Question about Mitsubishi VS-4544 45" TV
Mitsubishi VS-4543 not powering up
When pushing the power button the tv clicks once on the clicks again off. If I leave it unplugged for a few mins it will occasionally come on for about 10 mins then shutdown and will not do anthing but click on - then click off. It has worked perfectly for years. I only use the set a couple of hours a month. I am pretty handy with electronics. Can you tell me what it could be or how to find out?
The TV is a VS-4543 but it is not a choice even thought there are lots of post for this set
MikeNJ1964
  • 398 Answers
SOURCE: Mitsubishi VS 4543, Picture go out after a few minutes
I usually find that symptom you describe is caused by cracked solder joints on the power regulators or vertical output IC. I have also seen that symptom caused by loose solder joints on the vertical windings up inside one of the yokes. If you have experience in repairing TV's then you can disassemble the set and pull the main chassis, flip it over and resolder all of the parts mounted on heat sinks. If you do not have experience in repairing projection TV's then allow a qualified tech to handle it for you.
Posted on Aug 05, 2007
  • 1694 Answers
SOURCE: MITSUBISHI VS-4543
PVAT!!Look for bad connects--start w/easy first. Power supply,then vertical IC pins,then regulators.Take your time,be thorough.
Posted on Oct 01, 2007
SOURCE: PICTURE GOES OUT ON MY MITSUBISHI MODEL # VS-4543.
disassemble the set.
Posted on Oct 14, 2008
darjr
  • 378 Answers
SOURCE: I have a Mitsubishi vs-4543 tv that when powered
check the power supply section.. probably the electronic component got problem.
Posted on Jun 04, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Where can I find a
You can download a copy of the manual here.
Posted on Oct 15, 2010
Tv mitsubishi vs-60111
Was there a power failure? unplug unit for a min and plug it back in. hold power button til unit turns on. If it still flashes you may have a power supply problem inside the unit.
Apr 08, 2014 | Mitsubishi VS-60111 60" Rear Projection...
Blank screen and no audio on Mitsubishi vs 4543 when ps3 is connected through rca cables. other electronics work fine.
Check and replace the main power regulator [SMPS] board to your TV. Contact any service technician, or the authorized service center for Mitsubishi. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 12, 2014 | Mitsubishi VS-4543 45" TV
The tv wont power on and the green timer light continuously blinks. I have unplugged the the tv and also hit the reset button.
...OK to begin troubleshooting this. Unplug the set and leave for 1 min then plug up and leave for 2 min push the power button and let light blink for 2 min.... now push and hold at the same time the MENU and DEVICE buton st the same time. this is the self diagnoses feature ... the lights should link then pause then blink again... this 2 digit code will help narrow it down. Also have you check the lamp yet?
Oct 22, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Jun 04, 2009 | Mitsubishi VS-4544 45" TV
Mits rear projection VS-4543
i wouldahve the power supply checked out,,,it sounds like it may be getting weak
Jul 08, 2008 | Mitsubishi VS-5043 50" Rear Projection...
MITSUBISHI VS-4543
Oct 01, 2007 | Mitsubishi VS-4543 45" TV
Power problem
Look in Mitsubishi threads here your problem has already been answered.
Sep 21, 2007 | Mitsubishi VS-4543 45" TV
Aug 05, 2007 | Mitsubishi VS-60607 TV
Mitsubishi vs-4543
Most likely the convergence output IC has shorted out and has overloaded the convergence power supply, which has stopped working. The computer senses that the convergence power supply is not running and shuts the set down. The convergence IC should be replaced, the power supply restored and the convergence circuits realigned by someone experienced in Mitsubishi projection sets. When I do a housecall for a set like that I charge $150, but shops in your area will vary so ask around.
Aug 04, 2007 | Mitsubishi VS-4543 45" TV
TV turns off a second after turning on....
You have a high voltage shutdown problem, look at the threads here on Mitsubishi and you will find your answer.
Dec 09, 2006 | Mitsubishi VS-4543 45" TV
Televison & Video Logo
50 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
