Question about Maytag MDB7100AWB Dishwasher
How to take the upper and lower spinner off.
All of a sudden my dishes are not coming clean. I think I need to check the top and lower spinner but I don't know how to get them off safely. Is there a simple way? Thanks.
  • kaysdx Feb 25, 2009
    All of a sudden my dishes are not coming clean. There is plenty of water inside the dishwasher, but it would appear the upper dishes are hardly even getting wet. I suspect the upper spray arm is not spinning.
  • 734 Answers
1. No waterMake sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
Posted on Dec 02, 2008
Top shelf not cleaning
Hi, the most likely cause of this is the sump is plugged under the screen area, I have put some instructions together to show how to clean out down there. let me know if it helps.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Apr 28, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
My dishes come out dirty and glasses are cloundy.
#1 check the upper spinner arm to see if it is clogged with particles if it is, clean the holes outi f they get clogged the arm-sprayer will not clean the upper rack
#2 if it is not clogged got to your local Grc.chain and purchase a bottle of dishwasher cleaner for about 8.00 follow all instructins on bottle make sure water is hot by running hot water tap closest to dishwasher.use it in an empty dishwasher.You will be amazed how clean your dishes will come out after the first wash
Jan 23, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Hi, the dishwashers top rack dishes are not being cleaned.. help?
sounds like the upper spinning arm is not turning check to see if it is clogged at the nozzles if so take off and clean particles out also check bottom ofjet that spray soap up to upper spinner and see that is not blocked
Nov 12, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Upper rack is not cleaning. Greasy dishes on top seem that dishes are not being washed. Seems the upper water turning dispenser is not working, Bottom rack seems ok. I guess I only have half a dish washer...
Check the upper arm for free spinning, then remove the arm and check that the seam between the upper and lower halves has not split somewhere. Also check all the small holes for debris plugging. Run the machine in wash cycle for a little while with the upper arm off--that should flush out anything blocking the pipe up to the arm. If still nothing from the upper arm, tear down the lower arm assembly down to the deck while noting position of all parts removed. Clean the big screen at the bottom in white vinegar and hot water. Inspect the holes in the bottom for anything blocking them.
Aug 15, 2009 | KitchenAid 24 in. KUDS02FRSS Stainless...
Clean on bottom rack but dirty on top
Clean the filter at the bottom of the tub. If it is dirty or clogged the water pressure may not be strong enough to spin the top arm. Make sure also the there is nothing blocking the holes of the spinner arm. If the filter and arm are clear then the pump may be failing.
Aug 13, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Kenmore dishwasher not cleaning properly
Look in the inside for any screen that would be easily removed, some dishwashers have a self cleaning filter so you may not find it. I have a lot of other tips for you if your dishwasher is not cleaning so check it out.
http://tclaundryrepair.com/dishwasher
Feb 17, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishes and Flatware Don't Get Clean
Check to see that the removable cup rack on the left is seated correctly. One of the support legs of this rack is located above center of the spinner. If this leg is sitting on the top of the spinner rather than the center cross member of the main rack, the spinner will not move after that rack has been loaded.
Also check that the spinner is free moving once the draw is fully loaded, some plates can sit low enough to obstruct the spinner.
Mar 20, 2008 | Fisher DD603FCSS Dishwasher
Dishes not getting clean
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Nov 25, 2006 | Kenmore 24 in. 15933 Built-in Dishwasher
Maytag MDB7100AWB Dishwasher Logo
295 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
