Posted on Jan 28, 2007
My 15 year old toshiba projection tv that was hardly used. the screen now will not light up and on off button is blinking
Hello, I just received your email about your TV and will do a little research on it to give you a good answer to the problem real soon later today. Thank you Looks like a 51H83 model
Feb 17, 2012 | Toshiba 51H83 51" Rear Projection...
I have a Toshiba 51h83. Everything works fine except there is an issue where the colors are slightly lighter on both the left and right sides of the screen.
this is normal with rear projection tv's its from long usage when the tv isnt always in full screen mode. you can sometimes fix this by replacing the bulb/ or the color board for the projector. also you can replace the screen as it seems like it may also be do to image burn in if it wasnt always in full screen mode. (did this for my uncles Mitsubishi projection tv)
let me know if that helps!
Mar 16, 2011 | Toshiba 51H83 51" Rear Projection...
Hello..Toshiba 51HC85, 2005 model. Turn on TV and verticle wavy lines appear until TV is warmed up completely. After warm up the picture is great again. Any ideas?
I've had the same problem for about the last 6 months. My workaround which was to leave the tv on 24 7 and just turn off the TWC service box. But now the symptoms are vertical dark lines going all the way across screen. My guess is that it will cost more to fix than worth it. I paid @$2000 for it new in 2004. Technology has gotten better so I may just go out and get a Samsumg for considerably less and be way better off. None of Toshiba's products had done well for me. 2 laptops, 3 tvs, etc. have taught me this.
Sep 20, 2010 | Toshiba 51H83 51" Rear Projection...
My Toshiba 51 inch projection tv has red squares on screen
The model indicated is a projection set and the question is does it look 3d looking etc or something else?
See attached photos of typical convergence problem which MAY be what you have.
SD TECH
May 02, 2010 | Toshiba 51H83 51" Rear Projection...
TOSHIBA REAR PROJECTION TV 42H81
you have a convergence problem that will require the replacement of the convergence amp ics.
Nov 29, 2007 | Toshiba 51H83 51" Rear Projection...
Suspected Convergence Issue on Toshiba 51H83?
Needs chassis pull & convergence IC's replaced....then
Touch Focus will work again..................T.
Nov 19, 2007 | Toshiba 51H83 51" Rear Projection...
Crazy Picture
yes there is a hyper module,sounds like bad connections on the socket that it seats in or inside the module. remove and reseat and ESR the electrolytics....john
Sep 17, 2007 | Toshiba 51H83 51" Rear Projection...
Toshiba 51H83 51 in. Rear Projection pisture issue
I have a wild guess. I have the same tv and channel 72 is the proper channel to watch tv on. I don't know why, but maybe try channel 72 instead of the usual channel 3. Good luck, maybe a quick fix, maybe not!
May 30, 2007 | Toshiba 51H83 51" Rear Projection...
Wavey coloured horizontal lines and no sound
sounds like a bad eeprom.If thats not it start looking in the power supply.
Apr 11, 2006 | Toshiba 51H83 51" Rear Projection...
Toshiba 51H83 51" Rear Projection HDTV-Ready Television Logo
252 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
