Question about Syscan DocketPORT 665
I am getting error message
I am getting below error message and try to install software but it will not allow me to do so. Error Message " The scan was aborted because the sanner is not powered on or not connected properly. Please check the hardware connection and try again". Please let me know what I need to do.
Thanks
SOURCE: HP OFFICEJET 7410 "NO SCAN OPTION"
1.open the HP Director/Solution Center 2.click on scan menu and go to destination list tab 3. on the left side u will find a list of available destinations , move them all to the right side (front panel destination list) and save and then try to scan again , IT MAY WORK
Posted on Jan 22, 2007
SOURCE: Scanning probelm with my MP810
May be MP Navigator not compatible with Kaspersky 2009.
If you use KIS or KAS to protect your computer,disable KIS/KAS protection and try again.
I have same problem with my MP150 and after disable protection of my KIS2009, MP Navigator work perfectly.
Sorry for my bad English. I'm Vietnamese.
Posted on May 10, 2009
  • 413 Answers
SOURCE: Message appears on printer display: Sanner Failure - Unable to scan or copy
Install all the software on the installation cd.
Posted on May 29, 2009
  • 5 Answers
SOURCE: The scanner(travelscan pro 600) gets a no power or not connected message!
Go to Device Manager and most likely the travelscan pro 600 is not popping up under imaging devices where it should be. Unplug the scanner and plug it into a different USB port. Try this on all the USB Ports on the machine if it reappears in device manager then the software will work. If you are using a USB extention cord or USB hub get rid of them till you try all the ports. If it doesn't i would suggest contacting the manufacture and seeing if the scanner is still under warranty.
Posted on Jun 29, 2009
  • 79 Answers
SOURCE: Exact same problem
firstly I hope the model number is correct. if yes try once again the following steps.
disconnect the Docketport from usb. go to device manager and see there devices marked with yellow exclamation mark. remove them and restart the windows.
1. download the driver and install it
http://www.docucap.com/drivers/DocketPORT465_v1_1_4_setup.exe
2. secondly Docketscan application is needed ..download it too and intall
now try connecting the dockerport
I hope this should make things work.
Posted on Aug 07, 2009
When I try to download from a YouTube URL, I get an error message that reads:
I was getting the same error message. Mine was working fine before but it started getting error a couple of months ago. I searched the internet and could not find the answer. I finally went to the ilivid site and scanning through the faq, I noticed I had an earlier version then now. So I uninstalled and installed the new version and now no error message. HTH's you.
Oct 06, 2012 | Make IT Simple ilivid Download Manager
Scanner twain driver will not install
Dear sir,I am sory for your problem.Please format your oparating system i mean you install new windows.some times optical driver did not read properly data cab file,So hardware driver is not support properly.Windows xp SP3 is not complite version some messing.
Thanks You are success
Tareq
Aug 27, 2009 | Epson Perfection V300 Film Flatbed Scanner
Error printing scanned
some files may be corrupt: Best is try to reinstall printer software with original drivers to ensure that correct files are installed.
Jun 08, 2009 | Kyocera FS-3900DN Laser Printer
HPSC1610 all in one
Im very sure that you encountered that message when trying to scaning using the HP Director / HP solution center. Here are the steps that i want you to do inorder to solve the issue.
1. Insert the CD that you used to install the Software.
2. The Window for installation will pop-up, CLICK ON UNINSTALL. (note: make sure that you unplug the usb cable from the back of your computer before uninstalling the SOftware).
3. When done, restart your computer.
4. Re-insert the CD and Click on INSTALL.
The reason why you encounter such problem might have something to do with the corrupted components of the Software installed in your pc.
Thank you so much.
adonscott
Jul 03, 2008 | HP PSC 1315 All-In-One InkJet Printer
Editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
Imation atom usb driver vista
vista has this problem , see below webite
Error message when you try to install a new hardware device on a Windows Vista-based computer: "Windows encountered a problem installing the driver software for your device GET basis information
http://support.microsoft.com/kb/940199/en-us
Jun 06, 2008 | Electronics - Others
Syscan DocketPORT 665 Logo
62 people viewed this question
Top Syscan Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Marvin
Marvin
Are you a Syscan Office Equipment and Supply Expert? Answer questions, earn points and help others
