Magnavox ZV420MW8 only shows in black and white with no sound
When I tried to use my Magnavox ZV420MW8 it will not show anything in color only in black and white. Then there is also no sound but all the wires are plugged into the correct spots. I've tried putting the wire into different spots just to double check and then there is no picture at all so I believe I have the wires in the correct spot it just wont play and needs sound.
SOURCE: clear sound with jumping picture
either the disc ur inserting is dirty or the laser needs cleaning try cleaning ur laser first then the disc if the problem prosist take the dvd player back
Posted on Feb 08, 2008
  • 11 Answers
SOURCE: DVDs are only in black and white
Jimbo.. is your new TV HD compatiable??
Posted on Feb 15, 2008
  • 149 Answers
SOURCE: No color picture on any DVD played
Make sure the scart lead in pushed in fully and none of the pins are bent!!
Posted on Mar 29, 2008
Randy V
  • 236 Answers
SOURCE: dvd only playing in black and white
Make sure that you connect all of these connections to the right colored cables.
It seems like you only have the green cable connected. Go back and connect the red and blue for both the tv and dvd.
Posted on Aug 06, 2008
SOURCE: zv420mw8 magnavox vhs to dvd recorder
I have lost my remote to my Digital Video Disc Recorder with Videeo Cassette Recorder #ZV420MW8. I would like to know how to go about getting a replacement. Thank You, Diane Wotton dianewotton@yahoo.com
Posted on Nov 02, 2008
Packard Bell monitor showing colors
Replace the monitor, is dead.
Aug 04, 2012 | Computers & Internet
How do I change VCR recording speed on the Magnavox ZV420MW8
If you have the manual it is on page 79 (Press Rec Mode There are two speeds SP SLP it will toggle between the two.)
You can download the manual at http://www.funai-corp.com/6pdf/om/ZV420MW8.pdf
Jul 04, 2011 | Magnavox ZV420MW8 DVD/VCR
Magnavox 42"
You are correct=====Return it ! It's new, you should not have to have it repaired this soon.
Sep 23, 2009 | SNK Magnavox 42MF231D 42 in. Plasma TV
My plasma, lcd tv only shows in black and white
Would you say say the color is intermittent, sometimes black and white an occasionally flashes streaks of color? The small signal board may be at fault. You can ask to have the board replaced or fix it at the component level. Parts for the board at component level could be PN#823827736071 location 1H00, this is i beleive a color crystal, and two capacitors , PN#223886975478, location #s are 2H08 and 2H09. This repair is very prettymuch the repair you will need. Theses are surface mount parts and will require a tech to do. Hope this will give you a good start for repair!!!!!
Apr 10, 2009 | Philips Magnavox 42MF521D/37 Television
NO AUDIO ON MAGNAVOX ZV420MW8 RECORDING SECTION
Are you using AV cables (Red, Yellow, White).
One of your AV cable connections may loose or disconnected.
I hope this solution is helpful. Please remember to rate this solution.
Feb 03, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox TV/DVR/VCR Combo Model 20MC4304/17 color out
tengo un televisor magnavox combo pero so;o quiero sabersi se puedde dejar solo funcionando como tv ...y eliminar dvd . ya que no puedo hacerlo.
alguna ayuda se la agradeceria
Feb 03, 2009 | Philips Magnavox 20MC4304 20 in....
No color and sporatic play on VCR mode, with zv420mw8
If this problem happened within a few seconds, you probably have dirty heads. If It happened slowly you could have an alignment problem. Both of these problems should be repair professionally.
Fuji
Jan 29, 2009 | Philips Magnavox DVD/VCR Dual Player
Zv420mw8 magnavox vhs to dvd recorder
Oct 31, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox ZV420MW8
This recorder only records inline. This means that there is no channel on recorder. It records whatever your satellite or cable box is showing. You'll have to change the channel on that.
I don't know that this will work for timed recording. You'll have to make sure that your cable/satellite is on and set to the proper channel before you leave. This wont work if you're recording multiple shows on different channels while you're gone. In that case you may need a different recorder.
Mar 16, 2008 | Philips Magnavox DVD/VCR Dual Player
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
